Home » Archived » BIRT » How to reduce the space in detail? (for Mr. Burns)
How to reduce the space in detail? (for Mr. Burns) [message #243331] Tue, 19 June 2007 11:42 Go to next message
Originally posted by: chaohua.wang.premierata.com
Hi, Mr. Burns,
I can't find any post on 5/22/2007. could you tell me again? Thank you.
Chaohua
Hello chaohua,
may you find a solution reading my post on 22.05.2007 16:04.
Hope that helps!
Hi, Folks,
I generated a PDF file with designer, but I have found the space among
elements is little big in detail. I want to more small among them,
for example in my generated pdf fles.
section 1
section 9
I want the distance between them is much smaller.
Please help. Thank you,
chaohua
( I attached the deisgner file and generated pdf file)
Re: How to reduce the space in detail? (for Mr. Burns) [message #243448 is a reply to message #243331] Wed, 20 June 2007 03:34 Go to previous message
Hello chaohua,
From Jason W.:
.... the issue is that the padding numbers are not getting written to the
style in the xml unless they are altered.
Try setting all the paddings to 10pt, run the report and then set them back
to 0. This did
away with mine, and the output contained the correct paddings.
And / or reduce line height under the text block style attribute
Hope that helps!
Previous Topic:Manually add rows to dataset
Next Topic:Hiding of rows
Current Time: Sat Jul 26 13:16:05 EDT 2025
Powered by FUDForum. Page generated in 0.05984 seconds
