Home » Archived » Memory Analyzer (MAT) » Static fields and heap usage
Static fields and heap usage [message #2029] Wed, 30 April 2008 12:26 Go to next message
I am using MAT to analyse an application which uses GEF (http://www.eclipse.org/gef).
For each org.eclipse.draw2d.geometry.Rectangle instance the "Shallow Heap" and "Retained Heap" indicate both 24.
Below is the fields of Rectangle class :
/** the X value */
public int x;
/** the Y value */
public int y;
/** the width*/
public int width;
/** the height */
public int height;
/**A singleton for use in short calculations. Use to avoid newing unnecessary objects.*/
public static final Rectangle SINGLETON = new Rectangle();
static final long serialVersionUID = 1;
How is made the calculation ?
24 = 4 integers * 4 bytes + 1 long * 8 bytes (which seems me false)
24 = 4 integers * 4 bytes + methods and virtual methods table
24 = something else
Thanks for your answers,
Mariot
Re: Static fields and heap usage [message #2043 is a reply to message #2029] Thu, 01 May 2008 17:53 Go to previous messageGo to next message
Hi Mariot,
the size of java.lang.Object is 2 times the identifier size (32 or 64 bit).
Assuming a 32bit VM, this means for the draw2d.geometry.Rectangle:
24 = size of java.lang.Object (8) + 4 Integers á 4 bytes
Just in case you are wondering a/b other objects:
Object sizes are aligned up to a multiple of 8. That means a class A with
just a byte field has a size of 16 (8 bytes object header from
java.lang.Object + 1 byte field + 7 bytes alignment). This alignment can
occur at every inheritance level: class B extending class A and again only
declaring one byte field would waste a total of 14 bytes.
Kind regards,
Andreas.
Re: Static fields and heap usage [message #2057 is a reply to message #2043] Fri, 02 May 2008 03:10 Go to previous message
Hi Andreas,
Thanks for the clear explanation.
Mariot
Andreas Buchen wrote :
> Hi Mariot,
> with just a byte field has a size of 16 (8 bytes object header from
> only declaring one byte field would waste a total of 14 bytes.
> Kind regards,
> Andreas.
Previous Topic:Blog: Immortal Objects - Or: How to Find Memory Leaks
Next Topic:No application id has been found.
Current Time: Sun Jul 13 08:25:17 EDT 2025
Powered by FUDForum. Page generated in 0.05078 seconds
