Getting javahl 1.4.5 to work on windows xp [message #24010] |
Wed, 02 July 2008 20:43  |
I am trying to get JavaHL 1.4.5 to work on Windows XP with Subversive
0.7.1 and I keep getting the following error message when I try to
create a new repository location in the SVN Repository Perspective:
The system cannot find the file specified
svn: can't create tunnel: the system cannot find the file specified
I am using the svn+ssh: protocol to connect to the repository.
Do I need to install some external software that JavaHL needs to access?
I can't find any documentation that covers this.
I currently have following subversive and svn connectors installed in my
Eclipse 3.3.2:
JavaHL 1.4.5 Win32 Binaries 2.0.1
Native JavaHL 1.4.5 Implementation 2.0.1
Subversive SVN Connectors 2.0.1
SVN Team Provider 0.7.1
SVN Team Provider Localization 0.7.1
I am successfully connecting to the repository using Eclipe 3.3.2 on
Linux using JavaHL 1.4.4.
Any suggestions would really be appreciated.
Keith
ps. I have tried using SVNKit 1.1.7 on both Windows XP and Linux and I
have had no luck with it when using the svn+ssh protocol, which is why I
am now trying to get the JavaHL connector to work.
Re: Getting javahl 1.4.5 to work on windows xp [message #24172 is a reply to message #24107] |
Thu, 03 July 2008 05:38  |
No, you don't need to install the separate client.
The problem seems to refer to wrong tunneling configuration for your
network.
The native client does not include svn+ssh support, so the tunnel should
be created and configured using some external tool (ex. PUTTY).
Keith Fetterman wrote:
> Do I need a separate svn client, like TortoiseSVN, installed on my
> Windows XP to be able to use JavaHL 1.4.5?
>> Eclipse 3.3.2:
>> Thanks,
>> Keith
FUDForum. Page generated in 0.03283 seconds
