Clone GEF file [message #242519] |
Wed, 23 April 2008 06:51 |
Originally posted by: coolbird.gmail.com
<b>I want to add a button in the toolbar
When I click the button,
the graph will be copied and saved as a new file.
For example, there is a file named diagram-01.
When you click the button, this file would be copied and saved as diagram-02 automatically.
There is a rectangular in the diagram-02.This is correct,
But if I were to draw a circle, and then clicking the button to copy as diagram-03.
There are a rectangular and a circle in the diagram-03. It's correct, too.
But if I open the diagram-02, will find that there is only a rectangular in the diagram-02.
It seems diagram-02 didn't save before open diagram-03.
I try to call doSave() first, but the same result.
follows are code,if anything wrong?</b>
public void doFastCopy() {
doSave();
ByteArrayOutputStream out = new ByteArrayOutputStream();
try {
ObjectOutputStream oos = new ObjectOutputStream(out);
oos.writeObject(contentsModel);
oos.close();
// get now file name and add 1;
IFile file = ((IFileEditorInput) getEditorInput()).getFile();
setInput(new FileEditorInput(file));
IPath path= file.getFullPath();
String oldFileName = path.removeFileExtension().lastSegment();
int fileNumber=Integer.parseInt(oldFileName.substring(oldFileNam e.length()-1,oldFileName.length()));
String newFileName = oldFileName.replace(String.valueOf(fileNumber), String.valueOf(fileNumber+1));
IPath path2=path.removeLastSegments(1);
path2=path2.append(newFileName);
path2=path2.addFileExtension("sketch");
// create new file
final IFile file2 = ResourcesPlugin.getWorkspace().getRoot().getFile(path2);
file2.create(
new ByteArrayInputStream(out.toByteArray()), // contents
true, // keep saving, even if IFile is out of sync with the Workspace
null); // progress monitor
setInput(new FileEditorInput(file2));
getCommandStack().markSaveLocation();
catch (CoreException ce) {
ce.printStackTrace();
catch (Exception ioe) {
ioe.printStackTrace();
public void doSave(IProgressMonitor monitor) {
try {
oos.writeObject(getModel());
oos.close();
file.setContents(new ByteArrayInputStream(out.toByteArray()), true,true,monitor);
} catch (CoreException ce) {
} catch (IOException ioe) {
catch (Exception ex) {
ex.printStackTrace();
FUDForum. Page generated in 0.05812 seconds
