| How to programmatically add and remove JREs? [message #243156] |
Mon, 23 April 2007 14:21  |
Originally posted by: gbrall85.web.de
I'm working on a plugin for Eclipse 3.2 that manages a list of install
locations of a speficic software, whereas each of these locations
contains a JRE, for which I've defined a new VMInstallType.
Now I'm looking for a way to synchronize this list with the JDT plugin's
list of "Installed JREs". Manually adding and removing of VMInstalls of
my VMInstallType works.
My current solution is:
- call MyVMInstallType.disposeVMInstall(String id) to remove a JRE
- create a VMStandin instance, setting the appropriate values and
calling convertToRealVM() to add a JRE.
Finally, I call JavaRuntime.saveVMConfiguration().
The problem I encounter is that often (sometimes it works..) my changes
to the JRE list are not reflected in the "Installed JREs" preference
page. (They seem to be overwritten. I've been watching the associated
preference file - the VMInstalls are created and appear in the XML
string. However, when I close the Preferences Dialog, the old
configuration is restored.)
Is there a way to add/remove VMInstalls so that changes are immediately
reflected in the JRE list?
Any hints would be greatly appreciated,
thanks in advance,
Julian
| Re: How to programmatically add and remove JREs? [message #243277 is a reply to message #243156] |
Sat, 28 April 2007 08:40   |
Does perssing "Apply" on your page always work?
In such case I would guess that the JRE preferences page possibly overrides
your changes. Try scheduling JRE change as a job that will run after the
window closes.
Genady Beryozkin
http://www.genady.net/
Julian Oppermann wrote:
> Hello,
> plugin's list of "Installed JREs". Manually adding and removing of
> VMInstalls of my VMInstallType works.
> changes to the JRE list are not reflected in the "Installed JREs"
> preference page. (They seem to be overwritten. I've been watching the
> associated preference file - the VMInstalls are created and appear in
> the XML string. However, when I close the Preferences Dialog, the old
> immediately reflected in the JRE list?
> thanks in advance,
> Julian
| Re: How to programmatically add and remove JREs? [message #243282 is a reply to message #243277] |
Sun, 29 April 2007 11:51  |
> window closes.
Thank you, that works reliably.
I've registered an IJobChangeListener that calls my synchronizing method
when the job that updates JDT's JRE list fires its "done" event. The
only drawback is that I have to use a String from the LaunchingMessages
class that is marked as "internal".
Anyway, would that be a "good" practise or do you know a more elegant
way to notice when the Preferences dialog closes?
Julian
> Genady Beryozkin
>> Hello,
>> thanks in advance,
>> Julian
FUDForum. Page generated in 0.03335 seconds
