Home » Language IDEs » Java Development Tools (JDT) » Customize installed JREs
Customize installed JREs [message #244316] Thu, 07 June 2007 06:03 Go to next message
we have several JDKs installed on our system.
It would be great if these JDKs were added automatically to the installed
JREs when a new workspace is created. We already start Eclipse with the
"-pluginCustomization" option to configure other settings, but I didn't
find a way to configure the default installed JREs.
Does someone has an idea how to accomplish this?
regards,
Maarten Coene
Re: Customize installed JREs [message #244507 is a reply to message #244316] Wed, 13 June 2007 12:49 Go to previous messageGo to next message
Originally posted by: jacek.pospychala.pl.ibm.com
Marteen,
looks like there is an extension point doing this -
org.eclipse.jdt.launching.vmInstalls.
All you would have to do is create a new Plug-in project - in the editor
that opens immediately, after creating it,
go to Dependencies tab, add org.eclipse.jdt.launching, and save the file.
Then in the Extensions tab, add org.eclipse.jdt.launching.vmInstalls
extension and right clicking on it, add new vmInstalls and set
paths to them.
Then export your plugin (in Overview tab) to jar and deliver it together
with whole Eclipse, in plugins/ folder.
Maarten Coene wrote:
> installed JREs when a new workspace is created. We already start
> Eclipse with the "-pluginCustomization" option to configure other
> settings, but I didn't find a way to configure the default installed
> JREs.
> regards,
> Maarten Coene
Re: Customize installed JREs [message #1140187 is a reply to message #244507] Wed, 16 October 2013 03:29 Go to previous message
Resulting plugin.xml may look like:
<?eclipse version="3.4"?>
<plugin>
	<extension point="org.eclipse.jdt.launching.vmInstalls">
		<vmInstall home="${eclipse_home}/jdk6/" id="AddRscWorkspaceVMs.jdk6" name="jdk6"
			vmInstallType="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType">
		</vmInstall>
		<vmInstall home="${eclipse_home}/jdk7/" id="AddRscWorkspaceVMs.jdk7" name="jdk7"
		</vmInstall>
		<vmInstall home="C:/Program Files (x86)/RscApplications/JreEnv/ventura/was/thinClient/java/" id="AddRscWorkspaceVMs.ventura"
			name="ventura" vmInstallType="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType">
		</vmInstall>
	</extension>
</plugin>
with following manifest.mf
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: AddRscWorkspaceVMs
Bundle-SymbolicName: build-eclipse-standard-version-config-plugin;singleton:=true
Bundle-Version: 1.0.0
Require-Bundle: org.eclipse.jdt.launching,
 org.eclipse.jdt.core,
 org.eclipse.jdt
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Export as plugin and add it to your eclipse/dropins folder and you will receive pre-installed java-vms which appear as "(locked)" ones in the Window Preferences Installed JREs.
Previous Topic:define new Proposal Kind in the content assist
Next Topic:Eclipse IDE for C/C++ Developers -> Download JDT
Current Time: Thu Jul 17 20:50:58 EDT 2025
Powered by FUDForum. Page generated in 0.08106 seconds
