What is the data structure used in the Model Compare pane? [message #1386660] |
Thu, 19 June 2014 09:16 |
Could someone tell me which data is used for the tree structure in the bottom (Model Compare / Containment Features) is?
I have tweaked the Comparison which is the result of compare() but that seems to only effect the top window.
Am I correct in assuming that the entire, unmodified model is used in the bottom pane?
Mattias
Re: What is the data structure used in the Model Compare pane? [message #1386954 is a reply to message #1386660] |
Mon, 23 June 2014 08:55 |
Mattias,
The bottom pane of the compare configuration uses the models we have in memory, those that were provided through the IComparisonScope if you've launched the comparison directly through our APIs, or those that we have loaded ourselves in any other event (the loading takes place within ComparisonScopeBuilder#build(...) if you wish to debug).
You can alter the way these models are displayed by altering the generated ".edit" of your model, since we'll make use of that for these two(three) panes.
Laurent Goubet
Obeo
FUDForum. Page generated in 0.02745 seconds
