Home » Eclipse Projects » GEF » shall I use GEF or just draw2D?
shall I use GEF or just draw2D? [message #244582] Sun, 27 July 2008 09:21 Go to next message
Originally posted by: wizardishappy.gmail.com
I'm new to draw2D and GEF.
I want to draw several cycles and use cursor to draw lines to connect them. The user can input some labels to every line.
I wonder if I can just use draw2D or I have to use GEF.
TIA.
Re: shall I use GEF or just draw2D? [message #244585 is a reply to message #244582] Mon, 28 July 2008 01:34 Go to previous messageGo to next message
> TIA.
try GMF, http://www.eclipse.org/modeling/gmf/, which is more simple than
writing GEF App by hand if you are new to Graphical Editor.
Re: shall I use GEF or just draw2D? [message #244629 is a reply to message #244585] Mon, 28 July 2008 09:53 Go to previous messageGo to next message
hi,
Start with GMF without knowing in EMF or in GEF doesn't seem to be a
good idea ! You will be fastly lost.
For me, you should use GEF, all the more so your needs are rather
simple. You could see the shape example to begin.
>> TIA.
Re: shall I use GEF or just draw2D? [message #244645 is a reply to message #244629] Mon, 28 July 2008 10:32 Go to previous messageGo to next message
In fact, only one thing I cannot solve with Draw2D.
That is how can I edit a Label directly in a canvas?
(in my case, the user could edit the label of the connection).
One solution I figured out is to popup a dialog to let the user input something. But we all know that if there is a way to let the user directly edit the label in the label on the connection could be better. (The similar situation in JS of web application is to call show a Text component replacing the Label on the mouse click event, but I cannot find the similar component in draw2D. :( )
If any friend can give me a solution without GEF, I will be very happy. But if you point out GEF could be a better way to solve this, I will thank you too and to learn that..
TIA.
Re: shall I use GEF or just draw2D? [message #244654 is a reply to message #244645] Mon, 28 July 2008 12:24 Go to previous message
With GEF you have some element to help you to implement this kind of
feature.
see LogicLabelEditPart in the logic example (performDirectEdit,
LabelDirectEditPolicy)
Perhaps, you could do something like that without using GEF, but it's a
bit pity.
> TIA.
Previous Topic:Combo Box
Next Topic:Embedded object in ZEST
Current Time: Sun Nov 09 06:56:12 EST 2025
Powered by FUDForum. Page generated in 0.04043 seconds
