Home » Eclipse Projects » Eclipse Platform » Using workspace (org.eclipse.core.resources) standalone
Using workspace (org.eclipse.core.resources) standalone [message #241105] Wed, 12 May 2004 21:22 Go to next message
Originally posted by: dewit.metaserver.com
Is it possible to reuse the workspace framework outside the eclipse IDE?
What needs to be done to make it work?
thanks,
Yur
Re: Using workspace (org.eclipse.core.resources) standalone [message #241165 is a reply to message #241105] Thu, 13 May 2004 09:02 Go to previous messageGo to next message
Originally posted by: dj_houghton.nospam.ca.ibm.com
That all depends on what you mean. The org.eclipse.core.resources
plug-in relies heavily on org.eclipse.core.runtime and org.eclipse.osgi.
If by "outside the IDE" you mean without the Java Development Toolkit,
you should check out the Platform download (instead of the SDK
download). There are other projects out there take advantage of the
workspace and UI frameworks without including the JDT and PDE (Plug-in
Development Environment).
> thanks,
> Yur
Re: Using workspace (org.eclipse.core.resources) standalone [message #241206 is a reply to message #241165] Thu, 13 May 2004 11:01 Go to previous messageGo to next message
Hi DJ,
I actually mean without anything that is not the .resources or its required
dependencies (core.runtime and .osgi). The minimal of the minimal
configuration to be able to manipulate workspace folder, files and projects
in the file system, i.e. no JDT, no UI, no anything that is not related to
..resources.
I would imagine that it is possible to create a minimal OSGi configuration
to get just the core.resources (and its dependencies) instantiated and
configured. If yes, do you have a code snippet or could you point me to the
right classes so I can figure that out?
thanks,
yuri
"DJ Houghton" <dj_houghton@nospam.ca.ibm.com> wrote in message
news:c7vr7h$k31$1@eclipse.org...
> > thanks,
> > Yur
Re: Using workspace (org.eclipse.core.resources) standalone [message #241482 is a reply to message #241206] Fri, 14 May 2004 13:44 Go to previous message
I haven't done this lately but in theory you should be able to:
- go to the RCP web site and get the list of minimal required plug-ins
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-core-home/runtime/rcp-plugins.html
- add org.eclipse.core.resources to the list (and
org.eclipse.core.runtime.compatibility since resources requires it)
- create your own application, have it require org.eclipse.core.resources
- start Eclipse with the -application arg
- start debugging :-)
Yuri de Wit wrote:
> Hi DJ,
> .resources.
> thanks,
> yuri
>>>thanks,
>>>Yur
Previous Topic:Showing XML file in Tree Format in a new View
Next Topic:My decorator overlay icons don't display on startup
Current Time: Sun Aug 31 23:56:47 EDT 2025
Powered by FUDForum. Page generated in 0.04633 seconds
