Home » Archived » Riena » Create Application model depending on login information
Create Application model depending on login information [message #23776] |
Mon, 30 March 2009 03:44  |
I want to create my application model depending on the current users
permissions.
The problem is that IApplicationNode.createModel() is called before login
has been performed.
Is there any possibility to manipulate the displayed model nodes after
login? Or is there any out of the box solution for this?
Thanks and greetz,
Carsten
Re: Create Application model depending on login information [message #24053 is a reply to message #24021] |
Wed, 01 April 2009 04:57   |
Hi Carsten,
you are right class UIFilterRuleNavigationHiddenMarker is internal and
so should be used only with caution, because this code may undergo
changes. May be you file a bugzilla request which describes your problem
and mentions that class UIFilterRuleNavigationHiddenMarker is internal.
The gray "placeholder" seems to be a refresh problem. Can you file
bugzilla request for that? Is it a submodule your are hiding?
Regards, Frank
Carsten Spieker wrote:
> Hi Frank,
> thanks for your reply!
> I tried the way you explained via the UIFilter. Unfortunately I have two
> problems with this solution:
> 1) The class UIFilterRuleNavigationHiddenMarker seems to be internal.
> 2) The UI shows a bad looking gray "placeholder" where the now hidden
> navigation node was displayed before until I "click" somewhere in the UI
> (maybe this is only a refresh problem?)
> Greetz,
> Carsten
> "Frank Schepp" <Frank.Schepp@compeople.de> schrieb im Newsbeitrag
> news:gqqqia$un0$1@build.eclipse.org...
>> Hi Carsten,
>> you are right in case you use the splash login view (its different for the
>> login dialog view). The splash login view is brought up when the workbench
>> is created and that is after createModel() was called. I think you can use
>> the riena ui filters (see http://wiki.eclipse.org/Riena_UI_filters) to
>> manipulate the displayed model nodes based on permissions. Override the
>> createView() method of your application class (subclass of SwtApplication)
>> like this:
>> @Override
>> public Object createView(IApplicationContext context, IApplicationNode
>> pNode) {
>> Collection<IUIFilterRule> rules = new ArrayList<IUIFilterRule>(1);
>> // hidden marker for all children of application node
>> IUIFilterRule filterRule = new UIFilterRuleNavigationHiddenMarker("/" +
>> pNode.getNodeId().getTypeId() + "/*") {
>> @Override
>> public boolean matches(Object... args) {
>> return super.matches(args) && !getPermission(args);
>> private boolean getPermission(Object... args) {
>> boolean permission = true;
>> if (args[0] instanceof INavigationNode<?>) {
>> permission = // get permission for node (args[0])
>> return permission;
>> rules.add(filterRule);
>> IUIFilter filter = new UIFilter(rules);
>> pNode.addFilter(filter);
>> return super.createView(context, pNode);
>> Also there is an API method setVisible() in INavigationNode to set the
>> visibility of a node.
>> Regards, Frank
>>> Hi,
>>> permissions.
>>> has been performed.
>>> Thanks and greetz,
>>> Carsten
Re: Create Application model depending on login information [message #24153 is a reply to message #24053] |
Wed, 01 April 2009 05:46  |
Hi Frank,
I opened Bug report 270735 for this.
Greetz,
Carsten
news:gqvavi$9fi$1@build.eclipse.org...
> Hi Carsten,
> you are right class UIFilterRuleNavigationHiddenMarker is internal and so
> should be used only with caution, because this code may undergo changes.
> May be you file a bugzilla request which describes your problem and
> mentions that class UIFilterRuleNavigationHiddenMarker is internal. The
> gray "placeholder" seems to be a refresh problem. Can you file bugzilla
> Regards, Frank
>> Hi Frank,
>> Greetz,
>> Carsten
>>> Hi Carsten,
>>> the login dialog view). The splash login view is brought up when the
>>> workbench is created and that is after createModel() was called. I think
>>> you can use the riena ui filters (see
>>> http://wiki.eclipse.org/Riena_UI_filters) to manipulate the displayed
>>> model nodes based on permissions. Override the createView() method of
>>> your application class (subclass of SwtApplication) like this:
>>> @Override
>>> pNode) {
>>> + pNode.getNodeId().getTypeId() + "/*") {
>>> @Override
>>> return permission;
>>> Regards, Frank
>>>> Hi,
>>>> permissions.
>>>> login has been performed.
>>>> Thanks and greetz,
>>>> Carsten
Re: Create Application model depending on login information [message #581599 is a reply to message #23776] |
Mon, 30 March 2009 11:52  |
Hi Carsten,
pNode) {
return permission;
Regards, Frank
> permissions.
> has been performed.
> Thanks and greetz,
> Carsten
Re: Create Application model depending on login information [message #581645 is a reply to message #23906] |
Wed, 01 April 2009 03:08  |
Hi Frank,
Greetz,
Carsten
> Hi Carsten,
> like this:
> @Override
> pNode) {
> @Override
> return permission;
> Regards, Frank
>> permissions.
>> has been performed.
>> Thanks and greetz,
>> Carsten
Re: Create Application model depending on login information [message #581655 is a reply to message #24021] |
Hi Carsten,
Regards, Frank
> Hi Frank,
> Greetz,
> Carsten
>> Hi Carsten,
>> like this:
>> @Override
>> pNode) {
>> @Override
>> return permission;
>> Regards, Frank
>>> Hi,
>>> permissions.
>>> has been performed.
>>> Thanks and greetz,
>>> Carsten
Re: Create Application model depending on login information [message #581668 is a reply to message #24053] |
Hi Frank,
Greetz,
Carsten
> Hi Carsten,
> Regards, Frank
>> Hi Frank,
>> Greetz,
>> Carsten
>>> Hi Carsten,
>>> @Override
>>> pNode) {
>>> @Override
>>> return permission;
>>> Regards, Frank
>>>> Hi,
>>>> permissions.
>>>> Thanks and greetz,
>>>> Carsten
Current Time: Sat Jul 26 05:56:01 EDT 2025
Powered by FUDForum. Page generated in 0.09930 seconds
