Home » Eclipse Projects » GEF » Zest tree algorithms
Zest tree algorithms [message #242818] |
Fri, 09 May 2008 05:00  |
Originally posted by: ftordi.smaeur.com
I have currently some problem with tree and horizontal tree layout
algorithms. The problem is when there is multiple path to join a node some
nodes are placed exactly at the same place and overlapped.
Is there a way to change it?
Must I have to browse my nodes and replace it ?
Cheers Fabien
Re: Zest tree algorithms [message #243318 is a reply to message #243087] |
Mon, 02 June 2008 10:24   |
------=_Part_2125_5666164.1212416712697
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
Hey Fabien,
I had similiar trouble and i wrote a tree layout algorithm
I've attatched the file with the code.
cheers
michelle
Content-Type: application/octet-stream; name=gxtreelayoutalgorithm.java
Content-Disposition: attachment; filename=gxtreelayoutalgorithm.java
package com.softwareag.applinx.workbench.views.map;
import java.util.*;
import org.eclipse.zest.layouts.algorithms.AbstractLayoutAlgorithm;
import org.eclipse.zest.layouts.dataStructures.InternalNode;
import org.eclipse.zest.layouts.dataStructures.InternalRelationship ;
* A layout algorithm that spreads the directed graph as a tree from top down
* first a root is chosen (we offer a default way that may be overridden)
* then a tree is first spread from that root down in a grid fashion
* after which it is laid out bottom up to horizontally shift nodes.
* if the graph contains non connected subgraphs then the process of
* choosing a root and spreading it's child tree is continued.
* @author ilmta
public class GXTreeLayoutAlgorithm extends AbstractLayoutAlgorithm {
private double horSpacing = 40;
private double verSpacing = 60;
public GXTreeLayoutAlgorithm(int styles) {
super(styles);
protected void applyLayoutInternal(InternalNode[] entitiesToLayout, InternalRelationship[] relationshipsToConsider,
double boundsX, double boundsY, double boundsWidth, double boundsHeight) {
List<InternalNode> entitiesList = asList(entitiesToLayout);
List<InternalRelationship> relationshipsList = asList(relationshipsToConsider);
// --- build the node matrix without laying out first ---//
List<List<GXMoreThanNode>> rows = buildNodeMatrix(entitiesList, relationshipsList);
// --- layout the nodes --- //
// we're going to put them together bottom - up.
Collections.reverse(rows);
// the vertical size of a node line
int verticalLineSize = (int)(entitiesToLayout[0].getLayoutEntity().getHeightInLayou t() + verSpacing);
// the vertical location we begin placing the nodes from
int heightSoFar = (int) (((rows.size()-1) * verticalLineSize) + verSpacing);
// place bottom most row first - just center it.
List<GXMoreThanNode> childRow = rows.get(0);
int nodeSpacing = (int) (horSpacing + childRow.get(0).getNode().getLayoutEntity().getWidthInLayout ());
int x = (int) ((boundsWidth / 2) - ((childRow.size()/2) * nodeSpacing));
placeStrand(childRow, x, heightSoFar, nodeSpacing);
// place parent rows
List<GXMoreThanNode> parentRow;
// run through all parent rows
for (int i = 1; i < rows.size(); i++) {
// initialize stuff we'll need
parentRow = rows.get(i);
heightSoFar -= verticalLineSize;
placeRow(parentRow, heightSoFar);
* Lays out row with respect to it's children.
* @param yLocation - the vertical location to start placing the nodes.
* @param row - the row who's nodes we'd like to lay out.
private void placeRow(List<GXMoreThanNode> row, int yLocation) {
List<GXMoreThanNode> childlessStrand = new ArrayList<GXMoreThanNode>();
GXMoreThanNode parentLeft = null;
// for each parent in this parent row
for (int j = 0; j<row.size(); j++) {
GXMoreThanNode parentRight = row.get(j);
// if the node has children
if (!parentRight.getChildren().isEmpty()) {
// place the node in the center above his children
int parentX = 0;
for (GXMoreThanNode child:parentRight.getChildren()) {
parentX+=child.getX();
parentX /= parentRight.getChildren().size();
parentRight.setLocation(parentX, yLocation);
// and layout the childless strand
if (!childlessStrand.isEmpty()) {
placeChildless(childlessStrand, parentLeft, parentRight, yLocation);
childlessStrand.clear();
parentLeft = parentRight;
} else { // accumulate the childless nodes
childlessStrand.add(parentRight);
// place childless who are extra on the right. as in did not get taken care of when
// the parents were laid out.
placeChildless(childlessStrand, parentLeft, null, yLocation);
* Builds the matrix of nodes. each node will be wrapped with necessary innformation
* such as who are the direct children and parent (only visually in the graph not the
* actual relationships) the returned matrix is organized more or less as the real tree.
* @param entitiesList - entities to place in the matrix
* @param relationshipsList - the relationships between the entities given
* @return the matrix - (a list of rows of nodes)
private List<List<GXMoreThanNode>> buildNodeMatrix(List<InternalNode> entitiesList,
List<InternalRelationship> relationshipsList) {
List<List<GXMoreThanNode>> rows = new ArrayList<List<GXMoreThanNode>>();
while (!entitiesList.isEmpty()) {
InternalNode root = getFirstEntity(entitiesList, relationshipsList);
// add root row if necessary
if (rows.isEmpty()) {
rows.add(new ArrayList<GXMoreThanNode>());
// lay out the current root node and remove it from the list of entities left
entitiesList.remove(root);
GXMoreThanNode moreThanRoot = new GXMoreThanNode(root, null);
rows.get(0).add(moreThanRoot);
// build the tree that spreads from this current root.
builtTreeFromRoot(moreThanRoot, entitiesList, relationshipsList, rows.get(1), rows);
trimEmptyRows(rows);
return rows;
* Remove rows that are empty. This should only be the last row but since it's not too expensive
* better safe than sorry.
* @param rows - to trim
private void trimEmptyRows(List<List<GXMoreThanNode>> rows) {
List<List<GXMoreThanNode>> rowsCopy = new ArrayList<List<GXMoreThanNode>>(rows);
for (List<GXMoreThanNode> row:rowsCopy) {
if (row.isEmpty()) {
rows.remove(row);
* A childless stran is a "problem" in general because they break the evenness of the tree
* There are three types of such strands,
* extra nodes to the left, extra to the right, or extra in between parents.
* This method places those strands in spot.
* @param childlessStrand - the childless node to be laid out.
* @param parentLeft - the nearest parent on the left (or <value>null</value> if none such exists)
* @param parentRight - the nearest parent on the right (or <value>null</value> if none such exists)
* @param yLoc - the vertical location to lay out the nodes on.
private void placeChildless(List<GXMoreThanNode> childlessStrand,
GXMoreThanNode parentLeft, GXMoreThanNode parentRight, int yLoc) {
int startMark = 0;
int spacing = (int)(childlessStrand.get(0).getNode().getLayoutEntity().get WidthInLayout() + horSpacing);
// There's only a parent on the right
if (parentLeft==null && parentRight!=null) {
startMark = parentRight.getX() - (spacing *childlessStrand.size());
} // there's a parent on the left
else if ( parentLeft!=null) {
startMark = parentLeft.getX() + spacing;
// there's a parent on the right as well meaning the childless are between two parents
// we need to make there's enough room to place them
if (parentRight != null) {
int endMark = startMark + (spacing*childlessStrand.size());
// if there isn't enough room to place the childless between the parents
if (endMark > parentRight.getX()) {
// shift everything on the right to the right by the missing amount of space.
shiftTreesRightOfMark(parentRight, endMark - parentRight.getX());
// now the room has been assured, place strand.
placeStrand(childlessStrand,startMark , yLoc, spacing);
* Shifts the trees right of mark node
* @param mark to shift from
* @param shift - factor by which to move right by.
private void shiftTreesRightOfMark(GXMoreThanNode mark, int shift) {
mark.setLocation(mark.getX() + shift, mark.getY());
GXMoreThanNode leftMostChild = getRightMostChild(mark);
List<GXMoreThanNode> treeRoots = leftMostChild.getRow().subList(leftMostChild.getRow().indexO f(leftMostChild), leftMostChild.getRow().size());
for (GXMoreThanNode root : treeRoots) {
shiftTree(root, shift);
* Returns the right most child of parent
* @param parent
* @return the right most child of parent given.
private GXMoreThanNode getRightMostChild(GXMoreThanNode parent) {
GXMoreThanNode rightMost = parent.getChildren().get(0);
// run through children
for (GXMoreThanNode child:parent.getChildren()) {
if (child.getX() < rightMost.getX()) {
rightMost = child;
return rightMost;
* Shifts the given tree by the shift factor given to the right.
* @param root - root of tree to shift
* @param shift - factor to shirt by
private void shiftTree(GXMoreThanNode root, int shift) {
root.setLocation(root.getX() + shift, root.getY());
for (GXMoreThanNode child : root.getChildren()) {
shiftTree(child, shift);
* Places the list of nodes horizontally at the given point and
* spaced on horizontally by given spacing.
* @param strand - list of nodes to be laid out.
* @param x - location to begin the placing
* @param y - vertical location to lay out the entire list.
* @param spacing the horizontal spacing between nodes.
private void placeStrand(List<GXMoreThanNode> strand,
int x, int y, int spacing) {
for (GXMoreThanNode item : strand) {
item.setLocation(x, y);
x += spacing;
* follows the root by all its children to wrap the all up with all the
* extra info needed and adds the tree to the matrix.
* @param currRoot - root to go over tree from
* @param entitiesList - entities available
* @param relationshipsList - relationship between the given entities
* @param currRow - the current row in the matrix we are working on
* @param rows - the matrix.
private void builtTreeFromRoot(GXMoreThanNode currRoot, List<InternalNode> entitiesList,
List<InternalRelationship> relationshipsList,
List<GXMoreThanNode> currRow, List<List<GXMoreThanNode>> rows) {
// this is the first node that comes from the currRoot
// we'll use the mark to know where to continue laying out from
GXMoreThanNode mark = null;
List<InternalRelationship> relationshipsListCopy = new ArrayList<InternalRelationship>(relationshipsList);
// Orders the children of the currRoot in the given row (the row under it)
for (InternalRelationship rel: relationshipsListCopy) {
if (currRoot.getNode().equals(rel.getSource())) {
InternalNode destNode = rel.getDestination();
// if the destination node hasn't been laid out yet
if (entitiesList.contains(destNode)){
// place it in the row (as in lay it out)
GXMoreThanNode currNode = new GXMoreThanNode(destNode, currRoot.getNode());
currRoot.addChild(currNode);
currRow.add(currNode);
currNode.addedToRow(currRow);
entitiesList.remove(destNode);
// if this is the first node, save it as a mark.
if (mark == null) {
mark = currNode;
// remove the relationship since both of its ends have been laid out.
relationshipsList.remove(rel);
// if new children have been added
if (mark != null) {
// Create a next row if necessary
if (rows.size()-1 <= rows.indexOf(currRow)) {
List<GXMoreThanNode> nextRow = rows.get(rows.indexOf(currRow)+1);
for (int i = currRow.indexOf(mark); i<currRow.size(); i++ ) {
builtTreeFromRoot(currRow.get(i), entitiesList, relationshipsList, nextRow, rows);
* Currently we will arbitrarily choose the first node that is not a destination i.e. it's a starting point\
* if none such exists we will choose a random node.
private InternalNode getFirstEntity(List<InternalNode> entitiesList, List<InternalRelationship> relationshipsList) {
List<InternalNode> entitiesLeft = new ArrayList<InternalNode>(entitiesList);
// go through all the relationships and remove destination nodes
for (InternalRelationship rel:relationshipsList) {
entitiesLeft.remove(rel.getDestination());
if (!entitiesLeft.isEmpty()) {
// throw in random for fun of it
// return entitiesLeft.get((int)(Math.round(Math.random()*(entitiesLef t.size()-1))));
return entitiesLeft.get(0);
// if all the nodes were destination nodes then return a random node.
// return entitiesList.get((int)(Math.round(Math.random()*(entitiesLis t.size()-1))));
return entitiesList.get(0);
* Returns an ArrayList containing the elements from the given array.
* It's in a separate method and to make sure a new ArrayList is created
* since Arrays.asList(T ...) returns an unmodifiable array and throws runtime
* exceptions when an innocent programmer is trying to manipulate the resulting list.
* @param <T>
* @param entitiesToLayout
* @return
private <T> List<T> asList(T[] entitiesToLayout) {
return new ArrayList<T>(Arrays.asList(entitiesToLayout));
protected int getCurrentLayoutStep() {
// do nothing
return 0;
protected int getTotalNumberOfLayoutSteps() {
// do nothing
return 0;
protected boolean isValidConfiguration(boolean asynchronous, boolean continuous) {
// do nothing
return true;
protected void postLayoutAlgorithm(InternalNode[] entitiesToLayout, InternalRelationship[] relationshipsToConsider) {
// do nothing
protected void preLayoutAlgorithm(InternalNode[] entitiesToLayout, InternalRelationship[] relationshipsToConsider,
double x, double y, double width, double height) {
// do nothing
// entitiesToLayout[0].getLayoutEntity().
public void setLayoutArea(double x, double y, double width, double height) {
// do nothing
public double getHorSpacing() {
return horSpacing;
public void setHorSpacing(double horSpacing) {
this.horSpacing = horSpacing;
public double getVerSpacing() {
return verSpacing;
public void setVerSpacing(double verSpacing) {
this.verSpacing = verSpacing;
* wraps a node with useful info like parent and children etc.
private class GXMoreThanNode {
private InternalNode m_node;
private InternalNode m_parent;
private List<GXMoreThanNode> m_children;
private List<GXMoreThanNode> m_row;
private boolean m_located = false;
private int m_y;
private int m_x;
public GXMoreThanNode(InternalNode node, InternalNode parent) {
m_node = node;
m_parent = parent;
m_children = new ArrayList<GXMoreThanNode>();
public void addedToRow(List<GXMoreThanNode> row) {
m_row = row;
public void setLocation(int x, int y) {
m_x = x;
m_y = y;
m_node.setLocation(x, y);
setLocated(true);
public void addChild(GXMoreThanNode currNode) {
m_children.add(currNode);
public List<GXMoreThanNode> getChildren() {
return m_children;
public void setLocated(boolean located) {
m_located = located;
public boolean isLocated() {
return m_located;
public InternalNode getNode() {
return m_node;
public InternalNode getParent() {
return m_parent;
public int getY() {
return m_y;
public void setY(int y) {
m_y = y;
public int getX() {
return m_x;
public void setX(int x) {
m_x = x;
public List<GXMoreThanNode> getRow() {
return m_row;
------=_Part_2125_5666164.1212416712697--
Re: Zest tree algorithms [message #243359 is a reply to message #243355] |
Tue, 03 June 2008 10:32  |
In fact I don't really know how to send a file into the newgroup
but I give you a link to show what I told.
http://dl.free.fr/eVrc5ViVZ/Capture.png
as you can see there is a link which point to the gray box and it comes
from the bottom of the graph. It's a big tree with complicated
dependencies.
I'm sorry if I'm not clear. So I'll try to talk clearer.
Current Time: Thu Jul 17 06:27:40 EDT 2025
Powered by FUDForum. Page generated in 0.06000 seconds
