Home » Eclipse Projects » Riena » Create Application model depending on login information
Re: Create Application model depending on login information [message #24053 is a reply to message #24021] |
Wed, 01 April 2009 08:57   |
Frank Schepp Messages: 14 Registered: July 2009 |
Junior Member |
Hi Carsten,
you are right class UIFilterRuleNavigationHiddenMarker is internal and
so should be used only with caution, because this code may undergo
changes. May be you file a bugzilla request which describes your problem
and mentions that class UIFilterRuleNavigationHiddenMarker is internal.
The gray "placeholder" seems to be a refresh problem. Can you file
bugzilla request for that? Is it a submodule your are hiding?
Regards, Frank
Carsten Spieker wrote:
> Hi Frank,
> thanks for your reply!
> I tried the way you explained via the UIFilter. Unfortunately I have two
> problems with this solution:
> 1) The class UIFilterRuleNavigationHiddenMarker seems to be internal.
> 2) The UI shows a bad looking gray "placeholder" where the now hidden
> navigation node was displayed before until I "click" somewhere in the UI
> (maybe this is only a refresh problem?)
> Greetz,
> Carsten
> "Frank Schepp" <Frank.Schepp@compeople.de> schrieb im Newsbeitrag
> news:gqqqia$un0$1@build.eclipse.org...
>> Hi Carsten,
>> you are right in case you use the splash login view (its different for the
>> login dialog view). The splash login view is brought up when the workbench
>> is created and that is after createModel() was called. I think you can use
>> the riena ui filters (see http://wiki.eclipse.org/Riena_UI_filters) to
>> manipulate the displayed model nodes based on permissions. Override the
>> createView() method of your application class (subclass of SwtApplication)
>> like this:
>> @Override
>> public Object createView(IApplicationContext context, IApplicationNode
>> pNode) {
>> Collection<IUIFilterRule> rules = new ArrayList<IUIFilterRule>(1);
>> // hidden marker for all children of application node
>> IUIFilterRule filterRule = new UIFilterRuleNavigationHiddenMarker("/" +
>> pNode.getNodeId().getTypeId() + "/*") {
>> @Override
>> public boolean matches(Object... args) {
>> return super.matches(args) && !getPermission(args);
>> private boolean getPermission(Object... args) {
>> boolean permission = true;
>> if (args[0] instanceof INavigationNode<?>) {
>> permission = // get permission for node (args[0])
>> return permission;
>> rules.add(filterRule);
>> IUIFilter filter = new UIFilter(rules);
>> pNode.addFilter(filter);
>> return super.createView(context, pNode);
>> Also there is an API method setVisible() in INavigationNode to set the
>> visibility of a node.
>> Regards, Frank
>>> Hi,
>>> I want to create my application model depending on the current users
>>> permissions.
>>> The problem is that IApplicationNode.createModel() is called before login
>>> has been performed.
>>> Is there any possibility to manipulate the displayed model nodes after
>>> login? Or is there any out of the box solution for this?
>>> Thanks and greetz,
>>> Carsten
Re: Create Application model depending on login information [message #24153 is a reply to message #24053] |
Wed, 01 April 2009 09:46  |
Carsten Spieker Messages: 197 Registered: July 2009 |
Hi Frank,
I opened Bug report 270735 for this.
Greetz,
Carsten
news:gqvavi$9fi$1@build.eclipse.org...
> Hi Carsten,
> you are right class UIFilterRuleNavigationHiddenMarker is internal and so
> should be used only with caution, because this code may undergo changes.
> May be you file a bugzilla request which describes your problem and
> mentions that class UIFilterRuleNavigationHiddenMarker is internal. The
> gray "placeholder" seems to be a refresh problem. Can you file bugzilla
> Regards, Frank
>> Hi Frank,
>> Greetz,
>> Carsten
>>> Hi Carsten,
>>> the login dialog view). The splash login view is brought up when the
>>> workbench is created and that is after createModel() was called. I think
>>> you can use the riena ui filters (see
>>> http://wiki.eclipse.org/Riena_UI_filters) to manipulate the displayed
>>> model nodes based on permissions. Override the createView() method of
>>> your application class (subclass of SwtApplication) like this:
>>> @Override
>>> pNode) {
>>> + pNode.getNodeId().getTypeId() + "/*") {
>>> @Override
>>> return permission;
>>> Regards, Frank
>>>> Hi,
>>>> permissions.
>>>> login has been performed.
>>>> Thanks and greetz,
>>>> Carsten
Re: Create Application model depending on login information [message #581655 is a reply to message #24021] |
Junior Member |
Hi Carsten,
Regards, Frank
> Hi Frank,
> Greetz,
> Carsten
>> Hi Carsten,
>> like this:
>> @Override
>> pNode) {
>> @Override
>> return permission;
>> Regards, Frank
>>> Hi,
>>> permissions.
>>> has been performed.
>>> Thanks and greetz,
>>> Carsten
Re: Create Application model depending on login information [message #581668 is a reply to message #24053] |
Hi Frank,
Greetz,
Carsten
> Hi Carsten,
> Regards, Frank
>> Hi Frank,
>> Greetz,
>> Carsten
>>> Hi Carsten,
>>> @Override
>>> pNode) {
>>> @Override
>>> return permission;
>>> Regards, Frank
>>>> Hi,
>>>> permissions.
>>>> Thanks and greetz,
>>>> Carsten
Current Time: Mon Oct 02 22:37:34 GMT 2023
Powered by FUDForum. Page generated in 0.02666 seconds
