Home » Newcomers » Newcomers » -vm confusion
-vm confusion [message #243015] Thu, 13 December 2007 13:09 Go to next message
OK, so I'm running Eclipse on Windows
In the shortcut that I use to start Eclipse I put
-vm "c:\Program Files\Java\jre1.6.0_03\bin\javaw"
and Eclipse starts just fine. However when I put the following in the
eclipse.ini file
-vm
I get
Java Virtual Machine Launcher
Could not fine the main class. Program will exit.
and it then opens a window listing all the program arguments. According to
the on-line help this is the correct way to specify the JVM.
I suspect the problem is because there is a space in "Program Files" and
that this has exposed a bug in the Eclipse startup.
Does anyone know how to get around this bug?
Cheers, Eric
Re: -vm confusion [message #243016 is a reply to message #243015] Thu, 13 December 2007 14:03 Go to previous messageGo to next message
OK, now I'm questioning my sanity.
The eclipse.ini file is now working correctly with the following
-vm
I have no explanation - it just started working for no reason.
Cheers, Eric
Re: -vm confusion [message #243017 is a reply to message #243015] Thu, 13 December 2007 14:03 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Eric Kolotyluk" <eric.kolotyluk@kodak.com> wrote in message
news:5ccc07822fe71858b6c987cbd220055d$1@www.eclipse.org...
> eclipse.ini file
> -vm
Does it work if you put quote marks around that second line, just as you did
in the command-line version?
Re: -vm confusion [message #243026 is a reply to message #243016] Thu, 13 December 2007 16:30 Go to previous messageGo to next message
news:0e3b7ab2efaae79bef9063bec76efcbd$1@www.eclipse.org...
There's never any point in questioning your own sanity - if you're insane,
other people will question it for you :-)
Re: -vm confusion [message #243053 is a reply to message #243016] Fri, 14 December 2007 07:32 Go to previous messageGo to next message
Originally posted by: al_PUBLIC.gmx.de
On Thu, 13 Dec 2007 19:03:16 +0000 (UTC), eric.kolotyluk@kodak.com
> -vm
>Cheers, Eric
The eclipse.ini file is extremely fragile. If you've typed any sort of
whitespace after any of the lines in your .ini file it wouldn't work.
Achim
Eclipse Stammtisch Braunschweig/Wolfsburg/usw. am 18.12.2007
siehe http://www.bredex.de/de/news/eclipseregtable.html
Re: -vm confusion [message #243069 is a reply to message #243026] Fri, 14 December 2007 09:34 Go to previous messageGo to next message
And the definition of insanity is relative, anyway.
"A man talking sense to himself is no more insane than a man talking
nonsense not to himself...or just as insane."
-Rosencrantz and Guildenstern are Dead
Re: -vm confusion [message #243128 is a reply to message #243053] Fri, 14 December 2007 12:25 Go to previous messageGo to next message
> Achim
I may have left some whitespace, but I tried several times doing different
things.
At any rate every Java developer should learn about String.trim(), it
comes in really handy in cases like these ;-)
Cheers, Eric
Re: -vm confusion [message #243132 is a reply to message #243017] Fri, 14 December 2007 12:27 Go to previous messageGo to next message
I tried all variations of quotes I could think of, but that seemed to make
matters worse.
Cheers, Eric
Re: -vm confusion [message #243135 is a reply to message #243026] Fri, 14 December 2007 12:30 Go to previous message
OK, I couldn't stop laughing for 5 minutes because of you guys...
If I'm going insane, at least I'll go with a smile.
Cheers, Eric
Previous Topic:Problem for java client comsuming .net web services
Next Topic:Select Required Projects in Find Updates
Current Time: Fri Jul 25 22:01:44 EDT 2025
Powered by FUDForum. Page generated in 0.71933 seconds
