Use BIRT Report api "without" separate birt runtime (inside eclipse) [message #243232] |
Tue, 19 June 2007 04:41  |
Originally posted by: johan.ponin.fr.ibm.com
Hi all,
I've looked through BIRT tutorials for report api and it always begin with
some code for running birt runtime.
But I'm in an \"Eclipse plug-in\" context, so i would like to know if it's
possible to use the Report Api directly.
Considering my eclipse configuration 'could' all the librairies needed, i'd
like to do something like this:
ReportEngine engine =
$methodForPluginLookup.get(\"org.eclipse.birt.....\").createEngineFactory();
and then use the api like the tutorial.
My goal is to make a way to, programmaticaly, open a report or a report
template,
then create/change the datasource and datasets to be able to run a report
generation but with any input source I want from a kind of pipeline.
A scenario could look like this:
BIRT Designer User:
-> predefine Report/ReportTemplate R
Lambda Eclipse User:
-> Select an xml file X
-> Then run my plugin action to create specific generated report for X and
R without using the BIRT Designer to bind data sources.
Thanks in advance, I hope i'm not asking stupid things or bending BIRT too
much.
Johan PONIN
Re: Use BIRT Report api "without" separate birt runtime (inside eclipse) [message #243808 is a reply to message #243620] |
Thu, 21 June 2007 04:54  |
Oh thanks a lot Jason, it looks like exactly what i needed.
G'bye
Johan
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:f5bli2$rmn$1@build.eclipse.org...
> Johan,
> If you have BIRT re api plugin in your dependencies you should be able to
> do this to get the report engine
> EngineConfig config = new EngineConfig();
> // Create the report engine
> IReportEngineFactory factory = (IReportEngineFactory)
> org.eclipse.birt.core.framework.Platform
> .createFactoryObject(
> IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
> IReportEngine engine = factory.createReportEngine( config );
> Jason
> Johan PONIN wrote:
>> Hi all,
>> with some code for running birt runtime.
>> it's possible to use the Report Api directly.
>> i'd like to do something like this:
>> template,
>> BIRT Designer User:
>> and R without using the BIRT Designer to bind data sources.
>> too much.
>> Johan PONIN
FUDForum. Page generated in 0.35130 seconds
