Home » Eclipse Projects » Eclipse Platform » Showing only one editor
Showing only one editor [message #23969] Wed, 30 April 2003 10:50 Go to next message
Originally posted by: kgc.rsssolutions.com
I can open several editors with only one in focus for a particulat
TreeObject.
How to I ensure only one is opened?
Kevin
Re: Showing only one editor [message #24070 is a reply to message #23969] Wed, 30 April 2003 11:25 Go to previous messageGo to next message
Originally posted by: simon.ibm.oti.lab
How are you opening the editor? That is, what API are you using? What is the
editor input?
If you are using the IWorkbenchPage.openEditor api, then it will look for an
exising open editor whose input equals the passed in editor input. If found,
the editor is brought to the top and no new editor is open. So your editor
input should implement the equals method.
Simon :-)
"Kevin Crocker" <kgc@rsssolutions.com> wrote in message
news:b8onse$51f$1@rogue.oti.com...
> TreeObject.
> Kevin
Re: Showing only one editor [message #24373 is a reply to message #24070] Wed, 30 April 2003 12:57 Go to previous messageGo to next message
Ok, I think I am doing it all wrong.
I have objects in a tree which I populate an EditorInput object with. And
with this new EditorInput I am using the IWorkbenchPage.openEditor but ,of
course, it is a new object even when I select the same object from the tree.
Are there any good examples of using editors?
"Simon Arsenault" <simon@ibm.oti.lab> wrote in message
news:b8opt8$74r$1@rogue.oti.com...
the
> editor input?
an
found,
> Simon :-)
> > TreeObject.
> > Kevin
Re: Showing only one editor [message #24697 is a reply to message #24373] Wed, 30 April 2003 13:29 Go to previous messageGo to next message
Do you mean the exists method? How would I implement that?
news:b8ov9r$bnc$1@rogue.oti.com...
tree.
> the
> > editor input?
for
> an
> found,
editor
> > Simon :-)
> > > TreeObject.
> > > Kevin
Re: Showing only one editor [message #24776 is a reply to message #24697] Wed, 30 April 2003 14:29 Go to previous messageGo to next message
I'm assuming you have your own implementation of IEditorInput? If so, then
you only need to add the equals method on it. Here is what we do in the
FileEditorInput class:
* The <code>FileEditorInput</code> implementation of this
<code>Object</code>
* method bases the equality of two <code>FileEditorInput</code> objects on
the
* equality of their underlying <code>IFile</code> resources.
public boolean equals(Object obj) {
if (this == obj)
return true;
if (!(obj instanceof FileEditorInput))
return false;
FileEditorInput other = (FileEditorInput)obj;
return file.equals(other.file);
Simon :-)
news:b8p15v$ddd$1@rogue.oti.com...
And
,of
> tree.
is
> > the
> > > editor input?
> for
> > an
> > found,
> editor
> > > Simon :-)
> > > > TreeObject.
> > > > Kevin
Re: Showing only one editor [message #26535 is a reply to message #24776] Thu, 01 May 2003 14:54 Go to previous messageGo to next message
Worked great.
Hey Simon, Do you know if any training course occuring in Canada or if
there are consultants that would come to a corporate office to do in-house
training.
news:b8p4me$gir$1@rogue.oti.com...
> <code>Object</code>
on
> the
> if (this == obj)
> return true;
> return false;
> Simon :-)
> And
> ,of
> > tree.
What
> is
> > > the
> > > > editor input?
look
> > for
> > > an
If
> > > found,
> > editor
> > > > Simon :-)
> > > > > TreeObject.
> > > > > Kevin
Re: Showing only one editor [message #26821 is a reply to message #26535] Thu, 01 May 2003 16:31 Go to previous message
Not that I'm aware of. You may want to post a new message for this
question...maybe someone else on the forum would have an answer for you.
Simon :-)
news:b8rqhs$cen$1@rogue.oti.com...
> Worked great.
> training.
then
> > <code>Object</code>
> on
> > the
> > if (this == obj)
> > return true;
> > return false;
> > Simon :-)
with.
> > And
but
> > ,of
the
> > > tree.
> What
> > is
> > > > the
> > > > > editor input?
> look
> > > for
> > > > an
> If
> > > > found,
your
> > > editor
> > > > > Simon :-)
particulat
> > > > > > TreeObject.
> > > > > > Kevin
Previous Topic:Updating Changes to a object in a TreeViewer
Next Topic:What java command is run when the eclipse.exe file is run?
Current Time: Sat Jul 26 14:00:54 EDT 2025
Powered by FUDForum. Page generated in 0.05057 seconds
