Home » Archived » Test and Performance Tools Platform (TPTP) » Timed Plugin-tests
Timed Plugin-tests [message #24012] Fri, 29 July 2005 05:50
Originally posted by: edoardoATenigmatecDOTnet.no.spam
Junit Perf provides a simple to use TestDecorator that can among other
things, have a test fail if it is taking too long.
It cannot be used as-is with plugin tests that use the Platform UI as
certain API, for instance :
PlatformUI.getWorkbench().getActiveWorkbenchWindow();
display.readAndDispatch()
can only be called in the UI thread which is used by Eclipse's junit
runner to invoke a testXXX method.
what approach would you advise to decorate existing UI tests to
time-bind them ?
TIA,
Edoardo
Previous Topic:jdbc
Next Topic:Why do we need the agent?
Current Time: Fri Jul 25 09:43:44 EDT 2025
Powered by FUDForum. Page generated in 0.07746 seconds
