Error messges in the log [message #243638] |
Wed, 19 December 2007 12:06 |
Originally posted by: brucer.norova.com
I posted this last week in the CDT project group but didn't get a
response. I would appreciate anyone's ideas about this........
I extracted "eclipse-cpp-europa-fall2-linux-gtk.tar.gz" into /usr/lib and
crated a link to the eclipse ecxecutable in /usr/bin. I ran eclipse as
root and as a user. Both worked - at least - for the hello world
application. However, the log files for these runs report errors (more in
the user log than the root log). They seem to have something to do with
"read error" or "unable to create" for various files. I am running Ubuntu
7.10.
Any ideas about what is causing these errors and how to eliminate them?
Bruce
The log file when running as
root is:
!SESSION 2007-12-14 17:36:15.691
eclipse.buildId=M20071023-1652
java.version=1.6.0_03
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.debug.core 4 120 2007-12-14 17:39:19.671
!MESSAGE Error logged from Debug Core: !STACK 0
java.io.IOException: read error
at org.eclipse.cdt.utils.spawner.SpawnerInputStream.read0(Nativ e Method)
org.eclipse.cdt.utils.spawner.SpawnerInputStream.read(Spawne rInputStream.java:60)
at java.io.BufferedInputStream.read1(BufferedInputStream.java:2 56)
at java.io.BufferedInputStream.read(BufferedInputStream.java:31 7)
at java.io.FilterInputStream.read(FilterInputStream.java:90)
org.eclipse.debug.internal.core.OutputStreamMonitor.read(Out putStreamMonitor.java:144)
org.eclipse.debug.internal.core.OutputStreamMonitor.access$1 (OutputStreamMonitor.java:134)
org.eclipse.debug.internal.core.OutputStreamMonitor$1.run(Ou tputStreamMonitor.java:207)
at java.lang.Thread.run(Thread.java:619)
The log file when
running as a user is:
!SESSION 2007-12-14 17:52:35.283
!ENTRY org.eclipse.osgi 4 0 2007-12-14 17:52:35.658
!MESSAGE Error reading configuration:
/usr/lib/eclipse/configuration/org.eclipse.osgi/.manager/.fi leTableLock
(Permission denied)
!STACK 0
java.io.FileNotFoundException:
(Permission denied)
at java.io.RandomAccessFile.open(Native Method)
at java.io.RandomAccessFile.<init>(RandomAccessFile.java:212)
org.eclipse.core.runtime.internal.adaptor.Locker_JavaNio.loc k(Locker_JavaNio.java:32)
org.eclipse.osgi.storagemanager.StorageManager.lock(StorageM anager.java:388)
org.eclipse.osgi.storagemanager.StorageManager.open(StorageM anager.java:695)
org.eclipse.osgi.internal.baseadaptor.BaseStorage.initFileMa nager(BaseStorage.java:162)
org.eclipse.osgi.internal.baseadaptor.BaseStorage.initialize (BaseStorage.java:139)
org.eclipse.osgi.baseadaptor.BaseAdaptor.initializeStorage(B aseAdaptor.java:124)
org.eclipse.osgi.framework.internal.core.Framework.initializ e(Framework.java:174)
org.eclipse.osgi.framework.internal.core.Framework.<init>(Framework.java:147)
org.eclipse.osgi.framework.internal.core.OSGi.createFramewor k(OSGi.java:90)
at org.eclipse.osgi.framework.internal.core.OSGi.<init>(OSGi.java:31)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:283)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:172)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
!ENTRY org.eclipse.update.configurator 2007-12-14 17:52:36.775
!MESSAGE
/usr/lib/eclipse/configuration/org.eclipse.update/last.confi g.stamp
(Permission denied)
!ENTRY org.eclipse.osgi 4 0 2007-12-14 17:53:06.684
!MESSAGE !STACK 0
java.io.IOException: Permission denied
at java.io.UnixFileSystem.createFileExclusively(Native Method)
at java.io.File.checkAndCreate(File.java:1704)
at java.io.File.createTempFile(File.java:1793)
org.eclipse.osgi.storagemanager.StorageManager.createTempFil e(StorageManager.java:721)
org.eclipse.osgi.storagemanager.StorageManager.getOutputStre am(StorageManager.java:783)
org.eclipse.osgi.internal.baseadaptor.BaseStorage.saveBundle Datas(BaseStorage.java:489)
org.eclipse.osgi.internal.baseadaptor.BaseStorage.saveAllDat a(BaseStorage.java:382)
org.eclipse.osgi.internal.baseadaptor.BaseStorage.access$1(B aseStorage.java:372)
org.eclipse.osgi.internal.baseadaptor.BaseStorage$StateSaver .run(BaseStorage.java:1115)
!ENTRY org.eclipse.osgi 4 0 2007-12-14 17:53:06.685
!MESSAGE !STACK 0
org.eclipse.osgi.internal.baseadaptor.BaseStorage.saveStateD ata(BaseStorage.java:539)
org.eclipse.osgi.internal.baseadaptor.BaseStorage.saveAllDat a(BaseStorage.java:383)
!ENTRY org.eclipse.equinox.preferences 4 4 2007-12-14 17:53:12.548
!MESSAGE Exception saving preferences to:
/usr/lib/eclipse/configuration/.settings/org.eclipse.ui.ide. prefs.
!STACK 0
(Permission denied)
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(FileOutputStream.java:179)
at java.io.FileOutputStream.<init>(FileOutputStream.java:102)
org.eclipse.core.internal.preferences.EclipsePreferences.sav e(EclipsePreferences.java:983)
org.eclipse.core.internal.preferences.EclipsePreferences.sav e(EclipsePreferences.java:953)
org.eclipse.core.internal.preferences.EclipsePreferences.flu sh(EclipsePreferences.java:352)
org.eclipse.ui.internal.ide.ChooseWorkspaceData.writePersist edData(ChooseWorkspaceData.java:236)
org.eclipse.ui.internal.ide.application.IDEApplication.check InstanceLocation(IDEApplication.java:226)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:92)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
!ENTRY org.eclipse.osgi 4 0 2007-12-14 17:53:55.825
!MESSAGE !STACK 0
org.eclipse.osgi.internal.baseadaptor.BaseStorage.frameworkS top(BaseStorage.java:772)
org.eclipse.osgi.baseadaptor.BaseAdaptor.frameworkStop(BaseA daptor.java:273)
org.eclipse.osgi.framework.internal.core.SystemBundleActivat or.stop(SystemBundleActivator.java:64)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$3 .run(BundleContextImpl.java:1040)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:1036)
org.eclipse.osgi.framework.internal.core.StartLevelManager.s uspendAllBundles(StartLevelManager.java:705)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ecFWSL(StartLevelManager.java:658)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:291)
org.eclipse.osgi.framework.internal.core.StartLevelManager.s hutdown(StartLevelManager.java:261)
org.eclipse.osgi.framework.internal.core.SystemBundle.suspen d(SystemBundle.java:188)
org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:622)
org.eclipse.osgi.framework.internal.core.Framework.close(Fra mework.java:525)
at org.eclipse.osgi.framework.internal.core.OSGi.close(OSGi.jav a:41)
org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(Ecl ipseStarter.java:399)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:197)
!ENTRY org.eclipse.osgi 4 0 2007-12-14 17:53:55.826
!MESSAGE !STACK 0
FUDForum. Page generated in 0.19726 seconds
