Home » Eclipse Projects » GEF » Zest layouts in GEF viewer
Zest layouts in GEF viewer [message #242607] Tue, 29 April 2008 08:39 Go to next message
Originally posted by: ftordi.smaeur.com
Hi there!
I needs to display a graph structure into a GEF graphical viewer and my
node size has to be fixed by the application.
My problem is that I use Zest Layouts and I don't how to compute the size
of the whole area to fit my graph.
The size of the container should be resized depending on contained nodes.
That's why the method applyLayout(...) in Zest LayoutAlgorithms cause to
me some troubles.The node shouldn't overlaps.
The problem is that computing the size is totally depends on the layout
applied and I would like to know if it's possible for Zest to resize
automatically my area.
- I try to use the layout style ENFORCE_BOUNDS but it resize a little and
all Figures overlaps.
- I try to use CompositeLayout with Horizontal shift with the
DirectedGraphLayout but bounds are not really enforced the figure is
calculated in a negative zone.
- I try Horizontal shift with other layouts but the result seems to be
unchanged. All contained figures are size fixed that's why the
NO_LAYOUT_NODE_RESIZING.
Is there a method to dynamically resize or compute the size of the area?
I've exported my application in an RCP app, can you take a look :
- change the layout algorithm by selecting algorithm of the combobox into
the upper side and see that my area size is bad calculated.
-I've attached the source code in the jar, the bad computation is located
in com.sma.ui.pert.model.ScheduleModel:applyLayout()
Here is a link of my RCP app and source code:
http://download374.mediafire.com/l3fsdsibyrfg/gtzl2x9ctcp/Pe rt.zip
Re: Zest layouts in GEF viewer [message #242633 is a reply to message #242607] Tue, 29 April 2008 21:52 Go to previous messageGo to next message
Maybe this would give some hint.
http://www.eclipse.org/pde/incubator/dependency-visualizatio n/index.php
which use zest.
Qinxian
Fabien 写道:
> Hi there!
> size of the whole area to fit my graph.
> nodes. That's why the method applyLayout(...) in Zest LayoutAlgorithms
> cause to me some troubles.The node shouldn't overlaps.
> and all Figures overlaps.
> I've exported my application in an RCP app, can you take a look : -
Re: Zest layouts in GEF viewer [message #242649 is a reply to message #242633] Wed, 30 April 2008 09:32 Go to previous message
Thanks for your answer
The problem is the example use only a directed graph layout and I have to
use all off zest layouts.
I try Horizontalshift with other layouts but Spring layout and radial
layout
don't looks like something. The only way seems to be calculating the size
that I should use.
Is there a way to calculate this size properly?
cheers,
Fabien
Qinxian wrote:
> which use zest.
> Cheers,
> Qinxian
> Fabien 写道:
>> Hi there!
Previous Topic:Newbie needs some basic info
Next Topic:Resizing editor's FigureCanvas
Current Time: Tue Jul 22 20:11:13 EDT 2025
Powered by FUDForum. Page generated in 0.09243 seconds
