Problem with Word, Excel, and PowerPoint Emitters in 2.2.1.1 [message #242718] |
Mon, 10 December 2007 16:30  |
Originally posted by: brian.metier.com
I was using BIRT 2.2.1 when it first came out, and I was able to
successfully build .rptdesign files with the RCPDesigner and run them
through the BIRT Runtime (servlet). I was also able to see the correct
emitted output as Excel, Powerpoint, and Word.
I have now upgraded to BIRT 2.2.1.1, and I'm trying the simplest test
with only using the RCPDesigner.
I create an rptdesign file and put 1 label on the page that just says
"Test"
I then choose File > View Report > View Report As DOC, and what opens
in Microsoft Word is the base XML for the word file:
"<?xml version="1.0" encoding="UTF-8"?>
<?mso-application progid="Word.Document"?>
<w:wordDocument
xmlns:w="http://schemas.microsoft.com/office/word/2003/wordml"
xmlns:v="urn:schemas-microsoft-..."
Any ideas what may have caused this with BIRT 2.2.1.1?
Am I possibly missing a file or something?
-Brian
Re: Problem with Word, Excel, and PowerPoint Emitters in 2.2.1.1 [message #242726 is a reply to message #242718] |
Mon, 10 December 2007 17:22  |
Brian P. wrote:
> "Test"
> <w:wordDocument
> -Brian
Hi Brian. I think you'll have better luck in the BIRT newsgroup
(eclipse.birt). HTH. Mark
FUDForum. Page generated in 0.11727 seconds
