Home » Modeling » M2T (model-to-text transformation) » JET2-GMF/EMF Access Container class
JET2-GMF/EMF Access Container class [message #23884] Wed, 27 June 2007 07:02 Go to next message
Im using JET to generate some file from my GMF model instance and
everything works fine.
Now I have a question if it's possible to access a "Container" class
form the one being containted. Here's is a litte example of a simple model
ClassA <>------- ClassB ------- ClassC
This means that the ClassB is contained by the class A. The class C has
a reference to the classB. The entry point to my JET transformation is
the classC from where I can easily access the classB but I dont know how
to acceess the class A from the classB.
This is represented in the xml file of my model instance like:
<classA name="myclassA" >
<classB name="myclassB"/>
</classA>
<classC name="myclassC" refClassB="//@classesA.0/@classesB.0">
</classC>
So my question again is how can I access an attribute of a classA if I'm
itterating through the classesC.
I hope Im clear enough :)
Tex.
Re: JET2-GMF/EMF Access Container class [message #23925 is a reply to message #23884] Wed, 27 June 2007 07:39 Go to previous messageGo to next message
Putting a reference from the classB to its container classA would be a
solution but I think it's not the best one.
Tex Twil wrote:
> Hello,
> </classA>
> </classC>
> Tex.
Re: JET2-GMF/EMF Access Container class [message #23961 is a reply to message #23925] Wed, 27 June 2007 09:25 Go to previous messageGo to next message
Originally posted by: vincent.lg.voila.fr
Hi Tex, maybe you can try something like that :
<c:iterate var="curClassC" select="//classC">
<c:setVariable var="curClassA"
select="//classA[classB=$curClassC/@refClassB]">
<%-- do something with $curClassA --%>
</c:iterate>
Here we iterate through all classC nodes.
the select clause in setVariable tag searches for a classA node that
contains a classB node which matches the refClassB attribute of the
current classC node. I hope what I said is clear for you. I think you can
do the trick only using XPath expression, without adding any unnecessary
references.
Hope it helps,
Vincent.
Re: JET2-GMF/EMF Access Container class [message #23999 is a reply to message #23884] Wed, 27 June 2007 09:59 Go to previous messageGo to next message
Tex:
The JET XPath engine supports the parent axis:
$myB/parent::node() or $myB/parent::*
or the more cryptic, abbreviated form:
$myB/..
Paul
"Tex Twil" <chaljan@hotmail.com> wrote in message
news:f5tg4g$ukc$1@build.eclipse.org...
> Hello,
> Now I have a question if it's possible to access a "Container" class form
> This means that the ClassB is contained by the class A. The class C has a
> reference to the classB. The entry point to my JET transformation is the
> classC from where I can easily access the classB but I dont know how to
> </classA>
> </classC>
> Tex.
Re: JET2-GMF/EMF Access Container class [message #24034 is a reply to message #23999] Wed, 27 June 2007 10:03 Go to previous message
Great ! Thank you.
Tex.
Paul Elder wrote:
> Tex:
> $myB/..
> Paul
>> Hello,
>> </classA>
>> </classC>
>> Thanks,
>> Tex.
Previous Topic:c:iterate with delimiter and formatting
Next Topic:check if a variable is defined
Current Time: Tue Jul 22 02:25:18 EDT 2025
Powered by FUDForum. Page generated in 0.16430 seconds
