Home » Archived » XML Schema Definition (XSD) » getting elements
getting elements [message #24001] Tue, 24 June 2003 04:12 Go to next message
Originally posted by: rsb.ppi.de
Hi there,
I am looking for a method to extract the names of elements.
With
--- Begin Code ---
public static void printElement(XSDSchema xsdSchema) {
System.err.println("--- P R I N T E L E M E N T");
for (Iterator iter = xsdSchema.getElementDeclarations().iterator();
iter.hasNext();
/*no-op */
System.out.println(iter.next());
--- End Code ---
I recive this output
org.eclipse.xsd.impl.XSDElementDeclarationImpl@c791b9 (element: [xs:element:
null])
(name: b_Element, targetNamespace: http://www.fints.org/composer/)
(value: null, constraint: <unset>, form: qualified, lexicalValue: null)
(nillable: <unset>, disallowedSubstitutions: [],
substitutionGroupExclusions: [], abstract: <unset>, lexicalFinal: [], block:
But I want the element name (here: b_Element), only.
Cheers
Rene
Re: getting elements [message #24036 is a reply to message #24001] Tue, 24 June 2003 08:14 Go to previous messageGo to next message
Rene,
Cast the result of next() to XSDElementDeclaration and call getName.
Rene Schrader-Boelsche wrote:
> Hi there,
> With
> --- Begin Code ---
> iter.hasNext();
> /*no-op */
> --- End Code ---
> null])
> Cheers
> Rene
Re: getting elements [message #24066 is a reply to message #24036] Tue, 24 June 2003 08:18 Go to previous message
Thanx for the (very) quick help.
Rene
Re: getting elements [message #573419 is a reply to message #24001] Tue, 24 June 2003 08:14 Go to previous message
Rene,
> Hi there,
> With
> --- Begin Code ---
> iter.hasNext();
> /*no-op */
> --- End Code ---
> null])
> Cheers
> Rene
Re: getting elements [message #573459 is a reply to message #24036] Tue, 24 June 2003 08:18 Go to previous message
Rene
Previous Topic:getting elements
Next Topic:Help on Adding Identity Constraint to an element
Current Time: Mon Jul 21 21:04:42 EDT 2025
Powered by FUDForum. Page generated in 0.04484 seconds
