Home » Eclipse Projects » Eclipse Platform » Gettin error trying to run 3.0M8
Gettin error trying to run 3.0M8 [message #242686] Wed, 19 May 2004 17:58 Go to next message
Originally posted by: ajudish.lextron-inc.com
I just installed 3.0M8 on Windows2000. When I run eclipse get error to check
the log. Contents below. Why do I get this? I installed 2.1.3 and it
starts ok.
!SESSION ------------------------------------------------------------ -------
!ENTRY org.eclipse.core.launcher 4 0 May 19, 2004 15:57:04.876
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.IllegalAccessError: try to access method
java.io.FileOutputStream.<init>(Ljava/io/File;Z)V from class
org.eclipse.osgi.framework.util.SecureAction
org.eclipse.osgi.framework.util.SecureAction.getFileOutputSt ream(SecureActio
n.java:102)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultLo g.openFile(Defau
ltLog.java:106)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultLo g.log(DefaultLog
..java:146)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:125)
at java.lang.reflect.Method.invoke(Native Method)
at org.eclipse.core.launcher.Main.basicRun(Main.java:267)
at org.eclipse.core.launcher.Main.run(Main.java:692)
at org.eclipse.core.launcher.Main.main(Main.java:676)
Re: Gettin error trying to run 3.0M8 [message #242690 is a reply to message #242686] Wed, 19 May 2004 19:14 Go to previous message
See the download page for the full details but ensure that you are launching
Eclipse using at least 1.4.1 VM.
To ensure success use the -vm option
HTH
Darins
"Anthony Judish" <ajudish@lextron-inc.com> wrote in message
news:c8gkt0$lo2$1@eclipse.org...
check
> starts ok.
> !STACK
> at
> n.java:102)
> at
> ltLog.java:106)
> at
> .java:146)
> at
Previous Topic:ResourceNavigator in RCP application
Next Topic:Can I create custom Plugin ClassLoader?
Current Time: Thu Jul 17 20:31:48 EDT 2025
Powered by FUDForum. Page generated in 0.03899 seconds
