Home » Eclipse Projects » DSDP - Target Management » RXTX terminal connection on solaris
RXTX terminal connection on solaris [message #23926] Tue, 03 June 2008 09:19 Go to next message
Hello
I'm using rxtx v 2.1.7.4 terminal serial connection on Solaris. My serial
port is /dev/cua/a.
The target succesfully connects to the port after creating new connection
configuration and can be closed with the "Disconnect" button in the
Teerminal view.
It says "CLOSED" at the top status line.
I'm worried, that the target fails to reconnect with the "Connect" button
in the Terminal view,
writing "No such port: /dev/cua/a"
But this port exists and is free. I can check it with fuser command. I can
connect with the tip command.
It is connecting after several times trying. I clicked "Connect" 9 times.
There is an option to change timeout, but it doesn't help.
Could it be ,that it doesn't disconnect?
Thanks for the help,
Dina
Re: RXTX terminal connection on solaris [message #24218 is a reply to message #23926] Tue, 01 July 2008 12:32 Go to previous message
FYI,
this is now tracked in https://bugs.eclipse.org/bugs/show_bug.cgi?id=236319
The bug might be in RXTX or the Solaris Kernel.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Dina wrote:
> Hello
> serial port is /dev/cua/a.
> connection configuration and can be closed with the "Disconnect" button
> in the Teerminal view.
> button in the Terminal view,
> can connect with the tip command.
> times. There is an option to change timeout, but it doesn't help.
> Best regards,
> Dina
Re: RXTX terminal connection on solaris [message #575548 is a reply to message #23926] Tue, 01 July 2008 12:32 Go to previous message
FYI,
Dina wrote:
> Hello
> Best regards,
> Dina
Previous Topic:Copy local file to remote while maintaining directory structure
Next Topic:Automatic TerminalView Connection
Current Time: Mon Jul 21 21:06:31 EDT 2025
Powered by FUDForum. Page generated in 0.05430 seconds
