| Parameter UI - Set param Value/DefaultValue dynamically [message #243420] |
Tue, 19 June 2007 19:44  |
Originally posted by: damian.delcampo.sealink.com.au
I have date parameter in a report, this works fine and allows me to
manually enter a value such as 2007-06-19.
However I would like for this parameter to have a default value which is
dynamic - such as the current date or the current date minus 1 month etc.
How can this be achieved ????
I have set this parameter in the 'initialize' method of the report (
using params["paramDateEnd"].value = ..... ) however this seems to run
after the parameter UI is displayed.
Thank you kindly,
Damian
| Re: Parameter UI - Set param Value/DefaultValue dynamically [message #244130 is a reply to message #243940] |
Thu, 21 June 2007 20:24  |
Thanks Jason,
I'll have a crack at what you've suggested hopefully next week.
Kind regards,
Damian
Jason Weathersby wrote:
> Damian,
> There are jsp fragments that can be modified in the webconent directory,
> but you probably do not want to alter them just for one report. The
> reason I used a combo box is because the user could select the auto
> generated date or type in a date. Another option is to use the tag lib
> and use the param tag. This requires 2.2 but allows you to build your
> own parameter screen.
> Jason
> Damian Del Campo wrote:
>> Thanks for the reply Jason.
>> The problem with using a combo box to enter the date field is that
>> there would be a finite number of dates I can enter - this also
>> becomes a very non user friendly way of entering the date.
>> I need to find the way of accessing the UI elements just before the
>> parameter screen is rendered.
>> Do you know of the syntax of objects / function I could call to set
>> the value of these UI elements.
>> To be honest I'm a little preplexed that this is even an issue.
>> I'd have thought that date type parameters were probably the most used
>> in any reporting tool. Surely there are date type parameters
>> calculating a default value so that reports retain their usability
>> through time.
>> Kind regards,
>> Damian
>>> Damian,
>>> Try creating a scripted data source with the following scripts:
>>> open
>>> i=0;
>>> fetch
>>> if (i > 0 ){
>>> return false;
>>> }else{
>>> importPackage( Packages.java.util );
>>> sdd = new Date();
>>> sdd.setDate(sdd.getDate() - 1);
>>> row["dd"] = sdd;
>>> i++;
>>> return true;
>>> Then create a combo dynamic parameter that uses the scripted data set
>>> created.
>>> Jason
>>>> Hello,
>>>> which is dynamic - such as the current date or the current date
>>>> minus 1 month etc.
>>>> run after the parameter UI is displayed.
>>>> Thank you kindly,
>>>> Damian
FUDForum. Page generated in 0.04080 seconds
