Home » Archived » BIRT » Problem with Tooltips display on SVG Charts
Problem with Tooltips display on SVG Charts [message #243118] Mon, 18 June 2007 11:18 Go to next message
I've got a piece of code to generate bar charts in SVG format. The code adds
a tooltip to each bar in the chart to display the bars value when the mouse
is hovered over it. However, when I actually run it, the tooltip for each
bar is the same - they all display the value of the last bar on the chart.
I've verified that the data present in the list of triggers (obtained with
BarSeries.getTriggers() ) is correct, yet it won't display correctly. Any
ideas?
Re: Problem with Tooltips display on SVG Charts [message #243297 is a reply to message #243118] Tue, 19 June 2007 09:25 Go to previous messageGo to next message
I believe this should be fixed. Can you try with the lastet 2.1.3 release or
2.2 RC4?
David
"Henry Wilson" <hfwilson@uk.ibm.com> wrote in message
news:f567r9$7j5$1@build.eclipse.org...
> adds a tooltip to each bar in the chart to display the bars value when the
> mouse is hovered over it. However, when I actually run it, the tooltip for
> each bar is the same - they all display the value of the last bar on the
> chart.
> ideas?
Re: Problem with Tooltips display on SVG Charts [message #243468 is a reply to message #243297] Wed, 20 June 2007 06:08 Go to previous messageGo to next message
Just recompiled with 2.1.3, then with 2.2 RC3 (RC4 doesn't seem to be
available). I still get the same problem with both of the newer versions. Is
this a known bug?
"David Michonneau" <dmichonneau@actuate.com> wrote in message
news:f58lfq$qgq$1@build.eclipse.org...
>or 2.2 RC4?
> David
>> the mouse is hovered over it. However, when I actually run it, the
>> tooltip for each bar is the same - they all display the value of the last
>> bar on the chart.
>> with BarSeries.getTriggers() ) is correct, yet it won't display
>> correctly. Any ideas?
Re: Problem with Tooltips display on SVG Charts [message #243863 is a reply to message #243468] Thu, 21 June 2007 08:14 Go to previous messageGo to next message
It's not a known bug, can you please file one in bugzilla?
David
news:f5aue4$94s$1@build.eclipse.org...
> Is this a known bug?
>>or 2.2 RC4?
>> Thanks,
>> David
Re: Problem with Tooltips display on SVG Charts [message #243889 is a reply to message #243863] Thu, 21 June 2007 09:11 Go to previous messageGo to next message
I have filed a bugzilla report (#193708). Incidentally the problem seems to
be to do with Triggers as a whole rather than just tooltips, I tried using
triggers both for tooltip display and for Script invocation and both result
in all triggers performing the action relating to the last plot on the
chart. Any idea if/when this will be fixed? The chart engine is essentially
useless to me until such time as this is sorted out :-(
news:f5dq3s$a44$1@build.eclipse.org...
> David
>>>or 2.2 RC4?
>>> Thanks,
>>> David
Re: Problem with Tooltips display on SVG Charts [message #243978 is a reply to message #243889] Thu, 21 June 2007 11:41 Go to previous message
Henry,
I have set this bug as P1. I am not sure if we can fix it for 2.2 as the
final release is in one week, but it looks like a serious issue. I believe
we can fix it for 2.1.3 though.
David
news:f5dtg6$huf$1@build.eclipse.org...
>> Thanks,
>> David
>>> versions. Is this a known bug?
>>>>release or 2.2 RC4?
>>>> Thanks,
>>>> David
>>>>> code adds a tooltip to each bar in the chart to display the bars value
>>>>> when the mouse is hovered over it. However, when I actually run it,
>>>>> the tooltip for each bar is the same - they all display the value of
Previous Topic:Using a Javascript function of a Library and display the result in a report
Next Topic:basic chart and XML data
Current Time: Sat Jul 26 09:28:34 EDT 2025
Powered by FUDForum. Page generated in 0.04994 seconds
