Local Cache of Schemas [message #23546] |
Sun, 15 June 2003 19:52  |
I want to use a local cache for my resources/schemas.
I tried to provide my own URIResolver and looked at the example in the docs.
Everything works fine if I pass back the URI I get (an absolute one with
http://) but if I map the URI to a file:// URI it only loads the outermost
schema and doesn't have any element declarations. I checked the inputstream
generated by URIResolver.createInputStream and it has the correct schema
file in it but the URIResolver is never called for the other schemas
referenced by import or include.
What do I do wrong ? I also tried calling schema.setLocation but it didn't
make any difference.
The xsd file I use is: http://www.w3.org/TR/voicexml20/vxml.xsd
thanx
Jens Lukowski
FUDForum. Page generated in 0.44099 seconds
