Home » Language IDEs » Java Development Tools (JDT) » Absolute path of a resource in the classpath
Absolute path of a resource in the classpath [message #242712] Wed, 11 April 2007 06:10 Go to next message
Hi there!
I have to find the absolute path (URL) of a resource that lies in a JAR
file in the classpath of a Java project. All I know is the
classpath-relative path of this resource. With pure Java, this can be
done very easy over the classloader like this:
URL absolute =
this.getClass().getClassLoader().getResource("conf/meta-model/MyModel.edsmm ");
Because I need to do this in a plugin, i can't use the classloder. I
have to do this with help of an IJavaProject.
I know there is a way to get resources by iterating over the package
fragments of the project and doing a getNonJavaResources() at the right
fragment, but this is a very complicated solution with several loops,
sub-loops and checks.
Isn't there an easier way to do this? Normally, using eclipse should
make things simpler ;-).
Roger
Re: Absolute path of a resource in the classpath [message #242751 is a reply to message #242712] Wed, 11 April 2007 14:00 Go to previous messageGo to next message
Take a look at JavaCore.getResolvedClasspathEntry()
Genady Beryozkin
http://www.genady.net/
Roger Villars wrote:
> Hi there!
> URL absolute =
> right fragment, but this is a very complicated solution with several
> loops, sub-loops and checks.
> Thanks
> Roger
Re: Absolute path of a resource in the classpath [message #242761 is a reply to message #242751] Thu, 12 April 2007 04:28 Go to previous message
Thank you for the answer Genady.
Hmmm, correct me if I'm wrong. With getResolvedClasspathEntry() I get an
IClasspathEntry holding the resolved path of a given IClasspathEntry.
An IClasspathEntry represents a library, a JAR or a referenced project.
The problem is, that I don't know in which JAR my resource lies. That is
what I try to find out. I only know that I is somewhere in the projects
classpath.
Roger
> Genady Beryozkin
>> Hi there!
>> URL absolute =
>> Thanks
>> Roger
Previous Topic:Error opening JarFile
Next Topic:classpathContainerPage edit
Current Time: Thu Jul 17 06:04:51 EDT 2025
Powered by FUDForum. Page generated in 0.08550 seconds
