Open a Wizard from the Palette? [message #241407] |
Sun, 10 February 2008 12:08  |
I wonder if it is possible to add an entry to the palette that uses a
wizard to create an element. I currently don't mind where the created
element is positioned, but wonder from which place (and which kind of
entry) i may call a wizard dialog.
Thanks in advance,
Fredrik
Re: Open a Wizard from the Palette? [message #241412 is a reply to message #241407] |
Mon, 11 February 2008 02:20   |
Normal there 2 ways handle this:
1, like normal behavior in GEF editor, click in Editor figure, handle a
location and bound, then trigger a wizard,
just in paletteRoot configure class/method create a CreationTool subclass :
CreationToolEx extends CreationTool {
mouseDoubleClick...
@PaletteRoot,
componentsDrawer.add(newTemplateEntry(...));
protected CombinedTemplateCreationEntry newTemplateEntry(... descripitors) {
CombinedTemplateCreationEntry creation = new
CombinedTemplateCreationEntry(...);
creation.setToolClass(CreationToolEx.class);
return creation;
2, handle palette EditPart, in this way, need handle
org.eclipse.gef.ui.palette.PaletteViewer
customerize it with an extended PaletteEditPartFactory,
override some intrested cretioneditpart method:
such as createXEditPart(EditPart parentEditPart, Object model) method,
f.e. createEntryEditPart
pass a new PaletteEditPart subclass,
ofcause in customerized PaletteEdtiPart need override some methods like
this:
public void performRequest(Request req) {
//start a wizard
if the 1st way filled requirements, recommemded.
Xiangya
Fredrik 写道:
> Thanks in advance,
> Fredrik
Re: Open a Wizard from the Palette? [message #241506 is a reply to message #241412] |
Thu, 14 February 2008 09:06   |
Hi Xiangya,
Your recommended solution nr. 1 worked nicely.
Thanks for your help!
Fredrik
Qinxian wrote:
> @Override
> mouseDoubleClick...
> @PaletteRoot,
> return creation;
> this:
> @Override
> //start a wizard
> Cheers,
> Xiangya
> Fredrik åé:
>> Thanks in advance,
>> Fredrik
Re: Open a Wizard from the Palette? [message #630865 is a reply to message #241506] |
Tue, 05 October 2010 07:51  |
Hi Xiangya,
I'm new to Eclipse plug-in development. I am developing a Eclipse plug-in where I am populating contents of an XML file in a Wizard in Tree View, now from that wizard I want to select some XML elements and on click of Finish button of the Wizard, I want all the selected XML elements of wizard should be available in the Palette (a view panel like Outline or Task list).
In general I want to generate a Palette on click of Finish Button of a Wizard. Anyone can please help me on this.
Anil Soni
FUDForum. Page generated in 0.10533 seconds
