Home » Eclipse Projects » Eclipse Platform » Help!jvm exit with code 13
Help!jvm exit with code 13 [message #240180] Tue, 11 May 2004 03:50 Go to next message
I've just download Eclipse 3.0M8.
but when I start eclipse.exe ,it report "JVM terminated.exit code is 13".
The log printed:
!SESSION May 11, 2004
15:47:10.375 ----------------------------------------------
java.version=1.4.2
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=zh_CN
!ENTRY org.eclipse.osgi May 11, 2004 15:47:10.375
!MESSAGE Error parsing plugin manifest file at
d:\eclipse\eclipse3M8\eclipse\plugins\org.eclipse.update.con figurator_3.0.0
!STACK 0
org.eclipse.core.runtime.adaptor.PluginConverterImpl$PluginC onversionExcepti
on: Error parsing plugin manifest file at
org.eclipse.core.runtime.adaptor.PluginConverterImpl.parsePl uginInfo(PluginC
onverterImpl.java:508)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.fillPlu ginInfo(PluginCo
nverterImpl.java:77)
org.eclipse.core.runtime.adaptor.PluginConverterImpl.convert Manifest(PluginC
onverterImpl.java:641)
org.eclipse.core.runtime.adaptor.EclipseBundleData.generateM anifest(EclipseB
undleData.java:191)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadManif est(EclipseBundl
eData.java:170)
org.eclipse.core.runtime.adaptor.EclipseBundleData.getManife st(EclipseBundle
Data.java:154)
org.eclipse.core.runtime.adaptor.EclipseBundleData.loadFromM anifest(EclipseB
undleData.java:229)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultBu ndleData.initial
izeNewBundle(DefaultBundleData.java:93)
org.eclipse.osgi.framework.internal.defaultadaptor.DefaultAd aptor$1.begin(De
faultAdaptor.java:417)
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(F
ramework.java:720)
org.eclipse.osgi.framework.internal.core.Framework$1.run(Fra mework.java:612)
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.j
ava:690)
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.j
ava:607)
org.eclipse.osgi.framework.internal.core.BundleContext.insta llBundle(BundleC
ontext.java:207)
org.eclipse.core.runtime.adaptor.EclipseStarter.loadBasicBun dles(EclipseStar
ter.java:379)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:
208)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:115)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:267)
at org.eclipse.core.launcher.Main.run(Main.java:692)
at org.eclipse.core.launcher.Main.main(Main.java:676)
Caused by: org.xml.sax.SAXNotSupportedException: PAR018 true state for
feature "http://xml.org/sax/features/string-interning" is not supported.
true http://xml.org/sax/features/string-interning
at org.apache.xerces.parsers.SAXParser.setFeature(SAXParser.jav a:548)
at org.apache.xerces.jaxp.SAXParserImpl.setFeatures(SAXParserIm pl.java:143)
at org.apache.xerces.jaxp.SAXParserImpl.<init>(SAXParserImpl.java:126)
org.apache.xerces.jaxp.SAXParserFactoryImpl.newSAXParserImpl (SAXParserFactor
yImpl.java:113)
org.apache.xerces.jaxp.SAXParserFactoryImpl.setFeature(SAXPa rserFactoryImpl.
java:141)
org.eclipse.core.runtime.adaptor.PluginParser.parsePlugin(Pl uginParser.java:
374)
onverterImpl.java:505)
... 24 more
!ENTRY org.eclipse.osgi May 11, 2004 15:47:10.390
!MESSAGE Startup error
!STACK 1
org.osgi.framework.BundleException: An error occured trying to read the
bundle
faultAdaptor.java:447)
at org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileg
ed(Framework.java:720)
ava:690)
ava:607)
ontext.java:207)
ter.java:379)
208)
..java:25)
Nested exception:
java.io.IOException: Unable to properly read manifest for:
reference:file:d:/eclipse/eclipse3M8/eclipse/plugins/org.ecl ipse.update.conf
igurator_3.0.0/
undleData.java:231)
ramework.java:720)
ava:690)
ava:607)
ontext.java:207)
ter.java:379)
208)
..java:25)
Re: Help!jvm exit with code 13 [message #240503 is a reply to message #240180] Tue, 11 May 2004 15:06 Go to previous message
Originally posted by: chaves.nospam.inf.ufsc.br
Check out this bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=57298
Previous Topic:Error in RCP project : Could not load library: libcore_2_1_0b.so
Next Topic:[Newbie] Is it kosher for a plug-in to run another program?
Current Time: Sun Aug 31 21:39:30 EDT 2025
Powered by FUDForum. Page generated in 0.03880 seconds
