Home » Archived » BIRT » Problems getting BIRT 2.2 to run in eclipse 3.2
Problems getting BIRT 2.2 to run in eclipse 3.2 [message #243453] |
Wed, 20 June 2007 04:09  |
Originally posted by: Bernd.Laengerich.web.de
I downloaded eclipse 3.2.2 and installed BIRT 2.2
(2.2.0.v20070529-7K7K...) from the update manager. The configuration
shows no problem, however trying to load the designer eclipse
complains in the error log (see below). Any hints?
Bernd
..log:
eclipse.buildId=M20070212-1330
java.version=1.4.2_06
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.jface 4 2 2007-06-20 09:44:10.805
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.jface".
!STACK 0
java.lang.NoClassDefFoundError: org.eclipse.ui.menus.IMenuService
org.eclipse.birt.report.designer.internal.ui.editors.Designe rActionBarContributor.contributeToMenu(DesignerActionBarCont ributor.java:520)
org.eclipse.ui.part.EditorActionBarContributor.init(EditorAc tionBarContributor.java:167)
org.eclipse.gef.ui.actions.ActionBarContributor.init(ActionB arContributor.java:131)
org.eclipse.ui.part.EditorActionBarContributor.init(EditorAc tionBarContributor.java:146)
org.eclipse.birt.report.designer.ui.editors.actions.MultiPag eEditorActionBarContributor$SubActionBarDef.init(MultiPageEd itorActionBarContributor.java:87)
org.eclipse.birt.report.designer.ui.editors.actions.MultiPag eEditorActionBarContributor.setActivePage(MultiPageEditorAct ionBarContributor.java:187)
org.eclipse.birt.report.designer.ui.editors.AbstractMultiPag eEditor.updateActionBarContributor(AbstractMultiPageEditor.j ava:51)
org.eclipse.birt.report.designer.ui.editors.AbstractMultiPag eEditor.pageChange(AbstractMultiPageEditor.java:29)
org.eclipse.birt.report.designer.ui.editors.MultiPageReportE ditor.pageChange(MultiPageReportEditor.java:631)
org.eclipse.ui.forms.editor.FormEditor.setActivePage(FormEdi tor.java:596)
org.eclipse.birt.report.designer.ui.editors.MultiPageReportE ditor.setActivePage(MultiPageReportEditor.java:1121)
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:280)
org.eclipse.birt.report.designer.ui.editors.ReportEditorProx y.createPartControl(ReportEditorProxy.java:121)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:596)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:214)
org.eclipse.ui.internal.WorkbenchPage.makeActiveEditor(Workb enchPage.java:1168)
org.eclipse.ui.internal.WorkbenchPage.updateActivePart(Workb enchPage.java:1126)
org.eclipse.ui.internal.WorkbenchPage.partAdded(WorkbenchPag e.java:1531)
org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:210)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:822)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:721)
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:682)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2593)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2528)
org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2520)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2505)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2500)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2485)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:388)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:350)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileActio n.java:98)
org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystem EditorAction.java:98)
org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAct ion(OpenActionGroup.java:125)
org.eclipse.ui.views.navigator.MainActionGroup.runDefaultAct ion(MainActionGroup.java:328)
org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen( ResourceNavigator.java:679)
org.eclipse.ui.views.navigator.ResourceNavigator$6.open(Reso urceNavigator.java:434)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:817)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:843)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:815)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1069)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1168)
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:249)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:243)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:283)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1930)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:422)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
configuration:
*** Date: Wed Jun 20 10:06:53 CEST 2007
*** Platform Details:
*** System properties:
RUN_UNDER_ECLIPSE=false
awt.toolkit=sun.awt.windows.WToolkit
birt.viewer.working.path=C:\Entwicklung\.metadata\.plugins\o rg.eclipse.birt.report.viewer
catalina.base=/C:/Programme/eclipse32/plugins/org.eclipse.to mcat_4.1.130.v20060601/
catalina.home=/C:/Programme/eclipse32/plugins/org.eclipse.to mcat_4.1.130.v20060601/
catalina.useNaming=true
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
C:\Programme\eclipse32\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
578_50
-vm
C:\WINNT\system32\javaw.exe
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1182326230987
eclipse.vm=C:\WINNT\system32\javaw.exe
eclipse.vmargs=-Xmx256m
-jar
C:\Programme\eclipse32\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\Programme\eclipse32\startup.jar
java.class.version=48.0
java.endorsed.dirs=C:\Programme\Java\j2re1.4.2_06\lib\endors ed
java.ext.dirs=C:\Programme\Java\j2re1.4.2_06\lib\ext
java.home=C:\Programme\Java\j2re1.4.2_06
java.io.tmpdir=C:\DOKUME~1\blh\LOKALE~1\Temp\
java.library.path=C:\WINNT\system32;.;C:\WINNT\system32;C:\W INNT;c:\programme\imagemagick-6.3.3-q16;C:\Programme\MiKTeX
2.6\miktex\bin;C:\Programme\Perl\bin\;C:\WINNT\system32;C:\W INNT;C:\WINNT\System32\Wbem;C:\Programme\NMapWin\\bin;c:\pro gramme\gnu\wincvs
1.3\;C:\Programme\Microsoft SQL
Server\80\Tools\BINN;c:\Programme\Java\J2SDK1.4.2_06\bin;C:\ Programme\Gemeinsame
Dateien\GTK\2.0\bin;c:\Programme\apache-ant-1.5.2\bin;c:\Pro gramme\Java\Jikes-1.18\bin;c:\cygwin\bin;C:\Programme\CVSNT\
java.naming.factory.initial=org.apache.naming.java.javaURLCo ntextFactory
java.naming.factory.url.pkgs=org.apache.naming
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.2_06-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.WindowsPr eferencesFactory
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_06-b03
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSG i/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4
org.osgi.framework.language=de
org.osgi.framework.os.name=Windows2000
org.osgi.framework.os.version=5.0
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imag eio,javax.imageio.event,javax.imageio.metadata,javax.imageio .plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.n aming,javax.naming.directory,javax.naming.event,javax.naming .ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,j avax.print.attribute,javax.print.attribute.standard,javax.pr int.event,javax.rmi,javax.rmi.CORBA,javax.security.auth,java x.security.auth.callback,javax.security.auth.kerberos,javax. security.auth.login,javax.security.auth.spi,javax.security.a uth.x500,javax.security.cert,javax.sound.midi,javax.sound.mi di.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.table,javax.swing.text,javax.swing.text.htm l,javax.swing.text.html.parse
r,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,jav ax.transaction,javax.transaction.xa,javax.xml.parsers,javax. xml.transform,javax.xml.transform.dom,javax.xml.transform.sa x,javax.xml.transform.stream,org.ietf.jgss,org.omg.CORBA,org .omg.CORBA_2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynA nyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,or g.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNam ing.NamingContextExtPackage,org.omg.CosNaming.NamingContextP ackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny .DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.o mg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPack age,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.Po rtableInterceptor.ORBInitInfoPackage,org.omg.PortableServer, org.omg.PortableServer.CurrentPackage,org.omg.PortableServer .POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg .PortableServer.portable,org.omg.PortableServer.ServantLocat orPackage,org.omg.SendingConte
xt,org.omg.stub.java.rmi,org.w3c.dom,org.xml.sax,org.xml.sax .ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows 2000
os.version=5.0
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start,
org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=C:\Programme\eclipse32\configuration\org.ec lipse.osgi\bundles
osgi.configuration.area=file:/C:/Programme/eclipse32/configu ration/
osgi.framework=file:/c:/Programme/eclipse32/plugins/org.ecli pse.osgi_3.2.2.R32x_v20070118.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.2.R32x_v20070118
osgi.install.area=file:/C:/Programme/eclipse32/
osgi.instance.area=file:/C:/Entwicklung/
osgi.instance.area.default=file:/C:/Dokumente und
Einstellungen/blh/workspace/
osgi.logfile=C:\Entwicklung\.metadata\.log
osgi.manifest.cache=C:\Programme\eclipse32\configuration\org .eclipse.osgi\manifests
osgi.nl=de_DE
osgi.os=win32
osgi.splashLocation=c:\Programme\eclipse32\plugins\org.eclip se.platform_3.2.2.r322_v20070117b\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=c:\Programme\eclipse32\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Programme\Java\j2re1.4.2_06\lib\rt.ja r;C:\Programme\Java\j2re1.4.2_06\lib\i18n.jar;C:\Programme\J ava\j2re1.4.2_06\lib\sunrsasign.jar;C:\Programme\Java\j2re1. 4.2_06\lib\jsse.jar;C:\Programme\Java\j2re1.4.2_06\lib\jce.j ar;C:\Programme\Java\j2re1.4.2_06\lib\charsets.jar;C:\Progra mme\Java\j2re1.4.2_06\classes
sun.boot.library.path=C:\Programme\Java\j2re1.4.2_06\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium i486 i386
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.os.patch.level=Service Pack 4
user.country=DE
user.dir=C:\Programme\eclipse32
user.home=C:\Dokumente und Einstellungen\blh
user.language=de
user.name=blh
user.timezone=Europe/Berlin
user.variant=
workspace.projectclasspath=/C:/BirtReportPlugin/lib/charteng ineapi.jar;/C:/BirtReportPlugin/lib/com.ibm.icu_3.4.5.200612 13.jar;/C:/BirtReportPlugin/lib/commons-cli-1.0.jar;/C:/Birt ReportPlugin/lib/commons-codec-1.3.jar;/C:/BirtReportPlugin/ lib/coreapi.jar;/C:/BirtReportPlugin/lib/dataadapterapi.jar; /C:/BirtReportPlugin/lib/dteapi.jar;/C:/BirtReportPlugin/lib /engineapi.jar;/C:/BirtReportPlugin/lib/flute.jar;/C:/BirtRe portPlugin/lib/js.jar;/C:/BirtReportPlugin/lib/modelapi.jar; /C:/BirtReportPlugin/lib/org.eclipse.emf.common_2.2.1.v20070 2131851.jar;/C:/BirtReportPlugin/lib/org.eclipse.emf.ecore_2 .2.2.v200702131851.jar;/C:/BirtReportPlugin/lib/org.eclipse. emf.ecore.xmi_2.2.2.v200702131851.jar;/C:/BirtReportPlugin/l ib/sac.jar;/C:/BirtReportPlugin/lib/scriptapi.jar;C:\Entwick lung\BirtReportPlugin\bin;/C:/accept/lib/jpos-1.4.8.jar;/C:/ acframework/lib/db-ojb-1.0.4.jar;/C:/acframework/lib/commons -lang-2.1.jar;C:\Entwicklung\CutoverPlugin\bin;/C:/acframewo rk/lib/db-ojb-1.0.4.jar;/C:/a
ccept/lib/jpos-1.4.8.jar;/C:/acframework/lib/commons-beanuti ls-1.7.0.jar;/C:/acframework/lib/commons-collections-3.1.jar ;/C:/acframework/lib/commons-dbcp-1.2.1.jar;/C:/acframework/ lib/commons-lang-2.1.jar;/C:/acframework/lib/commons-logging -1.0.4.jar;/C:/acframework/lib/commons-pool-1.2.jar;C:\Entwi cklung\DBDebugLogPlugin\bin;/C:/accept/lib/jpos-1.4.8.jar;/C :/acframework/lib/db-ojb-1.0.4.jar;/C:/acframework/lib/commo ns-lang-2.1.jar;C:\Entwicklung\TABackupPlugin\bin;/C:/accept /lib/jpos-1.4.8.jar;C:\Entwicklung\TCSignpad\bin;/C:/accept/ lib/jdom.jar;/C:/accept/lib/mx4j-jmx.jar;/C:/accept/lib/mx4j -tools.jar;/C:/accept/lib/jpos-1.4.8.jar;/C:/accept/lib/mx4j -impl.jar;/C:/accept/lib/tcjavaspy2.jar;/C:/accept/lib/jaxp/ lib/endorsed/dom.jar;/C:/accept/lib/jaxp/lib/jaxp-api.jar;/C :/accept/lib/jaxp/lib/endorsed/sax.jar;/C:/accept/lib/jaxp/l ib/endorsed/xalan.jar;/C:/accept/lib/jaxp/lib/endorsed/xerce sImpl.jar;/C:/accept/lib/jwsdp-shared/lib/activation.jar;/C: /accept/lib/jwsdp-shared/lib/j
aas.jar;/C:/accept/lib/jwsdp-shared/lib/jta-spec1_0_1.jar;/C :/accept/lib/jwsdp-shared/lib/mail.jar;/C:/accept/lib/jaxb/j axb-api.jar;/C:/accept/lib/jaxb/jaxb-impl.jar;/C:/accept/lib /jaxb/jaxb-libs.jar;/C:/accept/lib/jaxb/jaxb-xjc.jar;/C:/acc ept/lib/jaxb/jax-qname.jar;/C:/accept/lib/jaxb/namespace.jar ;/C:/accept/lib/jaxb/relaxngDatatype.jar;/C:/accept/lib/jaxb /xsdlib.jar;/C:/accept/lib/wrapper.jar;/C:/acframework/lib/d b-ojb-1.0.4.jar;/C:/acframework/lib/commons-beanutils-1.7.0. jar;/C:/acframework/lib/commons-collections-3.1.jar;/C:/acfr amework/lib/commons-dbcp-1.2.1.jar;/C:/acframework/lib/commo ns-lang-2.1.jar;/C:/acframework/lib/commons-logging-1.0.4.ja r;/C:/acframework/lib/commons-pool-1.2.jar;/C:/accept/lib/co mmons-httpclient-3.1-beta1.jar;/C:/accept/lib/commons-codec- 1.3.jar;C:\Entwicklung\accept\bin;/C:/acframework/lib/activa tion.jar;/C:/acframework/lib/ant.jar;/C:/acframework/lib/ant lr.jar;/C:/acframework/lib/com-darwinsys-util.jar;/C:/acfram ework/lib/csvjdbc.jar;/C:/acfr
amework/lib/dbunit-2.0.jar;/C:/acframework/lib/dtdparser.jar ;/C:/acframework/lib/exml.jar;/C:/acframework/lib/forms-1.0. jar;/C:/acframework/lib/hsqldb.jar;/C:/acframework/lib/jakar ta-regexp-1.3.jar;/C:/acframework/lib/jcs.jar;/C:/acframewor k/lib/jdbc-se2.0.jar;/C:/acframework/lib/jdo.jar;/C:/acframe work/lib/jdori.jar;/C:/acframework/lib/jta1.0.1.jar;/C:/acfr amework/lib/junit.jar;/C:/acframework/lib/log4j-1.2.8.jar;/C :/acframework/lib/looks-all.jar;/C:/acframework/lib/mail.jar ;/C:/acframework/lib/msbase.jar;/C:/acframework/lib/mssqlser ver.jar;/C:/acframework/lib/msutil.jar;/C:/acframework/lib/O ctopus.jar;/C:/acframework/lib/OctopusGenerator.jar;/C:/acfr amework/lib/OctopusTask.jar;/C:/acframework/lib/optional.jar ;/C:/acframework/lib/prevayler.jar;/C:/acframework/lib/regex p.jar;/C:/acframework/lib/resolver.jar;/C:/acframework/lib/x ercesImpl.jar;/C:/acframework/lib/xml-apis.jar;/C:/acframewo rk/lib/xmljdbc.jar;/C:/acframework/lib/xmlParserAPIs.jar;/C: /acframework/lib/xmlutil.jar;/
C:/acframework/lib/tools.jar;/C:/acframework/lib/db2jcc_lice nse_c.jar;/C:/acframework/lib/db2jcc.jar;/C:/acframework/lib /derby.jar;/C:/acframework/lib/xdoclet-1.2.3.jar;/C:/acframe work/lib/xdoclet-ojb-module-1.2.3.jar;/C:/acframework/lib/xj avadoc-1.1.jar;/C:/acframework/lib/mysql-connector-java-5.0. 0-beta-bin.jar;/C:/acframework/lib/jtds-1.2.jar;/C:/acframew ork/lib/ojdbc14.jar;/C:/acframework/lib/db-ojb-1.0.4.jar;/C: /acframework/lib/commons-beanutils-1.7.0.jar;/C:/acframework /lib/commons-collections-3.1.jar;/C:/acframework/lib/commons -dbcp-1.2.1.jar;/C:/acframework/lib/commons-lang-2.1.jar;/C: /acframework/lib/commons-logging-1.0.4.jar;/C:/acframework/l ib/commons-pool-1.2.jar;/C:/acframework/lib/p6spy-1.3-patche d.jar;C:\Entwicklung\acframework\bin;/C:/jcrontab/lib/ejb-ap i.jar;/C:/acframework/lib/junit.jar;/C:/acframework/lib/log4 j-1.2.8.jar;/C:/acframework/lib/mail.jar;C:\Entwicklung\jcro ntab\bin
*** Features:
com.lowagie.itext (1.5.2.v20070608-041-w31181642) "Lowagie Itext"
org.apache.batik (1.6.0.v20060613-1220-0842282835-3442) "Apache Batik"
org.apache.batik.pdf (1.6.0.v20060613-1220-0842282835-3442) "Bundle-Name"
org.apache.commons.codec (1.3.0.v20070531-02--w31181642) "Apache
Commons Codec"
org.apache.derby.core (10.1.2.1) "Apache Derby Core Plug-in for Eclipse"
org.eclipse.birt (2.2.0.v20070529-7M7M-3aOvPNTlpz0mVkOVvOPYa7n)
"Business Intelligence and Reporting Tools"
org.eclipse.birt.chart (2.2.0.v20070529-7979-2qpGuZWQuAuluBAswz-Np)
"BIRT Chart Framework"
org.eclipse.birt.chart.cshelp (2.2.0.v20070209-11--w31181642) "BIRT
Chart Context-sensitive Help"
org.eclipse.birt.chart.doc.isv (2.2.0.v20070209-11--w31181642) "BIRT
Chart ISV Documentation"
org.eclipse.birt.chart.runtime (2.2.0.v20070614-7Y8l-MxfqtktA_rvyMo)
"BIRT Chart Runtime"
org.eclipse.birt.chart.runtime.source
(2.2.0.v20070614-7Y8l-MxfqtktA_rvyMo) "BIRT Chart Runtime Source"
org.eclipse.birt.chart.source
(2.2.0.v20070529-7979-2qpGuZWQuAuluBAswz-Np) "BIRT Chart Source Plugin"
org.eclipse.birt.crosstab.source (2.2.0.v20070529-33-0r733G3E5A) "BIRT
Source"
org.eclipse.birt.cshelp (2.2.0.v20070209-11--w31181642) "BIRT
org.eclipse.birt.doc (2.2.0.v20070209-11--w31181642) "BIRT Documentation"
org.eclipse.birt.doc.isv (2.2.0.v20070209-11--w31181642) "BIRT ISV
Documentation"
org.eclipse.birt.example (2.2.0.v20070314-7C7C-5SQCCz-CpKo) "BIRT Example"
(2.2.0.v20070604-7U7U-C-Qc-5jceYVXDWutB6) "BIRT Report Designer"
org.eclipse.birt.report.designer.source
(2.2.0.v20070604-7U7U-C-Qc-5jceYVXDWutB6) "BIRT Report Designer Source"
org.eclipse.birt.report.runtime (2.2.0.v20070529-7U7U-Cmz0UWCVtsA5)
"BIRT Report Runtime"
org.eclipse.birt.report.runtime.source
(2.2.0.v20070529-7U7U-Cmz0UWCVtsA5) "BIRT Report Runtime Source Plugin"
org.eclipse.birt.sdk (2.2.0.v20070529-7K7K-5kyOhoXWz0Hga-jCxC7-pHC)
"BIRT SDK"
org.eclipse.birt.source (2.2.0.v20070529-7M7M-3aOvPNTlpz0mVkOVvOPYa7n)
"BIRT Source Plugin"
org.eclipse.cdt (3.1.2.200702150621) "Eclipse C/C++ Development Tools"
org.eclipse.datatools.connectivity.feature (1.0.0.200612201) "Data
Tools Platform Connectivity Plug-in"
org.eclipse.datatools.connectivity.oda.designer.feature
(1.0.0.200612201) "DTP ODA Designer UI Framework Plug-in"
org.eclipse.datatools.connectivity.oda.feature (1.0.0.200612201) "DTP
Open Data Access"
org.eclipse.datatools.doc.user (1.0.0.200612211) "Data Tools Platform
User Guide"
org.eclipse.datatools.enablement.feature (1.0.0.200612201) "Eclipse
Data Tools Platform Enablement"
org.eclipse.datatools.enablement.oda.designer.feature
(1.0.0.200612201) "DTP XML UI Plug-in"
org.eclipse.datatools.enablement.oda.feature (1.0.0.200612201) "DTP
ODA-XML Driver"
org.eclipse.datatools.modelbase.feature (1.0.0.200612201) "Eclipse
Data Tools Platform SQLModel Plug-in"
org.eclipse.emf (2.2.2.v200702131851) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.ecore.sdo (2.2.1.v200702131851) "EMF Service Data
Objects (SDO)"
org.eclipse.gef (3.2.2.v20070208) "Graphical Editing Framework"
org.eclipse.jdt (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse Java
Development Tools"
org.eclipse.jdt.source (3.2.2.r322_v20070104-R4CR0Znkvtfjv9-) "Eclipse
Java Development Tools SDK"
org.eclipse.jem (1.2.3.v20070130_R----6zXJK-L2U8VZ) "Java EMF Model"
org.eclipse.jem.sdk (1.2.3.v20070130_R-G95EUlhcE39c_dh) "Java EMF
Model SDK"
org.eclipse.jem.source (1.2.3.v20070130_R----6zXJK-L2U8VZ) "Java EMF
Model Source"
org.eclipse.pde (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse
Plug-in Development Environment"
org.eclipse.pde.source (3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG) "Eclipse
Plug-in Development Environment Developer Resources"
org.eclipse.platform (3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclipse
Platform"
org.eclipse.platform.source (3.2.2.r322_v20070119-RQghndJN8IM0MsK)
"Eclipse Platform Plug-in Developer Resources"
org.eclipse.rcp (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP"
org.eclipse.rcp.patch1 (3.2.2.v20070330_322) "Eclipse RCP"
org.eclipse.rcp.source (3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse
RCP Plug-in Developer Resources"
org.eclipse.sdk (3.2.2.r322_v20070104-dCGKm0Ln38lm-8s) "Eclipse
Project SDK"
org.eclipse.ve (1.2.1.v20060817_M-zXJUB0fx_-eyDdh) "Visual Editor"
org.eclipse.ve.sdk (1.2.1.v20060825_M-u0g6E989Ug_OQPH) "Visual Editor SDK"
org.eclipse.ve.source (1.2.1.v20060817_M-zXJUB0fx_-eyDdh) "Visual
Editor Source"
org.mozilla.rhino (1.6.0.v20070406-05--w31181642) "Mozilla Rhino"
org.w3c.sac (1.3.0.v20070406-02--w31181642) "W3C Sac"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.v20060918_M) "Event Model" [Resolved]
com.ibm.icu (3.4.5.20061213) "International Components for Unicode for
Java (ICU4J)" [Active]
com.ibm.icu.source (3.4.5.20061213) "International Components for
Unicode for Java (ICU4J) source plug-in" [Resolved]
com.ibm.icu34.data.update (3.4.5.v20070507_2007f) "ICU4J Data Update
Fragment" [Resolved]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
com.lowagie.itext (1.5.2.v20070531) "Lowagie Itext" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.batik (1.6.0.v20060613-1220) "Apache Batik" [Resolved]
org.apache.batik.bridge (1.6.0.v200706061935) "Apache Batik
Bridge/GVT/Scripting" [Resolved]
org.apache.batik.css (1.6.0.v200706061935) "Apache Batik CSS" [Resolved]
org.apache.batik.dom (1.6.0.v200706081713) "Apache Batik DOM" [Resolved]
org.apache.batik.dom.svg (1.6.0.v200706061935) "Apache Batik SVG DOM"
[Resolved]
org.apache.batik.ext.awt (1.6.0.v200706061935) "Apache Batik AWT
Utilities" [Resolved]
org.apache.batik.extension (1.6.0.v200706061935) "Apache Batik
Extension" [Resolved]
org.apache.batik.parser (1.6.0.v200706061935) "Apache Batik Parser"
[Resolved]
org.apache.batik.pdf (1.6.0.v20060613-1220) "Apache Batik Pdf" [Resolved]
org.apache.batik.pdf (1.6.0.v200705310311) "Bundle-Name" [Resolved]
org.apache.batik.svggen (1.6.0.v200706061935) "Apache Batik SVG
Generation" [Resolved]
org.apache.batik.swing (1.6.0.v200706061935) "Apache Batik Swing"
[Resolved]
org.apache.batik.transcoder (1.6.0.v200706061935) "Apache Batik
Transcoder" [Resolved]
org.apache.batik.util (1.6.0.v200706061935) "Apache Batik Utilities"
[Resolved]
org.apache.batik.util.gui (1.6.0.v200706061935) "Apache Batik GUI
org.apache.batik.xml (1.6.0.v200706061935) "Apache Batik XML" [Resolved]
org.apache.commons.codec (1.3.0.v20070531) "Apache Commons Codec"
[Resolved]
Eclipse" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.apache.xerces (2.8.0.v200705301630) "Apache Xerces-J" [Resolved]
org.apache.xerces (2.8.0.v200606131651) "Xerces 2.8.0" [Resolved]
org.apache.xml.resolver (1.1.0.v200702082200) "Apache XmlResolver"
[Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.2.1.r321_v20060828) "Ant UI" [Resolved]
org.eclipse.birt (2.2.0.v20070531) "Business Intelligence and
Reporting Tools" [Resolved]
org.eclipse.birt.chart (2.2.0.v20070531) "BIRT Chart Framework" [Resolved]
org.eclipse.birt.chart.cshelp (2.2.0.v20070531) "BIRT Chart
Context-sensitive Help" [Resolved]
org.eclipse.birt.chart.device.extension (2.1.2.v20070205-1728) "BIRT
Chart Device Extension(s)" [Installed]
org.eclipse.birt.chart.device.extension (2.2.0.v20070530) "BIRT Chart
Device Extension(s)" [Resolved]
org.eclipse.birt.chart.device.pdf (2.1.1.v20070205-1728) "BIRT Chart
Device PDF Extension" [Installed]
org.eclipse.birt.chart.device.pdf (2.2.0.v20070530) "BIRT Chart Device
PDF Extension" [Resolved]
org.eclipse.birt.chart.device.svg (2.1.1.v20070205-1728) "BIRT Chart
Device SVG Extension" [Installed]
org.eclipse.birt.chart.device.svg (2.2.0.v20070613) "BIRT Chart Device
SVG Extension" [Resolved]
org.eclipse.birt.chart.device.swt (2.1.1.v20070205-1728) "BIRT Chart
Device SWT Extension" [Installed]
org.eclipse.birt.chart.device.swt (2.2.0.v20070530) "BIRT Chart Device
SWT Extension" [Resolved]
org.eclipse.birt.chart.doc.isv (2.2.0.v20070531) "BIRT Chart ISV
Documentation" [Resolved]
org.eclipse.birt.chart.engine (2.1.2.v20070205-1728) "BIRT Chart
Engine" [Installed]
org.eclipse.birt.chart.engine (2.2.0.v20070608) "BIRT Chart Engine"
[Active]
org.eclipse.birt.chart.engine.extension (2.1.2.v20070205-1728) "BIRT
Chart Engine Extension" [Installed]
org.eclipse.birt.chart.engine.extension (2.2.0.v20070608) "BIRT Chart
Engine Extension" [Resolved]
org.eclipse.birt.chart.examples (2.1.1.v20070205-1728) "BIRT Chart
Examples Plug-in" [Installed]
org.eclipse.birt.chart.examples (2.2.0.v20070530) "BIRT Chart Examples
Plug-in" [Resolved]
org.eclipse.birt.chart.reportitem (2.1.2.v20070205-1728) "BIRT
Chart-Report Integration" [Installed]
org.eclipse.birt.chart.reportitem (2.2.0.v20070531) "BIRT Chart-Report
Integration" [Active]
org.eclipse.birt.chart.reportitem.ui (2.1.2.v20070205-1728) "BIRT
Chart-Report UI Integration Plug-in" [Installed]
org.eclipse.birt.chart.reportitem.ui (2.2.0.v20070608) "BIRT
Chart-Report UI Integration Plug-in" [Active]
org.eclipse.birt.chart.runtime (2.2.0.v20070531) "BIRT Chart Runtime"
[Resolved]
[Resolved]
Plugin" [Resolved]
org.eclipse.birt.chart.ui (2.1.1.v20070205-1728) "BIRT Chart Library
UI Plug-in" [Installed]
org.eclipse.birt.chart.ui (2.2.0.v20070607) "BIRT Chart Library UI
Plug-in" [Active]
org.eclipse.birt.chart.ui.extension (2.1.2.v20070205-1728) "BIRT Chart
UI Extension" [Installed]
org.eclipse.birt.chart.ui.extension (2.2.0.v20070613) "BIRT Chart UI
org.eclipse.birt.core (2.1.2.v20070205-1728) "BIRT Core Package"
[Installed]
org.eclipse.birt.core (2.2.0.v20070614) "BIRT Core Package" [Active]
org.eclipse.birt.core.ui (2.1.1.v20070205-1728) "BIRT Core UI" [Installed]
org.eclipse.birt.core.ui (2.2.0.v20070613) "BIRT Core UI" [Active]
Source" [Resolved]
org.eclipse.birt.cshelp (2.2.0.v20070531) "BIRT Context-sensitive
Help" [Resolved]
org.eclipse.birt.data (2.1.2.v20070205-1728) "BIRT Data Engine" [Active]
org.eclipse.birt.data (2.2.0.v200706014) "BIRT Data Engine" [Installed]
org.eclipse.birt.data.oda.adapter.dtp (2.1.1.v20070205-1728) "BIRT-DTP
ODA Adapter Plug-in" [Installed]
org.eclipse.birt.doc (2.2.0.v20070531) "BIRT Documentation" [Resolved]
org.eclipse.birt.doc.isv (2.2.0.v20070531) "BIRT ISV Documentation"
[Resolved]
org.eclipse.birt.example (2.2.0.v20070531) "BIRT Example" [Resolved]
org.eclipse.birt.report.data.adapter (2.1.1.v20070205-1728) "BIRT Data
Adapter" [Installed]
org.eclipse.birt.report.data.adapter (2.2.0.v20070613) "BIRT Data
Adapter" [Resolved]
org.eclipse.birt.report.data.oda.jdbc (2.2.0.v20070607) "BIRT ODA-JDBC
Bridge Driver" [Installed]
org.eclipse.birt.report.data.oda.jdbc.ui (2.1.1.v20070205-1728) "BIRT
JDBC UI Plug-in" [Installed]
org.eclipse.birt.report.data.oda.jdbc.ui (2.2.0.v20070607) "BIRT JDBC
org.eclipse.birt.report.data.oda.sampledb (2.2.0.v20070607) "BIRT
Sample Database" [Installed]
org.eclipse.birt.report.data.oda.sampledb.ui (2.1.1.v20070205-1728)
"BIRT Sample Database UI Plug-in" [Installed]
org.eclipse.birt.report.data.oda.sampledb.ui (2.2.0.v20070607) "BIRT
org.eclipse.birt.report.data.oda.xml (2.1.1.v20070205-1728) "BIRT
ODA-XML Driver" [Installed]
org.eclipse.birt.report.data.oda.xml (2.2.0.v20070607) "BIRT ODA-XML
Driver" [Resolved]
org.eclipse.birt.report.data.oda.xml.ui (2.2.0.v20070607) "BIRT ODA
XML Designer" [Resolved]
org.eclipse.birt.report.data.oda.xml.ui (2.1.1.v20070205-1728) "BIRT
XML UI Plug-in" [Installed]
org.eclipse.birt.report.debug.ui (2.1.1.v20070205-1728) "BIRT debug
org.eclipse.birt.report.debug.ui (2.2.0.v20070607) "BIRT debug
Plug-in" [Active]
org.eclipse.birt.report.designer (2.2.0.v20070531) "BIRT Report
org.eclipse.birt.report.designer.core (2.1.2.v20070205-1728) "BIRT
Designer Core" [Resolved]
org.eclipse.birt.report.designer.core (2.2.0.v20070613) "BIRT Designer
Core" [Active]
org.eclipse.birt.report.designer.example.samplereport
(2.1.1.v20070205-1728) "BIRT Samplereport Plug-in" [Resolved]
org.eclipse.birt.report.designer.samplereports (2.2.0.v20070529) "BIRT
Samplereports Plug-in" [Resolved]
Source" [Resolved]
org.eclipse.birt.report.designer.ui (2.2.0.v20070613) "BIRT Designer
UI" [Active]
org.eclipse.birt.report.designer.ui.cubebuilder (2.2.0.v20070613)
"BIRT Cube Builder Plug-in" [Resolved]
org.eclipse.birt.report.designer.ui.editors (2.2.0.v20070613) "BIRT
MultipageEditor Extension Point Plug-in" [Active]
org.eclipse.birt.report.designer.ui.editors (2.1.1.v20070205-1728)
"Rdt Plug-in" [Installed]
org.eclipse.birt.report.designer.ui.editors.schematic
(2.1.1.v20070205-1728) "BIRT Editors Plug-in" [Installed]
(2.2.0.v20070607) "BIRT Editors Plug-in" [Active]
org.eclipse.birt.report.designer.ui.ide (2.1.1.v20070205-1728) "BIRT
Designer UI for IDE" [Installed]
org.eclipse.birt.report.designer.ui.ide (2.2.0.v20070607) "BIRT
Designer UI for IDE" [Active]
org.eclipse.birt.report.designer.ui.lib (2.1.1.v20070205-1728) "BIRT
Designer UI for Library" [Installed]
org.eclipse.birt.report.designer.ui.lib (2.2.0.v20070614) "BIRT
Designer UI for Library" [Active]
org.eclipse.birt.report.designer.ui.lib.explorer
(2.1.1.v20070205-1728) "BIRT Library Explorer Plug-in" [Installed]
org.eclipse.birt.report.designer.ui.lib.explorer (2.2.0.v20070607)
"BIRT Library Explorer Plug-in" [Resolved]
org.eclipse.birt.report.designer.ui.preview (2.1.2.v20070205-1728)
"BIRT Preview Plug-in" [Active]
org.eclipse.birt.report.designer.ui.preview.web (2.2.0.v20070607)
org.eclipse.birt.report.designer.ui.samples.ide (2.2.0.v20070607)
"Report Samples IDE Plug-in" [Resolved]
org.eclipse.birt.report.designer.ui.samplesview (2.2.0.v20070607)
"BIRT Report Samples View Plug-in" [Resolved]
org.eclipse.birt.report.designer.ui.views (2.2.0.v20070613) "BIRT UI
Views Plug-in" [Active]
org.eclipse.birt.report.engine (2.1.2.v20070205-1728) "BIRT Engine"
[Installed]
org.eclipse.birt.report.engine (2.2.0.v20070614) "BIRT Engine" [Active]
org.eclipse.birt.report.engine.emitter.html (2.1.2.v20070205-1728)
"BIRT HTML Emitter" [Installed]
org.eclipse.birt.report.engine.emitter.html (2.2.0.v20070530) "BIRT
HTML Emitter" [Resolved]
org.eclipse.birt.report.engine.emitter.pdf (2.1.2.v20070205-1728)
"BIRT PDF emitter" [Installed]
org.eclipse.birt.report.engine.emitter.pdf (2.2.0.v20070530) "BIRT PDF
emitter" [Resolved]
org.eclipse.birt.report.engine.emitter.postscript (2.2.0.v20070530)
"BIRT POSTSCRIPT emitter" [Resolved]
org.eclipse.birt.report.engine.emitter.ppt (2.2.0.v20070607) "BIRT PPT
emitter" [Resolved]
org.eclipse.birt.report.engine.emitter.prototype.excel
(2.2.0.v20070613) "BIRT Excel emitter" [Resolved]
org.eclipse.birt.report.engine.emitter.wpml (2.2.0.v20070608) "BIRT
Word emitter" [Resolved]
org.eclipse.birt.report.engine.fonts (2.2.0.v20070530) "BIRT Engine
fonts" [Resolved]
org.eclipse.birt.report.item.crosstab.core (2.2.0.v20070614) "BIRT
Crosstab Plug-in" [Resolved]
org.eclipse.birt.report.item.crosstab.ui (2.2.0.v20070614) "BIRT
Crosstab UI Plug-in" [Active]
org.eclipse.birt.report.model (2.1.2.v20070205-1728) "BIRT Model"
[Installed]
org.eclipse.birt.report.model (2.2.0.v20070612) "BIRT Model" [Active]
org.eclipse.birt.report.model.adapter.oda (2.1.1.v20070205-1728) "BIRT
Model ODA Adapter" [Resolved]
org.eclipse.birt.report.model.adapter.oda (2.2.0.v20070530) "BIRT
org.eclipse.birt.report.runtime (2.2.0.v20070531) "BIRT Report
Runtime" [Resolved]
Plugin" [Resolved]
org.eclipse.birt.report.viewer (2.2.0.v20070611) "BIRT Web Viewer"
[Active]
org.eclipse.birt.resources (2.1.1.v20070205-1728) "BIRT Resources
Plug-in" [Resolved]
org.eclipse.birt.resources (2.2.0.v20070530) "BIRT Resources Plug-in"
[Resolved]
org.eclipse.birt.sdk (2.2.0.v20070531) "BIRT SDK" [Resolved]
"BIRT Source Plugin" [Resolved]
[Resolved]
org.eclipse.cdt.core (3.1.2.200702150621) "C/C++ Development Tools
Core" [Resolved]
org.eclipse.cdt.core.win32 (3.1.2.200702150621) "C/C++ Development
Tools Core for Windows" [Resolved]
org.eclipse.cdt.debug.core (3.1.2.200702150621) "C/C++ Development
Tools Debug Model" [Resolved]
org.eclipse.cdt.debug.mi.core (3.1.2.200702150621) "C/C++ Development
Tools GDB/MI CDI Debugger Core" [Resolved]
org.eclipse.cdt.debug.mi.ui (3.1.2.200702150621) "C/C++ Development
Tools GDB/MI CDI Debugger UI" [Resolved]
org.eclipse.cdt.debug.ui (3.1.2.200702150621) "C/C++ Development Tools
org.eclipse.cdt.doc.user (3.1.2.200702150621) "C/C++ Development User
Guide" [Resolved]
org.eclipse.cdt.launch (3.1.2.200702150621) "C/C++ Development Tools
Launching Support" [Resolved]
org.eclipse.cdt.make.core (3.1.2.200702150621) "C/C++ Standard make
Build Core" [Resolved]
org.eclipse.cdt.make.ui (3.1.2.200702150621) "C/C++ Standard make
Build UI" [Active]
org.eclipse.cdt.managedbuilder.core (3.1.2.200702150621) "C/C++
Managed Builder Core" [Resolved]
org.eclipse.cdt.managedbuilder.gnu.ui (3.1.2.200702150621) "GNU
Managed Build Definitions" [Resolved]
org.eclipse.cdt.managedbuilder.ui (3.1.2.200702150621) "C/C++ Managed
Builder UI" [Resolved]
org.eclipse.cdt.refactoring (3.1.2.200702150621) "C/C++ Refactoring"
[Resolved]
org.eclipse.cdt.ui (3.1.2.200702150621) "C/C++ Development Tools UI"
[Resolved]
org.eclipse.compare (3.2.1.M20060711) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content
Mechanism" [Active]
org.eclipse.core.expressions (3.2.2.r322_v20070109a) "Expression
Language" [Active]
org.eclipse.core.filebuffers (3.2.1.r321_v20060721) "File Buffers"
[Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems"
[Resolved]
org.eclipse.core.filesystem.win32.x86 (1.0.0.v20060603) "Core File
System for Windows" [Resolved]
org.eclipse.core.jobs (3.2.0.v20060603) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.2.R32x_v20061218) "Core Resource
Management" [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core
Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.2.0.v20060603) "Core Resource
Management Win32 Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060603) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core
Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.1.R32x_v20060907)
"Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Resolved]
org.eclipse.datatools.connectivity (1.0.0.200612111) "Data Tools
Platform Connectivity Plug-in" [Resolved]
org.eclipse.datatools.connectivity.db.derby (1.0.0.20061109) "Eclipse
Data Tools Platform Apache Derby Plug-in" [Resolved]
org.eclipse.datatools.connectivity.db.generic (1.0.0.20061018)
"Eclipse Data Tools Platform Generic DB Connectivity Plug-in" [Resolved]
org.eclipse.datatools.connectivity.db.generic.ui (1.0.0.200609291)
"Eclipse Data Tools Platform Generic DB UI Plug-in" [Resolved]
org.eclipse.datatools.connectivity.dbdefinition.derby
(1.0.0.200609291) "Eclipse Data Tools Platform Apache Derby Database
Definition" [Resolved]
org.eclipse.datatools.connectivity.dbdefinition.genericJDBC
(1.0.0.200609291) "Eclipse Data Tools Platform DBDefinition Generic
JDBC Plug-in" [Resolved]
org.eclipse.datatools.connectivity.derby (1.0.0.200611091) "Eclipse
Data Tools Platform Derby Plug-in" [Resolved]
org.eclipse.datatools.connectivity.derby.ui (1.0.0.200611092) "Eclipse
Data Tools Platform Apache Derby UI Plug-in" [Resolved]
org.eclipse.datatools.connectivity.jdt (1.0.0.20061108) "Data Tools
Platform Connectivity JDT Extension Plug-in" [Resolved]
org.eclipse.datatools.connectivity.oda (3.0.3.200612131) "DTP Open
Data Access" [Active]
org.eclipse.datatools.connectivity.oda.consumer (3.0.3.200612131) "DTP
ODA Consumer Helper Component Plug-in" [Resolved]
org.eclipse.datatools.connectivity.oda.design (3.0.3.200611151) "DTP
ODA Design Session Model" [Resolved]
org.eclipse.datatools.connectivity.oda.design.ui (3.0.3.200612131)
"DTP ODA Designer UI Framework Plug-in" [Resolved]
org.eclipse.datatools.connectivity.oda.flatfile (3.0.3.200612141) "DTP
ODA Flat File Run-time Driver" [Resolved]
org.eclipse.datatools.connectivity.oda.flatfile.ui (3.0.3.200612111)
"DTP ODA Flat File Designer" [Resolved]
org.eclipse.datatools.connectivity.oda.profile (3.0.3.200611151) "DTP
ODA Connection Profile Framework Plug-in" [Resolved]
org.eclipse.datatools.connectivity.oda.template.ui (3.0.3.200612131)
"DTP ODA New Plug-in Template Wizard" [Resolved]
org.eclipse.datatools.connectivity.sqm.core (1.0.0.200612191) "Eclipse
Data Tools Platform SQM Core Plug-in" [Resolved]
org.eclipse.datatools.connectivity.sqm.core.ui (1.0.0.200611092)
"Eclipse Data Tools Platform SQM UI Plug-in" [Resolved]
org.eclipse.datatools.connectivity.sqm.fe.ui (1.0.0.200612071)
"Eclipse Data Tools Platform FE UI Plug-in" [Resolved]
org.eclipse.datatools.connectivity.sqm.fe.ui.actions (1.0.0.200611091)
"Eclipse Data Tools Platform FE Ui Actions Plug-in" [Resolved]
org.eclipse.datatools.connectivity.sqm.server.ui (1.0.0.200612111)
"Eclipse Data Tools Platform Server UI Plug-in" [Resolved]
org.eclipse.datatools.connectivity.ui (1.0.0.200612191) "Data Tools
Platform Connectivity UI Plug-in" [Resolved]
org.eclipse.datatools.connectivity.ui.dse (1.0.0.200612071) "Eclipse
Data Tools Platform Data Source Explorer Plug-in" [Resolved]
org.eclipse.datatools.doc.user (1.0.0.200612191) "Data Tools Platform
User Guide" [Resolved]
org.eclipse.datatools.enablement.finfo (1.0.0.200612201) "Eclipse Data
Tools Platform Enablement" [Resolved]
org.eclipse.datatools.enablement.ibm.db2.iseries.dbdefinitio n
(1.0.0.200609291) "DB2 UDB iSeries Database Definition Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.db2.iseries.profile
(1.0.0.200609291) "Eclipse Data Tools Platform IBM DB2 UDB iSeries
Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.db2.luw.dbdefinition
(1.0.0.200609291) "Eclipse Data Tools Platform DB2 UDB Database
org.eclipse.datatools.enablement.ibm.db2.luw.profile (1.0.0.200609291)
"Eclipse Data Tools Platform IBM DB2 UDB LUW Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.db2.zseries.dbdefinitio n
(1.0.0.200609291) "DB2 UDB Database Definition Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.db2.zseries.profile
(1.0.0.200609291) "Eclipse Data Tools Platform IBM DB2 UDB zSeries
Plug-in" [Resolved]
org.eclipse.datatools.enablement.ibm.informix.dbdefinition
(1.0.0.200609291) "Eclipse Data Tools Platform Informix Database
org.eclipse.datatools.enablement.ibm.informix.profile
(1.0.0.200609291) "Eclipse Data Tools Platform Informix Plug-in"
[Resolved]
org.eclipse.datatools.enablement.msft.sqlserver.dbdefinition
(1.0.0.200609291) "Eclipse Data Tools Platform SQL Server Database
org.eclipse.datatools.enablement.msft.sqlserver.profile
(1.0.0.200609291) "Eclipse Data Tools Platform Microsoft SQL Server
Plug-in" [Resolved]
org.eclipse.datatools.enablement.mysql (1.0.0.200611083) "Eclipse Data
Tools Platform MySQL enablement plug-in" [Resolved]
org.eclipse.datatools.enablement.mysql.dbdefinition (1.0.0.200609291)
"Eclipse Data Tools Platform MySQL Database Definition Plug-in" [Resolved]
org.eclipse.datatools.enablement.mysql.profile (1.0.0.200609291)
"Eclipse Data Tools Platform MySQL Plug-in" [Resolved]
org.eclipse.datatools.enablement.oda.xml (1.0.0.200612201) "DTP
ODA-XML Driver" [Resolved]
org.eclipse.datatools.enablement.oda.xml.ui (1.0.0.200612141) "DTP XML
org.eclipse.datatools.enablement.oracle.dbdefinition (1.0.0.200609291)
"Eclipse Data Tools Platform Oracle Database Definition Plug-in"
[Resolved]
org.eclipse.datatools.enablement.oracle.profile (1.0.0.200609291)
"Eclipse Data Tools Platform Oracle Plug-in" [Resolved]
org.eclipse.datatools.enablement.postgresql.dbdefinition
(1.0.0.200612191) "PostgreSQL DB Definition" [Resolved]
org.eclipse.datatools.enablement.postgresql.profile (1.0.0.200609291)
"PostgreSQL Connection Profile and Driver Template Plug-in" [Resolved]
org.eclipse.datatools.enablement.sybase.ase.dbdefinition
(1.0.0.200609291) "Eclipse Data Tools Platform Sybase Database
org.eclipse.datatools.enablement.sybase.ase.profile (1.0.0.200609291)
"Eclipse Data Tools Platform Sybase ASE Plug-in" [Resolved]
org.eclipse.datatools.modelbase.dbdefinition (1.0.0.200609291)
"Eclipse Data Tools Platform DBDefinition Model" [Resolved]
org.eclipse.datatools.modelbase.derby (1.0.0.200609291) "Derby
Plug-in" [Resolved]
org.eclipse.datatools.modelbase.edit (1.0.0.200609291) "Eclipse Data
Tools Platform SQLModel Edit Plug-in" [Resolved]
org.eclipse.datatools.modelbase.sql (1.0.0.200609291) "Eclipse Data
Tools Platform SQLModel Plug-in" [Resolved]
org.eclipse.datatools.modelbase.sql.query (1.0.0.200609291) "Eclipse
Data Tools Platform SQL Query Model Plugin" [Resolved]
org.eclipse.datatools.modelbase.sql.xml.query (1.0.0.200609291)
"Eclipse Data Tools Platform SQL XML Query Model Plugin" [Resolved]
org.eclipse.datatools.oda.cshelp (1.0.0.200612181) "DTP ODA
org.eclipse.debug.core (3.2.1.v20060823) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.2.r322_v20070202) "Debug UI" [Active]
org.eclipse.draw2d (3.2.2.v20070208) "Draw2d" [Active]
org.eclipse.emf (2.2.0.v200702131851) "Eclipse Modeling Framework
(EMF)" [Resolved]
org.eclipse.emf.ant (2.2.0.v200702131851) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.2.2.v200702131851) "EMF Template Code
Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.2.2.v200702131851) "EMF Ecore Code
org.eclipse.emf.codegen.ecore.ui (2.2.1.v200702131851) "EMF Ecore Code
Generation UI" [Resolved]
org.eclipse.emf.codegen.ui (2.1.0.v200702131851) "EMF Template Code
Generator UI" [Resolved]
org.eclipse.emf.common (2.2.1.v200702131851) "EMF Common" [Active]
org.eclipse.emf.common.ui (2.2.1.v200702131851) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0.v200702131851) "CommonJ SDO" [Resolved]
org.eclipse.emf.converter (2.2.1.v200702131851) "EMF Model Convert
Support" [Resolved]
org.eclipse.emf.ecore (2.2.2.v200702131851) "EMF Ecore" [Active]
org.eclipse.emf.ecore.change (2.2.1.v200702131851) "EMF Ecore Change
Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.2.0.v200702131851) "EMF Ecore
Change Edit Support" [Resolved]
org.eclipse.emf.ecore.edit (2.2.0.v200702131851) "EMF Ecore Edit
Support" [Resolved]
org.eclipse.emf.ecore.editor (2.2.0.v200702131851) "Sample Ecore
Editor" [Resolved]
Objects (SDO)" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.2.0.v200702131851) "EMF Service Data
Objects (SDO) Edit Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.2.0.v200702131851) "EMF Service
Data Objects (SDO) Editor" [Resolved]
org.eclipse.emf.ecore.xmi (2.2.2.v200702131851) "EMF XMI" [Resolved]
org.eclipse.emf.edit (2.2.2.v200702131851) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.2.1.v200702131851) "EMF Edit UI" [Resolved]
org.eclipse.emf.exporter (2.2.0.v200702131851) "EMF Model Export
Support" [Resolved]
org.eclipse.emf.importer (2.2.2.v200702131851) "EMF Model Import
Support" [Resolved]
org.eclipse.emf.importer.ecore (2.2.0.v200702131851) "EMF Ecore
Importer" [Resolved]
org.eclipse.emf.importer.java (2.2.1.v200702131851) "EMF Annotated
Java Importer" [Resolved]
org.eclipse.emf.importer.rose (2.2.0.v200702131851) "EMF Rose
org.eclipse.emf.mapping (2.2.0.v200702131851) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.2.0.v200702131851) "Ecore to
Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.2.0.v200702131851)
"Ecore to Ecore Mapping Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.2.0.v200702131851) "Ecore to XML
Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.2.0.v200702131851) "Ecore to
XML Mapping UI" [Resolved]
org.eclipse.emf.mapping.ui (2.2.1.v200702131851) "EMF Mapping UI"
[Resolved]
org.eclipse.equinox.common (3.2.0.v20060603) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.preferences (3.2.1.R32x_v20060717) "Eclipse
Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.2.1.R32x_v20060814) "Extension
Registry Support" [Active]
org.eclipse.gef (3.2.2.v20070208) "Graphical Editing Framework" [Active]
org.eclipse.help (3.2.2.R322_v20061213) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application
Server" [Active]
org.eclipse.help.base (3.2.2.R322_v20061207) "Help System Base" [Resolved]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.2.2.R322_v20061114) "Help System Webapp"
[Resolved]
org.eclipse.jdt (3.2.1.r321_v20060823) "Eclipse Java Development
Tools" [Resolved]
org.eclipse.jdt.apt.core (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing Core" [Installed]
org.eclipse.jdt.apt.ui (3.2.1.R32x_v20060822-2100) "Java Annotation
Processing UI" [Installed]
org.eclipse.jdt.core (3.2.3.v_686_R32x) "Java Development Tools Core"
[Active]
org.eclipse.jdt.core.manipulation (1.0.1.r321_v20060721) "Java Code
Manipulation Functionality" [Resolved]
org.eclipse.jdt.debug (3.2.2.r322_v20070130) "JDI Debug Model" [Resolved]
org.eclipse.jdt.debug.ui (3.2.2.r322_v20061205) "JDI Debug UI" [Resolved]
org.eclipse.jdt.doc.isv (3.2.1.r322_v20070109) "Eclipse JDT Plug-in
Developer Guide" [Resolved]
org.eclipse.jdt.doc.user (3.2.0.v20060605-1400) "Eclipse Java
Development User Guide" [Resolved]
org.eclipse.jdt.junit (3.2.1.r321_v20060810) "Java Development Tools
JUnit support" [Resolved]
org.eclipse.jdt.junit.runtime (3.2.1.r321_v20060721) "Java Development
Tools JUnit runtime support" [Resolved]
org.eclipse.jdt.junit4.runtime (1.0.1.r321_v20060905) "Java
Development Tools JUnit4 runtime support" [Installed]
org.eclipse.jdt.launching (3.2.2.r322_v20061114) "Java Development
Tools Launching Support" [Resolved]
Java Development Tools SDK" [Resolved]
org.eclipse.jdt.ui (3.2.2.r322_v20070124) "Java Development Tools UI"
[Resolved]
org.eclipse.jem (1.2.1.v20060918_M) "Java EMF Model" [Resolved]
org.eclipse.jem.beaninfo (1.2.2.v20061027_M) "Java EMF Model BeanInfo
(Introspection) Support" [Resolved]
org.eclipse.jem.proxy (1.2.0.v20060918_M) "Java EMF Model Proxy
Support" [Resolved]
org.eclipse.jem.sdk (1.2.0.v20060918_M) "Java EMF Model SDK" [Resolved]
Model Source" [Resolved]
org.eclipse.jem.ui (1.2.1.v20060918_M) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.2.1.v20060918_M) "Java EMF Model Utilities"
[Resolved]
org.eclipse.jem.workbench (1.2.3.v20070130_R) "Java EMF Model
Workbench Support" [Resolved]
org.eclipse.jface (3.2.2.M20061214-1200) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data
Binding" [Resolved]
org.eclipse.jface.text (3.2.2.r322_v20070104) "JFace Text" [Resolved]
org.eclipse.ltk.core.refactoring (3.2.1.r321_v20060823) "Refactoring
Core" [Resolved]
org.eclipse.ltk.ui.refactoring (3.2.2.r322_v20070124) "Refactoring UI"
[Resolved]
org.eclipse.osgi.services (3.1.100.v20060601) "OSGi Release 3
Services" [Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes"
[Resolved]
org.eclipse.pde (3.2.1.v20060810-0800) "Eclipse Plug-in Development
Environment" [Resolved]
org.eclipse.pde.build (3.2.1.r321_v20060823) "Plug-in Development
Environment Build Support" [Resolved]
org.eclipse.pde.core (3.2.1.v20060915-0800) "Plug-in Development Core"
[Resolved]
org.eclipse.pde.doc.user (3.2.1.v20060816-0800) "Eclipse Plug-in
org.eclipse.pde.junit.runtime (3.2.0.v20060605) "PDE JUnit Plug-in
Test" [Resolved]
org.eclipse.pde.runtime (3.2.0.v20060605) "Plug-in Development
Environment Runtime" [Resolved]
Plug-in Development Environment Developer Resources" [Resolved]
org.eclipse.pde.ui (3.2.1.v20060816-0800) "Plug-in Development UI"
[Resolved]
org.eclipse.platform (3.2.2.r322_v20070117b) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.2.2.R32x_v20070115) "Eclipse Platform
Plug-in Developer Guide" [Resolved]
org.eclipse.platform.doc.user (3.2.1.R32x_v200608101155) "Eclipse
Workbench User Guide" [Resolved]
"Eclipse Platform Plug-in Developer Resources" [Resolved]
org.eclipse.platform.source.win32.win32.x86
(3.2.2.r322_v20070119-RQghndJN8IM0MsK) "Eclipse Platform Plug-in
org.eclipse.rcp (3.2.0.v20060605) "Eclipse RCP" [Resolved]
RCP Plug-in Developer Resources" [Resolved]
org.eclipse.rcp.source.win32.win32.x86
(3.2.2.r322_v20070104-8pcviKVqd8J7C1U) "Eclipse RCP Plug-in Developer
org.eclipse.sdk (3.2.2.r322_v20070212) "Eclipse Project SDK" [Resolved]
org.eclipse.search (3.2.1.r321_v20060726) "Search Support" [Resolved]
org.eclipse.swt (3.2.2.v3236b) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.2.2.v3236) "Standard Widget Toolkit
org.eclipse.team.core (3.2.2.M20061114) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.2.M20061205) "CVS Team Provider Core"
[Active]
org.eclipse.team.cvs.ssh (3.2.1.M20061205) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.1.M20061205) "CVS SSH2" [Active]
org.eclipse.team.cvs.ui (3.2.2.M20061121) "CVS Team Provider UI" [Active]
org.eclipse.team.ui (3.2.1.M200608151725) "Team Support UI" [Active]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Active]
org.eclipse.ui (3.2.1.M20061108) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.2.1.R321_v20060720) "Cheat Sheets"
[Resolved]
org.eclipse.ui.console (3.1.100.v20060605) "Console" [Active]
org.eclipse.ui.editors (3.2.1.r321_v20060721) "Default Text Editor"
[Active]
org.eclipse.ui.externaltools (3.1.101.r321_v20060802) "External T
Re: Problems getting BIRT 2.2 to run in eclipse 3.2 [message #243922 is a reply to message #243903] |
Thu, 21 June 2007 10:46  |
malcolm davis wrote:
> Your organization will start to run into support and product issues soon.
Last year we had a project where we had to develop with jdk1.1.8 (IBM
cash register system) as the customer was not willing to move to Java2
due to memory constraints... That was just a pita to backport all
those collections stuff...
>> Bernd, now with 6 installations of eclipse/BIRT in different combinations
Okay, we are now running BIRT 2.1.2 with eclipse 3.2. I don't know
what was the issue here, as the first installation did not run but is
now working fine.
Thanks to "Birt Question" for pushing me in the right direction.
Bernd
Current Time: Tue Jul 22 12:06:40 EDT 2025
Powered by FUDForum. Page generated in 0.04425 seconds
