Home » Eclipse Projects » GEF » Problems importing GraphVisitor
Problems importing GraphVisitor [message #242680] Sun, 04 May 2008 05:52 Go to next message
Originally posted by: massimoarra.gmail.com
I'm trying to run the SchemaEditor example
( http://www.eclipse.org/articles/Article-GEF-editor/gef-schem a-editor.html),
but the import org.eclipse.draw2d.internal.graph.GraphVisitor cannot be
resolved.
I'm using Eclipse Ganymede 3.4 and GEF 3.4.0.
How can I resolve the import?
Massimo
Re: Problems importing GraphVisitor [message #242685 is a reply to message #242680] Sun, 04 May 2008 11:41 Go to previous messageGo to next message
Hi Massimo,
The example does not work on any GEF later than GEF 3.1.2.
I was able to get the example working on GEF 3.3(3.4) by commenting out
NodeJoiningDirectedGraphLayout in DirectedGraphLayoutVisitor and removing
NodeJoiningDirectedGraphLayout and DummyEdgeCreator. Not sure what other
changes I had to make.
I wanted to update this article with working source code, but have not had
the time. Hopefully June/July/Aug I will get the time....
Cheers...
Anthony
"Massimo" <massimoarra@gmail.com> wrote in message
news:880799b978b7ee59b50964d0aa93707d$1@www.eclipse.org...
> resolved. I'm using Eclipse Ganymede 3.4 and GEF 3.4.0.
> Thanks
> Massimo
Re: Problems importing GraphVisitor [message #246276 is a reply to message #242685] Tue, 18 November 2008 01:42 Go to previous messageGo to next message
I am too facing the same problem .Did you got the solution for it.If it
so, please forward me your solution.Your needful help will be appreciated.
Ashish Naidu.
Re: Problems importing GraphVisitor [message #479088 is a reply to message #246276] Sat, 08 August 2009 21:01 Go to previous message
Originally posted by: aroberts.arcalot.demon.co.uk
Has anyone thought about updating / fixing Phil Zoio "Building a Database
Schema Diagram Editor with GEF" on the site? As it's suffering from the
same GraphVisitor issue:
http://eclipse.org/articles/Article-GEF-editor/gef-schema-ed itor.html
Same applies to: http://dbschemaviewer.sourceforge.net/ .
"Ashish Naidu" <ashish.naidu15@gmail.com> wrote in message
news:adfabad2c0b95857ab67a943fc1b8cd3$1@www.eclipse.org...
> Ashish Naidu.
Previous Topic:Large no of figures to be rendered
Next Topic:drag and drop and ContainerEditPolicy ?
Current Time: Sat Jul 12 02:06:24 EDT 2025
Powered by FUDForum. Page generated in 0.03863 seconds
