Home » Archived » IMP » SVN site down?
SVN site down? [message #23761] Fri, 15 August 2008 14:20 Go to next message
Is the SVN repository still working?
I've not been able to access it for a couple of days...
SVN: '0x00400106: Get Repository Folder Children' operation finished with error
and
org.eclipse.team.svn.core.connector.SVNConnectorException: svn: PROPFIND of '/svnroot/technology': 405 Method Not Allowed
(http://dev.eclipse.org)
at org.polarion.team.svn.connector.svnkit.SVNKitConnector.handl eClientException(SVNKitConnector.java:1182)
at org.polarion.team.svn.connector.svnkit.SVNKitConnector.list( SVNKitConnector.java:1034)
at org.eclipse.team.svn.core.extension.factory.ThreadNameModifi er.list(ThreadNameModifier.java:276)
at org.eclipse.team.svn.core.utility.SVNUtility.list(SVNUtility .java:364)
at org.eclipse.team.svn.core.svnstorage.SVNRepositoryContainer. getChildren(SVNRepositoryContainer.java:71)
at org.eclipse.team.svn.ui.operation.GetRemoteFolderChildrenOpe ration.runImpl(GetRemoteFolderChildrenOperation.java:72)
at org.eclipse.team.svn.core.operation.AbstractActionOperation. run(AbstractActionOperation.java:76)
at org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doT ask(ProgressMonitorUtility.java:103)
at org.eclipse.team.svn.core.operation.CompositeOperation.runIm pl(CompositeOperation.java:94)
at org.eclipse.team.svn.core.operation.LoggedOperation.run(Logg edOperation.java:37)
at org.eclipse.team.svn.core.utility.ProgressMonitorUtility.doT askExternal(ProgressMonitorUtility.java:89)
at org.eclipse.team.svn.ui.utility.DefaultCancellableOperationW rapper.run(DefaultCancellableOperationWrapper.java:55)
at org.eclipse.team.svn.ui.utility.ScheduledOperationWrapper.ru n(ScheduledOperationWrapper.java:37)
Caused by: org.tigris.subversion.javahl.ClientException: svn: PROPFIND of '/svnroot/technology': 405 Method Not Allowed
at org.tigris.subversion.javahl.JavaHLObjectFactory.throwExcept ion(JavaHLObjectFactory.java:607)
at org.tmatesoft.svn.core.javahl.SVNClientImpl.throwException(S VNClientImpl.java:1389)
at org.tmatesoft.svn.core.client.SVNClientEx.list(SVNClientEx.j ava:889)
at org.polarion.team.svn.connector.svnkit.SVNKitConnector.list( SVNKitConnector.java:1025)
.... 14 more
Caused by: org.tmatesoft.svn.core.SVNException: svn: PROPFIND of '/svnroot/technology': 405 Method Not Allowed (http://dev.eclipse.org)
at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVN ErrorManager.java:69)
at org.tmatesoft.svn.core.internal.io.dav.DAVUtil.findStartingP roperties(DAVUtil.java:126)
at org.tmatesoft.svn.core.internal.io.dav.DAVUtil.getBaselinePr operties(DAVUtil.java:199)
at org.tmatesoft.svn.core.internal.io.dav.DAVUtil.getBaselineIn fo(DAVUtil.java:162)
at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.getLate stRevision(DAVRepository.java:150)
at org.tmatesoft.svn.core.wc.SVNBasicClient.getRevisionNumber(S VNBasicClient.java:348)
at org.tmatesoft.svn.core.wc.SVNBasicClient.getLocations(SVNBas icClient.java:462)
at org.tmatesoft.svn.core.wc.SVNBasicClient.createRepository(SV NBasicClient.java:418)
at org.tmatesoft.svn.core.wc.SVNLogClient.doList(SVNLogClient.j ava:654)
at org.tmatesoft.svn.core.client.SVNClientEx.list(SVNClientEx.j ava:877)
.... 15 more
Ed Willink
Re: SVN site down? [message #23804 is a reply to message #23761] Thu, 21 August 2008 11:56 Go to previous messageGo to next message
Ah! the wonders of SVN. Delete projects and check out again
and all the problems go away.
Ed Willink
Re: SVN site down? [message #23847 is a reply to message #23761] Mon, 25 August 2008 11:47 Go to previous messageGo to next message
Yes, the site has unavailable or had limited availability for a couple
of weeks, at least. For a week or so it didn't seem to be accessible at
all. Lately (as noted) it seems to be available for checkout but we
still aren't able to commit anything to it. Hence no updates for some
time now. We're still trying to figure out if the repository can be put
back to a state that will allow us to commit our accumulated changes.
We are quite eager for that to happen.
Stan
Ed Willink wrote:
> Hi
> with error
> and
> Regards
> Ed Willink
Re: SVN site down? [message #24213 is a reply to message #23761] Thu, 11 September 2008 17:11 Go to previous message
Ed Willink wrote:
> Hi
> with error
> and
Hi there,
The problem was that all of the eclipse.org Technology projects
using SVN were recently migrated from a single repository to one
repository per project. The result is that although the URL for
any given folder looks the same, e.g.
http://dev.eclipse.org/svnroot/technology/org.eclipse.imp/or g.eclipse.imp.runtime
(and so you might think your workspace should work unchanged),
but the two parts (repo location + path within the repo) aren't
the same. You have to delete the plugin projects from your
workspace, create a new repository location, and check them out
again.
The new repository location for IMP is now:
Oh, and remember to check out the "trunk" sub-folder of any of
the plugin projects, rather than the parent folder.
- Bob Fuhrer
Re: SVN site down? [message #573029 is a reply to message #23761] Thu, 21 August 2008 11:56 Go to previous message
Ed Willink
Re: SVN site down? [message #573056 is a reply to message #23761] Mon, 25 August 2008 11:47 Go to previous message
Stan
Ed Willink wrote:
> Hi
> with error
> and
> Regards
> Ed Willink
Re: SVN site down? [message #573295 is a reply to message #23761] Thu, 11 September 2008 17:11 Go to previous message
Ed Willink wrote:
> Hi
> with error
> and
Hi there,
again.
- Bob Fuhrer
Previous Topic:Status of project?
Next Topic:Status of project?
Current Time: Wed Jul 16 17:58:27 EDT 2025
Powered by FUDForum. Page generated in 0.05356 seconds
