Setting the editor -> setting is forgotten [message #245141] |
Sun, 01 July 2007 12:36  |
I just upgraded to Eclipse Europe and I'm very impressed by this new
release.
One thing which remains a problem for me is the assignment of editor to
file. For example I assigned the WTP XML editor to the file "chapter10.xml"
which previously assiged to the text editor.
If I then change to another file and then back to chapter10.xml then the
editor does not work anymore. The XML editor is still selected as editor in
the list but I have to re-select it to make the XML editor active again. To
me it seems that the text editor is active and the XML editor is still
selected in the list.
This problem occurs only with some files and also an Eclipse -clean did not
solve this.
Any ideas how to clean this up?
Best regards, Lars
Re: Setting the editor -> setting is forgotten [message #245254 is a reply to message #245229] |
Tue, 03 July 2007 13:40  |
No, nothing in the log. It is always reproducable for me but not for others.
But thanks, I will try to investigate more.
"Daniel Megert" <daniel_megert@ch.ibm.com> wrote in message
news:f6ct32$s8o$1@build.eclipse.org...
> Lars Vogel wrote:
>>Hi,
>>as this doesn't work for me any suggestions how to solve / investigate it?
> Anything in .log? Try to narrow it down to a reproducible case and file a
> bug report.
> Dani
>>Best regards, Lars
>>news:f6ae64$4gg$1@build.eclipse.org...
>>>Lars Vogel wrote:
>>>>Hello,
>>>>release.
>>>>"chapter10.xml" which previously assiged to the text editor.
>>>>in the list but I have to re-select it to make the XML editor active
>>>>again. To me it seems that the text editor is active and the XML editor
>>>>is still selected in the list.
>>>>not solve this.
>>>This works fine for me. Note that if you ever used 'Open With' on file
>>>x.y it will remember that editor even if you change the default editor.
>>>Dani
>>>>Best regards, Lars
FUDForum. Page generated in 0.04451 seconds
