Hashtable$Entry is referenced by ? [message #23658] |
Tue, 26 July 2005 04:21  |
Originally posted by: jan.luciad_nospam.com
Hi !
When showing the "object references" view of the profiling data I find a
number of objects referenced by Hashtable$Entry. Unfortunately I can't
expand that element in the view to find out which object is actually
referencing Hashtable$Entry.
Does somebody know how I can find this out ? Thanks !
Jan
Re: Hashtable$Entry is referenced by ? [message #40798 is a reply to message #23974] |
Wed, 16 November 2005 08:22  |
Originally posted by: kevin.mcmanus.dds.mediaocean.com
Hi All,
I am having the same issue, and the app that I'm profiling has numerous
HashMaps. So, it becomes a matter of guesswork to determine which
HashMap instance refers to which Entry.
So, in "Referenced By" mode, I see the following, where the Entry is a
leaf, not showing the HashMap, or [Entry, which references it.
MyClass.185761
|-----> HashMap$Entry.202499
Using Memory Statistics I can determine that instances of my class exist
when they should not, but not what is keeping the in memory.
Any suggestions?
Kevin
Jan Goyvaerts wrote:
> Hi Eugene,
> Thanks for helping me out !
> I thought I did that already. To make sure I did, I tried it. With the
> same result.
> I can follow the references of an object to Hashtable$Entry and there it
> stops. There is no icon to expand the node any further. But when I look
> to which objects are referencing Hashtable for example, then I see a
> list of objects. I guess the one I'm looking for is amongst then. But I
> would really like to go further then the Hashtable$Entry to be sure
> which one it is.
> Maybe it's the install that is wrong ? Or is this a known issue ? Maybe
> inner classes are not supported ?
> Linux Fedora Core 3
> Sun JDK 1.4.2_08
> Eclipse 3.1
> TPTP 4.0 (tptp.runtime-TPTP-4.0.0-200507181519)
> Are you able to check for the references of Hashtable$Entry. (Or
> HashMap$Entry)
> Jan
> Eugene Chan wrote:
>> Hi Jan,
>> You can collect object reference information by click on the 'Collect
>> Object
>> Reference' button in the Profiling Monitor View toolbar, or in context
>> menu
>> on the profiling object (eg. process) you are profiling.
>> Eugene
>> "Jan Goyvaerts" <jan@luciad_nospam.com> wrote in message
>> news:dc4rqg$co6$1@news.eclipse.org...
>>> Hi !
>>> Jan
FUDForum. Page generated in 0.02838 seconds
