Home » Eclipse Projects » Subversive » Ganymede Subversive - Compare/Replace with version from Repository
Ganymede Subversive - Compare/Replace with version from Repository [message #23931] Wed, 02 July 2008 14:42 Go to next message
Does the Subversive plugin have the capability to Compare/Replace with ...
-> Version from Repository?
If I have a specific version of a file and I want to compare/replace it
with a previous versions, how is the best way of doing this?
Thanks.
Re: Ganymede Subversive - Compare/Replace with version from Repository [message #24120 is a reply to message #23931] Thu, 03 July 2008 04:27 Go to previous message
Originally posted by: alexander.gurov.polarion.org
Yes, the Subversive plug-in provides corresponding functionality.
Compare with a version from repository could be done by using "Compare
With->URL..." action.
Replace with a version from repository could be done by using "Replace
Another way to perform these operations is to use History View's pop-up
menu actions when History View is attached to resource which you want to
compare or replace with the specific revision.
Previous Topic:strange error on commit
Next Topic:Getting javahl 1.4.5 to work on windows xp
Current Time: Mon Jul 21 21:24:09 EDT 2025
Powered by FUDForum. Page generated in 0.08344 seconds
