Home » Language IDEs » Java Development Tools (JDT) » How to find out if method is public using IMember or IType
How to find out if method is public using IMember or IType [message #243433] Thu, 03 May 2007 15:34 Go to next message
Urgent help needed:
I would like to update method with Annotation and I would like to do it
only for public methods.
How I can figure out if method is public using IMethod or IType API ?
Re: How to find out if method is public using IMember or IType [message #243438 is a reply to message #243433] Fri, 04 May 2007 02:47 Go to previous messageGo to next message
If you have the IMethod you can check
(method.getFlags() & Flags.AccPublic) != 0
You may also want to check method.isConstructor() and Flags.AccStatic
depending whether you want to include static methods and constructors or
not.
--Cam
Irene Levina wrote:
> Urgent help needed:
Re: How to find out if method is public using IMember or IType [message #243443 is a reply to message #243438] Fri, 04 May 2007 09:42 Go to previous messageGo to next message
I would rather recommend:
Flags.isPublic(method.getFlags())
Olivier
Re: How to find out if method is public using IMember or IType [message #243454 is a reply to message #243443] Fri, 04 May 2007 12:57 Go to previous message
Good point.
Previous Topic:Eclipse compiler and static initializers
Next Topic:java.lang.NoClassDefFoundError
Current Time: Thu Jul 10 07:58:58 EDT 2025
Powered by FUDForum. Page generated in 0.08755 seconds
