Home » Eclipse Projects » Nebula » Examples
Examples [message #2045] |
Wed, 17 May 2006 11:32  |
I can see from the home page that you have some example code for how to
use this widget. I have been unsuccessful in trying to find it however
and was wondering if you could point me in the right direction.
Drew
Re: Examples [message #3552 is a reply to message #3519] |
Wed, 31 May 2006 09:41   |
Yes that picture is definitely the Grid. I don't have that code handy.
Its not very exciting code anyway. Generally Grid is designed to
match the SWT Table's API. The are differences but rather few. For
example, the Grid can function without any selection highlighting and
therefore you *must* pass either SWT.SINGLE or SWT.MULTI or no selection
highlighting will occur. The normal Table defaults to SWT.SINGLE.
Some of the other features visible in that screenshot that might not
exist in Table:
Column Groups:
Create a GridColumnGroup and create columns as children of it. If you
want the group to be collapsible, use the SWT.TOGGLE style in the
constructor of GridColumnGroup and set the detail/summary properties on
the individual columns.
Checkboxes in multiple cols:
Grid doesn't utilize the SWT.CHECK style in the main constructor, but
rather in individual column constructors, allowing checkbox per col.
Column spanning:
GridItem.setColumnSpan()
Hierarchical:
Creating items as children of other items as you would with a Tree. Set
one column as the 'tree' column (i.e. shows the toggle) by calling
GridColumn.setTree(true).
There will be examples and snippets (and better javadoc) as the project
progresses.
-Chris
Daniel wrote:
> Hi there,
> From what I've seen of the Grid so far and what I've been able to
> deduce from the source code, this has the makings of a great Table
> extension (of which I am in some need :-P). I can't wait to see some
> samples. Just out of curiosity, was the screenshot on the Grid homepage
> actually done using the widget itself, and if so, is that code available
> anywhere? Thanks so much!
> - Daniel
Re: Examples [message #3646 is a reply to message #3552] |
Wed, 31 May 2006 16:17   |
Originally posted by: steve_northover.ca.ibm.com
Hi Chris,
Some thoughts ...
"Chris Gross" <chris.gross@us.ibm.com> wrote in message
news:e5k6ec$f07$1@utils.eclipse.org...
I know this is a better API but given that the native table has shipped and
doesn't
work this way means that this sort of difference will be an unexpected
annoyance.
A better solution might be to add an API to get rid of the selection. The
API
could offer to set the selection mode dynamically or it could just be
something
like "setSelectionEnabled()" or something like that.
> exist in Table:
> Column Groups:
You might consider supporting the SWT.CHECK in the main constructor
too, to be compatible. NOTE: If this turns out to be a lot of pain for
some
reason, then don't consider it.
> Column spanning:
> Hierarchical:
> progresses.
> -Chris
> Daniel wrote:
> > Hi there,
> > - Daniel
Re: Examples [message #3679 is a reply to message #3646] |
Thu, 01 June 2006 09:40   |
Those changes definitely sound reasonable. I'll add them to the next
update.
-Chris
Steve Northover wrote:
> Hi Chris,
> Some thoughts ...
> doesn't
> annoyance.
> API
> something
>> exist in Table:
>> Column Groups:
> some
>> Column spanning:
>> Hierarchical:
>> progresses.
>> -Chris
>> Daniel wrote:
>>> Hi there,
>>> - Daniel
Re: Examples [message #3711 is a reply to message #3679] |
Fri, 02 June 2006 11:19   |
My rule of thumb is that style bits and API that are the same as a similar
control should work the same, even if the new usage is "better" (like your
changes are). Being able to substitute one widget for another or have a new
widget work the same way as one you already understand is valuable. Of
course, common sense overrides everything. For example, if it requires a
ton of code to be compatible or the implementation becomes a nightmare then
the rule goes out the window.
news:e5mqo3$jj4$1@utils.eclipse.org...
> update.
> -Chris
> > Hi Chris,
> > Some thoughts ...
selection
and
> > doesn't
> > annoyance.
The
> > API
> > something
> >> exist in Table:
> >> Column Groups:
> > some
> >> Column spanning:
> >> Hierarchical:
Set
> >> progresses.
> >> -Chris
> >> Daniel wrote:
> >>> Hi there,
homepage
available
> >>> - Daniel
Re: Examples [message #4032 is a reply to message #3711] |
Fri, 02 June 2006 15:26  |
Sounds good. Consistency is very valuable and in Nebula we aren't
trying to necessarily invent new paradigms.
-Chris
>> update.
>> -Chris
>>> Hi Chris,
>>> Some thoughts ...
> selection
> and
>>> doesn't
>>> annoyance.
> The
>>> API
>>> something
>>>> exist in Table:
>>>> Column Groups:
>>> some
>>>> Column spanning:
>>>> Hierarchical:
> Set
>>>> progresses.
>>>> -Chris
>>>> Daniel wrote:
>>>>> Hi there,
> homepage
> available
>>>>> - Daniel
Re: Examples [message #561435 is a reply to message #2045] |
Wed, 17 May 2006 14:39  |
"Grid"-widget-Example: http://www.eclipse.org/nebula
related source is found in cvs
(host: dev.eclipse.org, repository path: /cvsroot/technology, user:
anonymous, con type: pserver)
head: org.eclipse.swt.nebula
michael
"Andrew Elegante" <aelegante@qcomm.com> schrieb im Newsbeitrag
news:3b944325a6fa4b2f0fbbfdf5c8a7f862$1@www.eclipse.org...
> Drew
Re: Examples [message #561518 is a reply to message #2045] |
Thu, 18 May 2006 11:13  |
Hi Drew,
I hope to have an example plugin soon.
-Chris
Andrew Elegante wrote:
> Drew
Re: Examples [message #561757 is a reply to message #2060] |
Thu, 25 May 2006 14:46  |
I found the source of the grid in the repository, but no sample code.
Did I overlook something?
Martin
Re: Examples [message #561814 is a reply to message #2113] |
Tue, 30 May 2006 16:14  |
Hi there,
- Daniel
Re: Examples [message #561835 is a reply to message #3519] |
exist in Table:
Column Groups:
Column spanning:
Hierarchical:
progresses.
-Chris
Daniel wrote:
> Hi there,
> - Daniel
Re: Examples [message #561904 is a reply to message #3552] |
Hi Chris,
Some thoughts ...
doesn't
annoyance.
API
something
> exist in Table:
> Column Groups:
some
> Column spanning:
> Hierarchical:
> progresses.
> -Chris
> Daniel wrote:
> > Hi there,
> > - Daniel
Re: Examples [message #561926 is a reply to message #3646] |
update.
-Chris
> Hi Chris,
> Some thoughts ...
> doesn't
> annoyance.
> API
> something
>> exist in Table:
>> Column Groups:
> some
>> Column spanning:
>> Hierarchical:
>> progresses.
>> -Chris
>> Daniel wrote:
>>> Hi there,
>>> - Daniel
Re: Examples [message #561949 is a reply to message #3679] |
> update.
> -Chris
> > Hi Chris,
> > Some thoughts ...
selection
and
> > doesn't
> > annoyance.
The
> > API
> > something
> >> exist in Table:
> >> Column Groups:
> > some
> >> Column spanning:
> >> Hierarchical:
Set
> >> progresses.
> >> -Chris
> >> Daniel wrote:
> >>> Hi there,
homepage
available
> >>> - Daniel
Re: Examples [message #561971 is a reply to message #3711] |
-Chris
>> update.
>> -Chris
>>> Hi Chris,
>>> Some thoughts ...
> selection
> and
>>> doesn't
>>> annoyance.
> The
>>> API
>>> something
>>>> exist in Table:
>>>> Column Groups:
>>> some
>>>> Column spanning:
>>>> Hierarchical:
> Set
>>>> progresses.
>>>> -Chris
>>>> Daniel wrote:
>>>>> Hi there,
> homepage
> available
>>>>> - Daniel
Current Time: Sat Jul 26 03:06:45 EDT 2025
Powered by FUDForum. Page generated in 0.05453 seconds
