Home » Archived » BIRT » Incomplete bars in Eclipse 3.3. BIRT 2.2
Incomplete bars in Eclipse 3.3. BIRT 2.2 [message #242716] Thu, 14 June 2007 10:02 Go to next message
I have this application that works fine in Eclipse 3.2, BIRT 2.1 but I
just tried it with Eclipse 3.3. BIRT 2.2 RCO(or could be RC1). Basically I
have some bar charts. When another application is opened, such as firefox,
such that the view is blocked by the new window, when the window is
minimized, all the drawing in the charts is erased, and the view has to be
closed and re-opened before the charts appear correctly again. I briefly
looked into it, and it seems like the problem happens in the
adjustHorizontal method of PlotWithAxes or in some other place where some
scaling algorithm is used. So I was wondering if this bug is already
known, if not then I will investigate the problem and open a new bug
thanks
Re: Incomplete bars in Eclipse 3.3. BIRT 2.2 [message #242740 is a reply to message #242716] Thu, 14 June 2007 11:22 Go to previous message
I do not know about this issue. Your chart is SWT-based? Sounds like a
painting problem of the SWT canvas, since the window overlap won't trigger
any chart regeneration.
David
"Raheel Ashraf" <rashraf@ca.ibm.com> wrote in message
news:5731791fd9c7c05d9d8cc7075bc75389$1@www.eclipse.org...
> thanks
Previous Topic:Thanks, but...
Next Topic:Birt reports (Batch File)
Current Time: Sun Jul 13 07:43:43 EDT 2025
Powered by FUDForum. Page generated in 0.03529 seconds
