Home » Language IDEs » Java Development Tools (JDT) » Debugger stops at a breakpoint but has "lost its way"
Debugger stops at a breakpoint but has "lost its way" [message #242983] Thu, 19 April 2007 15:48 Go to next message
Since installing 3.3M6 I am continually experiencing a problem with the
debugger.
At least 50% of the time, the debugger apparently stops at a breakpoint
but has "lost its way":
a. The variables view is blank
b. The F5/6/7/8 keys do not respond
c. The debug view controls are greyed out
d. The list of threads in the debug view is collapsed (the
current thread is not expanded and the breakpoint not highlighted)
e. The debug view sometimes minimizes itself to a fast view
This did not happen previous to 3.3M6 that I noticed but it has become a
major annoyance. It often happens even as you are just stepping from line
to line -- suddenly the variables window goes blank, etc.
The (highly unsatisfactory) workaround is to go back to the debug view,
re-expand the thread you are interested in and double-click (a single
click doesn't do it) on the latest breakpoint. Sometimes that doesn't even
work and you have to keep selecting and deselecting entries in the thread
stack until it eventually rights itself.
The specific debugging scenario I have right now is that I am running
another version of Eclipse in the debugger while developing a plug-in.
I looked in bugzilla but couldn't find a bug that appears from the
description to be exactly like this so I thought I'd post to the forum
before raising a new bug.
Has anyone seen this or is it a known issue?
Best wishes, Ivan.
Re: Debugger stops at a breakpoint but has "lost its way" [message #242984 is a reply to message #242983] Thu, 19 April 2007 16:48 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Ivan Biddles" <ivanb@scientology.net> wrote in message
news:0643bc50664028e7be97606030b49ddf$1@www.eclipse.org...
> debugger.
Yes, it's a known issue (in fact I think I posted the bug number here a
couple days ago, or maybe it was on eclipse.platform).
It's fixed in recent builds. Pick up the latest I-build.
Re: Debugger stops at a breakpoint but has "lost its way" [message #244092 is a reply to message #242984] Tue, 29 May 2007 11:42 Go to previous message
This problem has shown up for several reasons and has been "fixed" several
times. The most recent issue was just fixed for RC2. If anyone sees this
problem using the latest integration build, please file a bug against JDT
Debug asap so we can look at it for 3.3.
Curtis
"Walter Harley" <wharley@bea.com> wrote in message
news:f08kil$jno$1@build.eclipse.org...
>> debugger.
Previous Topic:How do I find/read/write plug-in resources?
Next Topic:debug: conditional watchpoint?
Current Time: Fri Aug 22 23:47:09 EDT 2025
Powered by FUDForum. Page generated in 0.03973 seconds
