Home » Newcomers » Newcomers » Where to put the code for connecting to a server
Where to put the code for connecting to a server [message #242578] Sat, 08 December 2007 13:33 Go to next message
Originally posted by: housh_housh.yahoo.com
I want to speak to a JBOSS App-Server from my RCP App.
I have added a button to the toolbar and written a ConnectionAction. I
just put the JNDI code for connecting to the server into the run()
methon of my ConnectionAction.
Would you place the connection code somewhere else?
Although I have all the JBOSS Client Jars in my build-path I get
billions of class-loading exceptions (which I don't get from a "normal"
Java Client with the same JNDI code). Any ideas on that?
Thank you very much,
ex
Re: Where to put the code for connecting to a server [message #242629 is a reply to message #242578] Mon, 10 December 2007 07:25 Go to previous messageGo to next message
Originally posted by: jakub.jurkiewicz.gmail.com
exquisitus pisze:
> Hello,
> ex
How did you add these jars to the build path? If you want to use them in
a plugin then you should add them to the Classpath section of the
Runtime tab in the plugin.xml file.
Hope this helps,
Jakub
http://eclipser-blog.blogspot.com
Re: Where to put the code for connecting to a server [message #242703 is a reply to message #242629] Mon, 10 December 2007 16:03 Go to previous message
Thank you very much for your answer.
I wasn't aware about the fact that every plugin has its own classpath.
When I go to the "runtime" tab I just have a New and a Add button. Do I
have to add every jar of JBOSS one by one? Is there a way to add all the
Jars to the plugin's classpath at once?
again thanx,
ex
Jakub Jurkiewicz wrote:
> exquisitus pisze:
>> Hello,
>> ex
> Hope this helps,
> Jakub
Previous Topic:What is the Search icon?
Next Topic:Pattern EMF
Current Time: Sun Jul 13 16:34:40 EDT 2025
Powered by FUDForum. Page generated in 0.10044 seconds
