Home » Newcomers » Newcomers » Source Code for XML Generating
Source Code for XML Generating [message #243281] Sun, 16 December 2007 02:30 Go to next message
Originally posted by: zhangzhongl.gmail.com
Hi,Everyone
I got a question that need your help.
I do not know where can I find the source code for the XML Generating
function.
I mean I got an DTD file in my project,and I can right-click it and use
the Generate...--->XML File... to generate an sample xml or a minimum xml
file.
I want to obtain the source code that implements this function.
I can use the cvs tool,but I do not know which project should I get in the
/cvsroot/eclipse.
Any advice will be appreciated.
Re: Source Code for XML Generating [message #243291 is a reply to message #243281] Sun, 16 December 2007 12:19 Go to previous message
I think WTP provides this function, but I'm not sure in which plugin.
You could look for the string you see on the menu label in the
plugin.properties of each of WTP's plugins. I wonder if Chris' Eclipse
Spy could be used to get the answer quickly:
http://mea-bloga.blogspot.com/2007/11/plug-in-spy-rcp-and-ec lipse-33.html
zhangzhongl wrote:
> Hi,Everyone
> function.
> use the Generate...--->XML File... to generate an sample xml or a
> minimum xml file.
> the /cvsroot/eclipse.
Previous Topic:Working with QT
Next Topic:How to upgrade Photran and keep the old settings?
Current Time: Sat Jul 26 18:10:01 EDT 2025
Powered by FUDForum. Page generated in 1.29882 seconds
