Home » Eclipse Projects » Nebula » org.eclipse.swt.nebula.widgets.pgroup.internal.GraphicsUtils missing from nebula_pshelf_ALPHA.jar
org.eclipse.swt.nebula.widgets.pgroup.internal.GraphicsUtils missing from nebula_pshelf_ALPHA.jar [message #23826] Sun, 21 January 2007 11:31 Go to next message
Hi.
I just tried getting PShelf to work with RedmondShelfRenderer - but I
got the following errors:
Exception in thread "main" java.lang.NoClassDefFoundError:
org/eclipse/swt/nebula/widgets/pgroup/internal/GraphicUtils
org.eclipse.swt.nebula.widgets.pshelf.RedmondShelfRenderer.i nitialize(RedmondShelfRenderer.java:210)
org.eclipse.swt.nebula.widgets.pshelf.PShelf.setRenderer(PSh elf.java:191)
Seems like you've forgot to add some internal utility classes.
Daniel Holmen
Re: org.eclipse.swt.nebula.widgets.pgroup.internal.GraphicsUtils missing from nebula_pshelf_ALPHA.ja [message #24372 is a reply to message #23826] Wed, 24 January 2007 17:49 Go to previous messageGo to next message
Hi Daniel,
When did you download the version? There was a messed up jar at some
point. It was fixed quite a while ago I believe. I just downloaded the
jar again and it seems fine. Can you try downloading the current version.
-Chris
Daniel Holmen wrote:
> Hi.
> at
> at
> Daniel Holmen
Re: org.eclipse.swt.nebula.widgets.pgroup.internal.GraphicsUtils missing from nebula_pshelf_ALPHA.ja [message #24453 is a reply to message #24372] Wed, 24 January 2007 18:05 Go to previous messageGo to next message
Actually I have to take this back. I just realized that the project in
which I've been testing the jar files had the actual nebula project
itself in the build path (doh!). I apologize. I'll post an updated jar
on the download site momentarily.
-Chris
p.s. FWIW, I am working on getting an automated build for Nebula so that
these things dont happen in the future.
Chris Gross wrote:
> Hi Daniel,
> -Chris
>> Hi.
>> at
>> at
>> Regards,
>> Daniel Holmen
Re: org.eclipse.swt.nebula.widgets.pgroup.internal.GraphicsUtils missing from ne [message #24873 is a reply to message #24453] Mon, 29 January 2007 06:30 Go to previous message
Thanks, Chris.
It works perfectly now.
Re: org.eclipse.swt.nebula.widgets.pgroup.internal.GraphicsUtils missing from nebula_pshelf_ALPHA.ja [message #575686 is a reply to message #23826] Wed, 24 January 2007 17:49 Go to previous message
Hi Daniel,
-Chris
> Hi.
> at
> at
> Daniel Holmen
Re: org.eclipse.swt.nebula.widgets.pgroup.internal.GraphicsUtils missing from nebula_pshelf_ALPHA.ja [message #575782 is a reply to message #24372] Wed, 24 January 2007 18:05 Go to previous message
-Chris
Chris Gross wrote:
> Hi Daniel,
> -Chris
>> Hi.
>> at
>> at
>> Regards,
>> Daniel Holmen
Re: org.eclipse.swt.nebula.widgets.pgroup.internal.GraphicsUtils missing from ne [message #576060 is a reply to message #24453] Mon, 29 January 2007 06:30 Go to previous message
Thanks, Chris.
Previous Topic:When does the IBM Corporation plan to release this widget ?
Next Topic:Grid item updates
Current Time: Sat May 10 23:15:52 EDT 2025
Powered by FUDForum. Page generated in 0.05959 seconds
