ASTParser Help [message #240639] |
Sun, 11 February 2007 09:32  |
Originally posted by: nitrousfiz.googlemail.com
Can I use Eclipse's ASTParser to parse java source code from a standalone
application (i.e. without the null pointed exception)?
If yes, which version should I use?
If not, what alternatives are there for parsing java code?
Here is what I need to do-
Use a parser to create an AST and extract the names of the methods, its
parameters & its parameter types. I also need to extract variable names &
variable types from a given set of statements.
Please help me out to get this done.
Thanks for your help in advance.
Fayezin
Re: ASTParser Help [message #240648 is a reply to message #240643] |
Sun, 11 February 2007 14:06   |
This is the program I am trying to run:
import java.io.*;
import org.eclipse.jdt.core.dom.*;
public class ParseJava {
ASTParser parser = ASTParser.newParser(AST.JLS3);
parser.setSource(code.toCharArray());
parser.setKind(ASTParser.K_EXPRESSION);
ASTNode node = parser.createAST(null);
if (node.getNodeType() == ASTNode.METHOD_INVOCATION) {
MethodInvocation methodInvocation = (MethodInvocation) node;
System.out.println("Invoking method : "+methodInvocation.getName());
I get this error during compilation (maybe its asking for the runtime?)-
The type org.eclipse.core.runtime.IProgressMonitor cannot be resolved. It is
indirectly referenced from required .class files
I am using the org.eclipse.jdt.core_3.2.1.v_677_r32x.jar in my buildpath.
If its the wrong one, please advise which one to use?
Can you please help me solve this problem?
Fayezin
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:eqn9rs$ql$1@utils.eclipse.org...
> Fayezin,
> I believe this should be possible. Perhaps if you show what you've tried
> and show the exception stack trace someone, will know what you need to do
> to avoid it.
> Fayezin Islam wrote:
>> Hello,
>> Regards,
>> Fayezin
Re: ASTParser Help [message #240663 is a reply to message #240648] |
Sun, 11 February 2007 16:43   |
--------------070606070704050207030907
Fayezin,
It sounds like you still need to put all of jdt's dependencies on the
classpath. E.g., IProgressMonitor is in org.eclips.equinox.common_*.jar.
> Hello,
> import java.io.*;
> public static void main(String[] args) {
> Fayezin
>> Fayezin,
>> to avoid it.
>>> Hello,
>>> Regards,
>>> Fayezin
<html>
<head>
</head>
Fayezin,<br>
<br>
org.eclips.equinox.common_*.jar.<br>
<br>
<br>
<blockquote cite="mideqnpfi$t4g$1@utils.eclipse.org" type="cite">
<pre wrap="">Hello,
import java.io.*;
Fayezin
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com"><merks@ca.ibm.com></a> wrote in message
<a class="moz-txt-link-freetext" href="news:eqn9rs$ql$1@utils.eclipse.org">news:eqn9rs$ql$1@utils.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">Fayezin,
to avoid it.
</pre>
<pre wrap="">Hello,
Fayezin
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------070606070704050207030907--
Re: ASTParser Help [message #246170 is a reply to message #246161] |
Wed, 25 July 2007 15:19  |
Originally posted by: chengt.uwm.edu
Cheng Thao wrote:
> Olivier Thomann wrote:
>> Cheng Thao a écrit :
>>> Exception in thread "main" java.lang.NoClassDefFoundError:
>>> org/eclipse/core/runtime/Plugin
>>> at java.lang.ClassLoader.defineClass1(Native Method)
>>> at java.lang.ClassLoader.defineClass(Unknown Source)
>>> at java.security.SecureClassLoader.defineClass(Unknown Source)
>>> at java.net.URLClassLoader.defineClass(Unknown Source)
>>> at java.net.URLClassLoader.access$000(Unknown Source)
>>> at java.net.URLClassLoader$1.run(Unknown Source)
>>> at java.security.AccessController.doPrivileged(Native Method)
>>> at java.net.URLClassLoader.findClass(Unknown Source)
>>> at java.lang.ClassLoader.loadClass(Unknown Source)
>>> at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
>>> at java.lang.ClassLoader.loadClassInternal(Unknown Source)
>>> at
>>> org.eclipse.jdt.core.dom.ASTParser.initializeDefaults(ASTPar ser.java:230)
>>> at org.eclipse.jdt.core.dom.ASTParser.<init>(ASTParser.java:212)
>>> at org.eclipse.jdt.core.dom.ASTParser.newParser(ASTParser.java: 112)
>>> at test.Test.main(Test.java:23)
>> You can get this if you don't have all the required jars on your
>> classpath.
>> Olivier
> org/eclipse/core/runtime/content/IContentTypeManager$IConten tTypeChangeListener
> I added many more jar files. Now it needs the IContentTypeManager which
> I can't seem to find the jar that has it. I assume it is in the
> org.eclipse.core.runtime.jar. I tried that, but it didn't work. I look
> at the source code in org.eclipse.core.runtime.content, but there is no
> IContentTypeManager.
> I'm using Eclipse 3.2.2.
OK, this is fixed. I had to include the following jar files.
org.eclipse.core.contenttype.jar
org.eclipse.core.jobs.jar
org.eclipse.core.resources.jar
org.eclipse.runtime.jar
org.eclipse.equinox.common.jar
org.eclipse.equinox.preferences.jar
org.eclipse.jdt.core.jar
org.eclipse.osgi.jar
FUDForum. Page generated in 0.47864 seconds
