Home » Language IDEs » PHP Development Tools (PDT) » Open Declaration feature
Open Declaration feature [message #23902] Mon, 28 May 2007 06:03 Go to next message
hello,
i'd like to use the "open declaration" eclipse feature within the pdt
(right click on a variable).
selecting a php variable and hitting F3 ("open declaration" feature
specified in eclipse "Navigate" menu) i obtain a general
java.nullpointer.exception.
should i have to configure some library path or something similar, in my
workspace?
thank you,
lorenzo
Re: Open Declaration feature [message #23945 is a reply to message #23902] Mon, 28 May 2007 06:08 Go to previous messageGo to next message
There shouldn't be any exception, please report a bug including the PHP code
snippet,
in which this problem happens.
Thanks!
"lorenzo lucioni" <l.lucioni@communicationvalley.it> wrote in message
news:f3e9e9$grj$1@build.eclipse.org...
> hello,
> workspace?
> thank you,
> lorenzo
Re: Open Declaration feature [message #23983 is a reply to message #23945] Mon, 28 May 2007 06:20 Go to previous messageGo to next message
done.
but, you know, it isn't the best solution: my bug report will not be
usefull. good luck.
it would be better if you help me in create a right configuration for
the php code assistant. i'll be, than, able to determine why the
java.lang.nullpointerexception were raised.
lorenzo
> snippet,
> Thanks!
>> hello,
>> workspace?
>> thank you,
>> lorenzo
Re: Open Declaration feature [message #24193 is a reply to message #23983] Mon, 28 May 2007 15:17 Go to previous messageGo to next message
Lorenzo,
Can you please send the bug url?
Thanks!
Ali
lorenzo lucioni wrote:
> done.
> usefull. good luck.
> lorenzo
>> snippet,
>> Thanks!
>>> hello,
>>> workspace?
>>> thank you,
>>> lorenzo
Re: Open Declaration feature [message #24603 is a reply to message #24193] Wed, 30 May 2007 04:20 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=189396
Ali B. ha scritto:
> Lorenzo,
> Thanks!
> Ali
>> done.
>> usefull. good luck.
>> lorenzo
>>> PHP code snippet,
>>> Thanks!
>>>> hello,
>>>> in my
>>>> workspace?
>>>> thank you,
>>>> lorenzo
Previous Topic:Another xdebug gotchya (w/solution)
Next Topic:php debug urlrewrite
Current Time: Sun Jul 27 03:16:27 EDT 2025
Powered by FUDForum. Page generated in 0.04853 seconds
