Home » Archived » OHF » Issue with XMLWriter 1.15 in the utilities plugin
Issue with XMLWriter 1.15 in the utilities plugin [message #23528] Fri, 17 November 2006 13:28
Originally posted by: dean.atchley . duke.dot.edu
I would bug this on bugzilla but there wasn't a matching component.
Looks like version 1.15 of org.eclipse.ohf.utilities.xml.XMLWriter.java
changed the throws
section of some methods from OHFException to IOException and as a result the
hl7v2.core
plugin is failing to build due to CPConformanceProfileComposer usage of
XMLWriter.
Dean
Previous Topic:The OHF Bridge PHP application is back on the air
Next Topic:Issue with XMLWriter 1.15 in the utilities plugin
Current Time: Tue Jul 22 02:30:14 EDT 2025
Powered by FUDForum. Page generated in 0.27412 seconds
