Home » Language IDEs » ServerTools (WTP) » Sysdeo Plugin on OS X
Sysdeo Plugin on OS X [message #23942] Thu, 20 May 2004 14:16 Go to next message
Originally posted by: robwms63.yahoo.com
I had not been able to get it working. I would try and start Tomcat and
it would fail, but nothing came into the console (when I start Tomcat
from the command line it tells me that only root can see the console).
Finally, I generated a run configuration, went in and tried to run it
from there and it gave me an error: tools.jar not found. Then I found an
article on apple.com about how their JDK doesn't have a tools.jar, so I
removed it and the server started. Now, it isn't working, as soon as I
start, it just shows 'terminated' in the debugger.
Questions:
Where are the errors going? If I start Tomcat from the command line, the
log files in /Tomcat/Home/logs does get updated. When I start from
inside Eclipse, nothing....
Re: Sysdeo Plugin on OS X [message #24130 is a reply to message #23942] Fri, 21 May 2004 10:39 Go to previous message
Originally posted by: default.Bruno.com
Someone send me this, maybe it will help you :
"On OS X, in order to get tomcat running in eclipse using ur plugin, you have to
add "-server" to the JVM parameters section, otherwise you will get the
ClassNotFoundException error..."
Bruno
> Questions:
Previous Topic:How to upload to FTP team Server with a shortcut?
Next Topic:Commitment to participate
Current Time: Fri Sep 05 21:12:01 EDT 2025
Powered by FUDForum. Page generated in 0.03804 seconds
