Branding lost upon workbench restart [message #242848] |
Thu, 20 May 2004 12:58  |
I'm currently using Eclipse's Install/Update manager to deliver my
feature, which contains 6 plugins (including a branding plugin), and is
marked as 'primary'. I am using a custom install handler to drop in a new
eclipseproduct file and a new config.ini file. After the initial
download/install, I am prompted to restart the workbench, and when I do I
get my splash screen, as well as the proper title at the top of the
eclipse window. Also, when I go to Help->About, I can see my feature
details and plugin details. In other words, everything seems to be
working properly.
When I restart the workbench the second time, however, the feature/plugin
details are lost. I still get the splash screen, but when I go to
Help->About->Feature/Plugin details, my feature and plugins show up with a
blank Provider and Plug-in Name (the version and Plug-in Id are still
there).
This is also causing the Product Configuration manager to bomb since it
apparently doesn't have the proper labels for the tree view it's creating.
As far as I can tell, all of my xml markup is properly configured. Does
anyone know of a good starting place to track this down? I'm using M8
eclipse.
Ryan
Re: Branding lost upon workbench restart [message #243233 is a reply to message #242848] |
Fri, 21 May 2004 12:41  |
Originally posted by: dorian.birsan.net
If your primary plugin id is different that the feature id, you see this
behavior. Pick up the M9 driver, it should have a fix for this.
"Ryan Hollom" <ryan.hollom@lawson.com> wrote in message
news:c8io2r$nl3$1@eclipse.org...
> working properly.
> there).
> eclipse.
> Ryan
FUDForum. Page generated in 0.06709 seconds
