Home » Archived » BIRT » How to create a table with unknown number of columns on creation time?
How to create a table with unknown number of columns on creation time? [message #242662] Thu, 14 June 2007 05:12 Go to next message
Originally posted by: limorl.il.ibm.com
I have a apecial case - I know the number of columns only in run-time,
when I get the data (I use scripted data source, and the data is coming
from a Map object).
So when I create the table I don't know how many columns I would have. Is
there any way to determine it dynamically?
Thanks in advance,
Limor
Re: How to create a table with unknown number of columns on creation time? [message #242701 is a reply to message #242662] Thu, 14 June 2007 09:00 Go to previous message
Hello limor,
may you have a look at crosstables:
http://www.eclipse.org/birt/release20specs/BPS1/BPS1_CrossTa b_SPEC.pdf
http://www.eclipse.org/birt/phoenix/project/notable2.2RC0.ph p
Hope that helps!
Previous Topic:How to use styles in crosstables
Next Topic:General BIRT Question
Current Time: Fri Jul 18 13:30:39 EDT 2025
Powered by FUDForum. Page generated in 0.52863 seconds
