Home » Archived » BIRT » BIRT 2.2RCO cannot use this version after download
BIRT 2.2RCO cannot use this version after download [message #239952] |
Fri, 25 May 2007 13:46 |
Originally posted by: hans-reier.sigmond.comptel.com
BIRT Downloads for build 2.2RC0 created on 2007-05-21 06:30:00
1) I tried the stand alone BIRT Report designer. This could not be
opened. Refer to message in attachment. I think that some files must be
missing.
I also did an experiment with copying the downloaded files on top of an
old version of BIRT. Then I got the Report designer GUI on my screen,
but (not very surprisingly) everything did not work (e.g. I could not
connect to a data source).
I have earlier used an older version of BIRT in this way, and this
version is OK.
2) I tried to download the Eclipse Birt software, including Eclipse and
everything. I could start Eclipse OK, and I could locate the BIRT
plugins when browsing in the product configuration; but nothing else
works. There are no references to BIRT stuff in the eclipse GUI / any of
the menus. I do not know if this is the same problem as 1) or another
problem.
Another guy in my company did this with an earlier version of Eclipse
with BIRT, and everything was OK. He also tried the same thing I did
with the lastest version (BIRT 2.2RCO) and got the same result as me.
Do we have to install some more things to get this to work?
Hans Reier Sigmond
!SESSION 2007-05-25 09:23:32.775
eclipse.buildId=unknown
java.version=1.4.2_10
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=no_NO
Framework arguments: -startup C:\Program
Files\Birt\birt-rcp-report-designer-2_2_0\plugins\org.eclips e.equinox.launcher_1.0.0.v20070502.jar
Command-line arguments: -os win32 -ws win32 -arch x86 -startup
C:\Program
!ENTRY org.eclipse.osgi 4 0 2007-05-25 09:23:38.694
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application
"org.eclipse.birt.report.designer.ui.rcp.DesignerApplication " could not
be found in the registry. The applications available are:
org.eclipse.ant.core.antRunner,
org.eclipse.birt.report.engine.ReportExecutor,
org.eclipse.equinox.app.error,
org.eclipse.help.base.infocenterApplication,
org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool,
org.eclipse.update.core.standaloneUpdate,
org.eclipse.update.core.siteOptimizer.
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:236)
org.eclipse.equinox.internal.app.EclipseAppContainer.start(E clipseAppContainer.java:92)
org.eclipse.equinox.internal.app.Activator.addingService(Act ivator.java:129)
org.osgi.util.tracker.ServiceTracker$Tracked.trackAdding(Ser viceTracker.java:1064)
org.osgi.util.tracker.ServiceTracker$Tracked.track(ServiceTr acker.java:1042)
org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged( ServiceTracker.java:967)
org.eclipse.osgi.framework.internal.core.FilteredServiceList ener.serviceChanged(FilteredServiceListener.java:94)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1224)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEventPrivileged(Framework.java:1603)
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEvent(Framework.java:1578)
org.eclipse.osgi.framework.internal.core.ServiceRegistration Impl. <init>(ServiceRegistrationImpl.java:103)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.c reateServiceRegistration(BundleContextImpl.java:657)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:609)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:675)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:359)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 497)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:436)
at org.eclipse.equinox.launcher.Main.run(Main.java:1162)
Re: BIRT 2.2RCO cannot use this version after download [message #240135 is a reply to message #239969] |
Tue, 29 May 2007 10:23 |
Pierre-Yves wrote:
> Have you tried using JDK 1.5 instead of 1.4 ?
> I had difficulties using 1.4 with 2.2M6 for the RCP designer...
> -Pierre-Yves
No, this is not the reason, it seams to be that some required components
in the software are missing after downloading.
Have anyone else got another idea?
Reier
Re: BIRT 2.2RCO cannot use this version after download [message #240469 is a reply to message #240135] |
Wed, 30 May 2007 17:26 |
Which specific download are you using?
Jason
Hans Reier Sigmond wrote:
> Pierre-Yves wrote:
>> -Pierre-Yves
> Reier
Re: BIRT 2.2RCO cannot use this version after download [message #240582 is a reply to message #240469] |
Thu, 31 May 2007 08:52 |
--------------000909080406040700080902
I and two other guys at the office tried the allInOne download! (I also
tried the stand alone report designer download and it did not work either).
I have tried to run Eclipse -clean the first time I started eclipse.
The enclosed file seclipseBIRT.jpg shows what Eclipse looks like after
starting it. I also removed old eclipse installations on the PC before
installation.
The only trace of BIRT in the Eclipse GUI is the tutoral, which does not
work; and I can also see the xml new.report.RPTDesign in XML. This seems
to be the XML representation of a report skeleton.
"The action could not be run because the plugin
org.eclipse.birt.designer.ui.editors.schematics is missing".
I also tried to look at the plugin I could find in Eclipse, refer to the
attachment eclipseBirtPlugins.JPG.
The Eclipse BIRT perspective cannot be found.
Also I have tried to compare the downloaded files, to what is listed in
the FAQ and other documentation. Refer to the attached file
I am able to find some of the required Birt plugins but not all.
Perhaps the plugin names has changed since the FAQ was written, Or else
(more likely) something is missing in the installation??
Reier
> Jason
>> Pierre-Yves wrote:
>>> Hi,
>>> -Pierre-Yves
>> components in the software are missing after downloading.
>> Reier
Content-Type: image/jpeg;
name="eclipeBirtPlugins.JPG"
Content-Disposition: inline;
filename="eclipeBirtPlugins.JPG"
/9j/4AAQSkZJRgABAQEAYABgAAD/2wBDAAgGBgcGBQgHBwcJCQgKDBQNDAsL DBkSEw8UHRof
Hh0aHBwgJC4nICIsIxwcKDcpLDAxNDQ0Hyc5PTgyPC4zNDL/2wBDAQkJCQwL DBgNDRgyIRwh
MjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIyMjIy MjIyMjL/wAAR
CAOpBCcDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDr/HXjpvBbaeq6bFdi6Qnl lTbtVD3Q5zur
nW+LGsJFFK/gydY5Rujc8Bx6g+VyKpfHH/W6F/1zk/8AQYq6KaS506wh1NNP YW9xIkrxsgKP
KHDgfIWYbmGFYjIPyMCCu3qjCmqUZON279WYynLmaTsYNx8abq0mMNz4YEMo AJSSRVYAjI4M
XcEH8aj/AOF4yf8AQvRf9/1/+N1X+LenWkEVrex2E0E9zIHLy7BtDBmKAIcA AkA5HVcgnLE6
HiWPwzpmlQWt3bacr3miW5t7a3sQtx9oY/64yhBgccgsc4PHr0Ro0HGLUd/N maqTu03t/wAD
/Mg/4XhJ/wBC9F/3/X/43S/8Lvk/6F+L/v8Ar/8AG6q6l4B8L2Gpa5bxXOrz nRrU3M8JaNTI
GVSgRtp6ZYsSvGRgdzaj8AaRoV2mrvNfTwpcWJtrYSIkkbSkH96dhHHsBn2o VPCu2m9u/Xbq
Nzqrr/SD/hd0n/Qvxf8Af5f/AI3S/wDC7ZP+hfi/7/L/APG6u654G03XPFjX lzNeK97r0llK
ImUBUERcEZU4OR3yPauV1XwromgWOnvcxarfzXyzyo1rKiJGqEgKQUbcRj5j kYHbiinTw07e
7q/N9rjcqibSe3+dje/4XZJ/0L8X/f5f/jdL/wALsk/6AEX/AH+X/wCN1h/E Sw0WD4hjT7W0
/s+HfCs7RuixBWVOVQINuASSSTk88Vc1zTRefEZfB0NrY6ZprTRwxullH5uw KCG80rvYtjru
5JpxoUJKL5d9d35f5idSavrt+pof8Lrk/wCgBF/3+X/43S/8Lqk/6AEX/f5f /jdRad8OtC1S
4tZI5dTtrZ7q6tZIpZUMpMSkh1OwDHGCMHB4zWh4d0TSdCguNWshqCm78Oy3 iZuVEkBzhgri
MYJGMNjjB4OeJcMMlpH8/Pz8hqVVu1/6ul+pV/4XTJ/0AIv+/wAv/wAbo/4X RJ/0AYv+/wAv
/wAbqXVvBOlSxw6vfTXswnjsk8uAwxNvmJ3OxWLBA9cZJzk1Cfhpo41K3txc 3/lyay+nsd6Z
EYiLg/d+9kfT2oVPDbOP5+X+aFz1LXT/AK1/yY7/AIXRJ/0AYv8Av8v/AMbo /wCFzyf9AGL/
AL/L/wDG6zn8EaOljpAjOp3OpanNNFDAkkaIfLl2ks5X5RsB7Nz7DB29D8F6 DZeJfD8yqb2G
7lureW3mcTRh41bnLRJuHB429cEHjkdPDJX5e/fp8w5qvcrf8Lmk/wCgDF/3 9X/43R/wuaT/
AKAMX/f1f/jdM0bwhpPiLQbe4jNza24vpwYf3LysqRbiqyCNWJJ6A5AHbjNV 4PA2hy6X/a7P
qK2raTJframZPNVkYAgvswVOeDtFP2eGTs4/n6/ow5qnR/1e36ouf8Llk/6A UX/f1f8A43S/
8Lkk/wCgFF/39X/43XG+MtBtvDuv/YrOSV4GgjmXziCw3LnBIAB/IVgCtY4W hJXS/FkurUXU
9R/4XHJ/0Aov+/q//G6X/hcUn/QCi/7+r/8AG68upRT+p0e34sXtp9z1H/hc Un/QDi/7+r/8
bo/4XDJ/0A4v+/q//G68wFLR9To9vxYe2n3PT/8AhcEn/QDi/wC/q/8Axul/ 4W/J/wBAOL/v
6v8A8brzAU6j6nR7fiw9tPuenf8AC3pP+gJF/wB/V/8AjdH/AAt2T/oCRf8A fxf/AI3XmVKK
PqlHt+LD20+56b/wt2T/AKAkX/fxf/jdL/wtyT/oCRf9/F/+N15nS0vqlHt+ LD20+56X/wAL
bk/6AkX/AH8X/wCN0v8AwtqT/oCxf9/F/wDjdeaClFH1Sj2/Fh7afc9K/wCF tSf9AWL/AL+L
/wDG6X/hbMn/AEBYv+/i/wDxuvNqWj6pR7fiw9tPuek/8LYk/wCgLF/38X/4 3R/wteT/AKA0
X/fxf/jdebinCj6pR7fiw9tPuej/APC15P8AoDRf9/F/+N0v/C1pP+gNF/38 X/43XnFLR9Uo
9vxYe2n3PRv+Fqyf9AaL/vtf/jdL/wALUk/6A8X/AH2v/wAbrzkU4UfVKPb8 WHtp9z0T/hak
n/QHi/77X/4il/4WnJ/0B4v++1/+IrzulFH1Sj2/Fh7afc9E/wCFpSf9AeL/ AL7X/wCIo/4W
jJ/0CIv++1/+Irz0UtL6pR7fiw9tPuehf8LQk/6BEX/fa/8AxFL/AMLPk/6B EX/fa/8AxFee
inUfVKPb8WL20+56D/ws+T/oERf99r/8RR/ws6T/AKBMX/fa/wDxFef0oo+q Ue34sPbT7noH
/CzZP+gTF/32v/xFL/wsyT/oExf99L/8RXAUtH1Sj2/Fh7afc77/AIWXJ/0C Yv8Avpf/AIil
/wCFlyf9AmL/AL6X/wCIrgRTqPqlHt+LD20+53v/AAsqT/oFRf8AfS//ABFH /CyZP+gVF/30
v/xFcHSij6pR7fiw9tPud5/wsiT/AKBUX/fS/wDxFH/CyJP+gVF/30v/AMRX CClFL6pR7fiw
9tPud3/wseT/AKBcX/fS/wDxFH/CxpP+gXF/30v/AMRXDClo+q0e35h7afc7 n/hYsn/QLi/7
6X/4il/4WLJ/0C4v++l/+IrhhThR9Vo9vzD20+52/wDwsST/AKBkX5r/APEU v/Cw5P8AoGRf
mv8A8RXEUoo+q0e35h7afc7f/hYUn/QMi/Nf/iKX/hYMn/QMi/Nf/iK4kUtH 1Wl2/MPbT7na
/wDCwJP+gbF+a/8AxFL/AMLAk/6BsX5r/wDEVxQpwo+q0u35h7afc7P/AIT+ T/oGxfmv/wAR
S/8ACfSf9A2L81/+IrjKWj6rS7fmHtp9zs/+E9k/6BsX5r/8RR/wnsn/AEDo vzX/AOIrjRTq
X1Wl2/MPbT7nY/8ACeSf9A6L81/+Ipf+E7k/6B0X/jv/AMRXHUoo+q0u35h7 afc7D/hOpP8A
oHRf+O//ABFL/wAJ1J/0D4v/AB3/AOIrkBS0fVaXb8w9tPudf/wnMn/QPi/8 d/8AiKP+E4k/
6B8X/jv/AMRXI0oo+q0u35h7afc67/hN5P8AoHxf+O//ABFH/Cbyf8+EX/jv /wARXJilo+q0
u35h7afc6z/hNpP+fCL/AMd/+Ipf+E1k/wCfCL/x3/4muTFOFL6rS7fmHtp9 zqv+E0k/58Iv
/Hf/AIml/wCEzk/58IvyX/4muVpRR9VpdvzD20+51X/CZSf8+MX5L/8AE0v/ AAmUn/PjF+S/
/E1y1LR9VpdvzD20+51H/CYyf8+MX5L/APE0v/CYSf8APjF+S/8AxNcwKWj6 rS7fmHtp9zp/
+Evk/wCfKL8l/wDiaP8AhLpP+fKL8l/+JrmacKPqtLt+Ye2n3Ol/4S6T/nyi /Jf/AImj/hLZ
P+fKL8l/+JrmxSij6tS7fmHtp9zpP+Esk/584vyX/wCJo/4SyT/nzi/Jf/ia 5ylo+rUu35h7
afc6P/hK5P8Anzi/Jf8A4ml/4SqT/nzi/wC+V/8Aia5wU4UfVqXb8w9tPudD /wAJTJ/z6Rf9
8r/8TS/8JRJ/z6Rf98r/APE1z1KKX1al2/MPbz7nQ/8ACUSf8+kX/fK//E0f 8JPJ/wA+kX/f
K/8AxNYApaPq1Lt+Ye3n3N//AISaT/n0i/75X/4ml/4SWT/n1i/75X/4msAU 4UfVqXb8w9vP
ubv/AAkkn/PrF/3yv/xNL/wkkn/PrF/3yv8A8TWEKcKPq1Lt+Yvb1O5uf8JH J/z6xf8AfK//
ABNH/CRSf8+0X/fC/wDxNYlLR9WpdvzD29Tubf8AwkMn/PtF/wB8L/8AE0v/ AAkEn/PtF/3w
v/xNYlOFH1al2/Mft59zZ/4SCT/n2i/74X/4ml/t+T/n3i/74X/4msalpfVq Xb8w9tPubP8A
b0n/AD7xf98L/wDE0f27J/z7xf8AfC//ABNY4pwo+rUu35h7efc1/wC3ZP8A n3i/74X/AOJo
/tyT/nhF/wB8L/8AE1k0tH1al2/MPb1O5rf23J/zwi/74X/4ml/tqT/nhF/3 wv8A8TWSKcKP
q1Lt+Yvb1O5qf21J/wA8Iv8Av2v/AMTS/wBsyf8APCL/AL9r/wDE1l0oo+r0 u35h7ep3NT+2
JP8AnjF/37X/AOJo/teT/njF/wB+1/wrNFLR9XpdvzD29TuaX9rSf88Yv+/a /wCFL/a0n/PG
L/v2v+FZopwo+r0u35h7ep3NH+1ZP+eUX/ftf8KP7Uk/55Rf9+1/wrPpwpfV 6fb8w9vU7l/+
05P+eUX/AH7X/Cl/tKT/AJ5Rf9+1/wAKoUtH1en2D29TuXv7Rk/55xf9+1/w p8d7NLIqJFEW
YgAeWnJP4VQFWLH/AI/7b/rqv8xSeHppbfmNVpt7l7ddf887X84qhuLyS1WN phar5kqQoB5R
LO7BVAA9SR/PpWZf69o+lzrBqGrWNpMy7xHcXKRsVyRnBI4yD+VVtWmiuBoM 8EiSwyapZuki
MGVlMgIII6giuBTX8v5/5nZyvv8Al/kdFuuv+edr+cVV7y/ewhWW5+yojSLG uPLYlmIUAADJ
5P8AXpXCN4H8O+JfEniG81fTvtNwl7HEr+fImFFtAQMKwHVj+dVbfSbHQ4L3 TdNg8i0h8R2v
lx72bGYbdjyxJ6k96cZRbty/n/mJxaV7/l/kemB7sqp8q2GQCM+UDg8jg0NJ cohd1s1VRkkt
EABXN+Op4LbQBLJqN5Y3CiH7I9nlpZJ9o2RrHnEu48FDwRnOMZHO6BfajeNr X/CRzzW+vraH
OmA7LeKDHEkQDMJMnO5ySQfl4HUcop25fz/zBJtb/l/kX/H+pfb/AAMJ4WXy ZpImUogXcp5G
eAfQ4NFZfiP/AJJbp/8AuW//AKAKKJJJtIIttalj4r+GtX8Qy6T/AGVafaPI jbzP3iJt3LHj
7xGehqhozfEHSbAwnRWuLhpFZ7h76IMyq24A8567s88hjxkkn1C5/wBav/XN P/QRXJTeLfK8
QTaZu0aLypkixc6p5U77lU5WLyzn72AN3JHatI4mSgqdk0hSopvmOC8SeHfH HiK8eR9IMNuz
CTyFu4Su/nLHDAE5LY443HqSScu58C+Or14nu7Sed4kEcbS3sbFFHRRl+APS vVrPxVbvDLLd
ZIMgEKWkEs7MnlRuW2qpbAL/AHtoHIzgmt+KWOeFJonV45FDIynIYHoRWqxt SKsor+vmT9Xj
3PEk8JfENNSbUlW9W+YYa5GoIJSMYwW356DHWpIPDPxItrqe6gfUIri4x50y akqvJjpuIkyc
e9e2UUvr9Tsv6+Y/YR7s8Xg8P/Eu2eV4J9TiaZ/MlZNTCmRsY3NiTk8Dk1HF 4V+IcFpNaRfb
o7aYsZYV1FQkhb725d+DnvnrXtlFH16f8q+7/gh7CPdniF54P8e6jFDHfRXd 0kIxEs98jiMc
fdBfjoOnpUzeGfiJJZx2Ttftax7QkB1FSi7fu4XfgYwMemK9poo+v1Oy/r5h 9Xj3Z4zJ4d+I
011HdSyajJcRqVjlbUlLoD1AO/IB71EPCnj9YhEFvBGITbhBfpgRHqmN/wB3 26V7XRR9en/K
v6+Yewj3Z5Voun/EDRbo3I097qXbGim41JxtVM7Vwkygrz91sj25Oa7aP8ST eXV1FJfW8l1K
ZpRb36xqznvhXA9B+Feu0Uvrs735V/XzD2Cta7PFW8I+On+zl4rpjbOXgzfI fKYnJK/P8pzz
kd6sTeHviJczQzTyahLLA2+J31FWaNvVSX4P0r2Kin9en2X9fMPYR7s8dk8P fEOaRJJZNQd0
k81WbUVJV8Y3A7+DjjPpTZfDPj6eWaWb7bJJNH5MrvfqTJH/AHWJflfY8V7J RS+vT/lQewj3
Z4pdeCvGV9MJru0muJAoUPNdxucDoMl+gqH/AIV/4o/6Bn/kxF/8VXuNFV9f qdl/XzF9Xj3P
D/8AhX/if/oGf+R4v/iqX/hAPE//AEDP/I8X/wAVXt9FH9oVey/r5h9XieI/ 8IB4n/6Bn/ke
P/4ql/4QHxN/0DP/ACPH/wDFV7bRR/aFXsv6+YfV4nif/CBeJv8AoG/+R4// AIql/wCEC8Tf
9A3/AMjx/wDxVe10Uf2hV7L+vmH1eJ4r/wAIH4l/6Bv/AJHj/wDiqX/hA/Ev /QN/8jx//FV7
TRS+v1ey/r5h9XieL/8ACCeJf+gb/wCR4/8A4ql/4QXxJ/0Df/I8f/xVez0U fX6nZf18w+rx
PGf+EF8Sf9A7/wAjx/8AxVL/AMIN4k/6B3/keP8A+Kr2Wij6/U7L+vmH1eJ4 3/wg3iP/AKB3
/keP/wCKpf8AhB/Ef/QO/wDI8f8A8VXsdFH1+p2X9fMPq8Tx3/hB/EX/AEDv /I8f/wAVS/8A
CEeIv+gd/wCRo/8A4qvYaKPr9Tsv6+YfV4nj/wDwhHiL/oHf+Ro//iqX/hCf EP8A0D//ACNH
/wDFV6/RR9fqdl/XzD6vE8h/4QnxD/0D/wDyNH/8VS/8IV4h/wCgf/5Gj/8A iq9doo+v1Oy/
r5h9XieR/wDCFeIP+gf/AORo/wD4ql/4QvxB/wBA/wD8jR//ABVet0UfX6nZ f18w+rxPJf8A
hDPEH/Ph/wCRo/8A4ql/4QzX/wDnw/8AI0f/AMVXrNFH1+p2X9fMPq8Tyf8A 4Q3X/wDnw/8A
I0f/AMVS/wDCG6//AM+H/kaP/wCKr1eij6/U7L+vmH1eJ5T/AMIdr3/Ph/5G j/8AiqX/AIQ/
Xv8Anw/8jJ/8VXqtFH1+p2X9fMPq8Tyv/hD9e/58f/Iyf/FUv/CIa7/z4/8A kZP/AIqvU6KP
r9Tsv6+YfV4nlv8AwiGu/wDPj/5FT/4ql/4RHXf+fH/yKn/xVeo0UfX6nZf1 8w+rRPL/APhE
dc/58f8AyKn/AMVS/wDCJa5/z4/+RU/xr0+ij69U7L+vmH1aB5j/AMIlrn/P l/5FT/Gj/hE9
b/58v/Iqf416dRS+vVOy/r5h9WgeZf8ACJ63/wA+X/kVP8aX/hFNb/58v/Iq f416ZRR9eqdl
/XzD6tA80/4RTWv+fL/yKn+NL/wiutf8+X/kVP8AGvSqKPr1Tsv6+YfVonm3 /CLa1/z5/wDk
VP8AGl/4RbWf+fP/AMip/jXpFFH16p2X9fMPq8Tzj/hF9Z/58/8AyKn+NL/w i+sf8+f/AJFT
/GvRqKPr1Tsg+rRPOv8AhGNY/wCfP/yKn+NL/wAIxrH/AD5/+RU/xr0Sij69 U7IPq0Dzz/hG
dY/59P8AyIn+NL/wjWr/APPp/wCRE/xr0Kij69U7IPq0Dz7/AIRrV/8An0/8 iJ/jS/8ACN6v
/wA+n/kRP8a9Aoo+vVOyD6tA4D/hG9W/59P/ACIn+NL/AMI5q3/Pp/5ET/Gu +oo+u1OyD6tA
4L/hHNV/59f/ACIv+NL/AMI7qv8Az6/+RF/xrvKKPrtTsg+rQOE/4R3Vf+fX /wAiL/jS/wDC
Pap/z6/+RF/xruqKPrtTsg+rQOG/4R7VP+fX/wAiL/jS/wDCP6p/z6/+RF/x ruKKX12p2QfV
oHEf2Bqf/Pt/5EX/ABpf7A1P/n2/8iL/AI121FH12p2QfVoHFf2Dqf8Az7f+ RF/xpf7B1L/n
2/8AH1/xrtKKPrtTsg+rQOM/sLUv+fb/AMfX/Gl/sLUv+fb/AMfX/Guyoo+u 1OyD6tA47+w9
R/59/wDx9f8AGl/sTUf+ff8A8fX/ABrsKKPrtTsg+rQOQ/sTUf8An3/8fX/G l/sXUP8An3/8
fX/Guuoo+u1OyD6tA5L+xdQ/59//AB9f8aP7G1D/AJ9//H1/xrraKPrtTsg+ rQOT/sa//wCe
H/j6/wCNL/Y9/wD88P8Ax9f8a6uij67U7IPq0Dlf7Hv/APnh/wCPr/jS/wBk X3/PD/x9f8a6
mij67U7IPq0Dl/7Ivv8Anh/4+v8AjS/2Tff88P8Ax9f8a6eij67U7IPq0Dmf 7Jvf+eP/AI+v
+NL/AGVe/wDPH/x5f8a6Wij65U7IPq0Dm/7Lvf8Anj/48P8AGl/su8/54/8A jw/xro6KPrlT
sg+rQOdGmXn/ADx/8eH+NL/Zl3/zx/8AHh/jXQ0UfXKnZB9Wgc//AGbd/wDP L/x4f40v9m3f
/PL/AMeH+Nb9FL65U7IPq0DB/s67/wCeX/jw/wAaX+z7r/nl/wCPD/Gt2ij6 5U7IPq0DD/s+
6/55f+PD/Gl+wXX/ADy/8eH+NbdFH1yfZB9WgYv2C5/55/8AjwpfsNz/AM8/ /HhWzRR9cn2Q
fVoGP9huf+ef/jwpfsVx/wA8/wDx4Vr0UfXJ9kH1aBk/Yrj/AJ5/qKX7HP8A 88/1FatFH1yf
ZB9WgZf2Of8AufqKX7JP/c/UVp0UfXJ9kH1aBm/ZZv7n6il+yzf3P1FaNFH1 yfZB9WgZ/wBm
m/ufqKX7NL/c/UVfoo+uT7IPq0Cj9nl/u/qKXyJf7v6irtFH1ufZB9WgU/Ik /u/qKXyZP7v6
1boo+tz7IPq0Cr5Mn939acq3EREkOwSr8yFxuUMOmQCMj2yKsUUni5vog+rR 7nIX/hK81SdZ
9Qm0m7mVdgkuNIjkYLknGSx4yT+dWBoWshbKP+1LQQ2csUsMS2AVFMZBUYVx xxjA7V09FZe0
X8q/H/M15H3f4f5HG3fgye/unurxtHubh8b5ZtGid2wMDJLZPAA/CpLfwld2 8cEEdzYw2kdy
lyYLXTkhDOpBz8rdSABnBrrqKFUS+yvx/wAxcj7v8P8AIxru28QT3LSRatbw xcKkYsg21QAB
yX5OByf5dKry6Z4imieKTW4CjqVYfYRyD1/jroaKHUT15V+P+Ycj7v8AD/I4 XxpZnT/h/BZl
t/kNDHuxjdtGM47dKKufEj/kUm/67p/Wijm5ncaVtDtLn/Wr/wBc0/8AQRXM tNeadfakkWi6
jeJczCUSwtbqn+rRcDfMGONvcD+p3dRM0l/BbwCTe8If5ZVQYCp1yj+vt3qB 7TUIwDIZEBIU
br2IcntzB/nB9DUWuVc5eTwHG0UGZrC5lh+UC/08TxFfLjQ/JuBDZiBBDdyM HrXWWkAtbOG3
CxKIkVAsMexBgY+VcnaPQZ4pv2DU/SUfW8jH/tD6/kfQ0w294Z1gRpzKIhI4 a6jULl3XA/cc
/cyemPwzTd2Bboqv9g1P0lH1vIx/7Q+v5H0NH2DU/SUfW8jH/tD6/kfQ0rBc sUU1rQR7Q93e
7iisQHiIBIBx/qveoI/s0wYxajdOF+9tlhOP/IdLRaXGk2WaKqWsllfRmS01 S4uEU7S0U0Lg
H0yI6mEEZk8v7XfbthfG+LoCAT/q/Vh+dG4STi7NWJaKj+zp/wA/d9/33F/8 bo+zp/z933/f
cX/xugRJRUf2dP8An7vv++4v/jdH2dP+fu+/77i/+N0ASUVH9nT/AJ+77/vu L/43R9nT/n7v
v++4v/jdAElFR/Z0/wCfu+/77i/+N0fZ0/5+77/vuL/43QBJRUf2dP8An7vv ++4v/jdIsEbo
HW7vipLAHfF2Yqf+WfqDRYCWio/s6f8AP3ff99xf/G6Ps6f8/d9/33F/8boA koqP7On/AD93
3/fcX/xukWCN40kW7virorqd8XIIyD/q/Q0WAloqu4t0kWN9Qu1duimWEE/h 5dSfZ0/5+77/
AL7i/wDjdJWfUepJRUf2dP8An7vv++4v/jdH2dP+fu+/77i/+N0xElFR/Z0/ 5+77/vuL/wCN
0fZ0/wCfu+/77i/+N0ASUVH9nT/n7vv++4v/AI3R9nT/AJ+77/vuL/43QBJR Uf2dP+fu+/77
i/8AjdH2dP8An7vv++4v/jdAElFR/Z0/5+77/vuL/wCN0fZ0/wCfu+/77i/+ N0ASUVH9nT/n
7vv++4v/AI3R9nT/AJ+77/vuL/43QBJRUf2dP+fu+/77i/8AjdH2dP8An7vv ++4v/jdAElFR
/Z0/5+77/vuL/wCN0fZ0/wCfu+/77i/+N0ASUVH9nT/n7vv++4v/AI3R9nT/ AJ+77/vuL/43
QBJRUf2dP+fu+/77i/8AjdH2dP8An7vv++4v/jdAElFR/Z0/5+77/vuL/wCN 0fZ0/wCfu+/7
7i/+N0ASUVH9nT/n7vv++4v/AI3R9nT/AJ+77/vuL/43QBJRUf2dP+fu+/77 i/8AjdH2dP8A
n7vv++4v/jdAElFR/Z0/5+77/vuL/wCN0fZ0/wCfu+/77i/+N0ASUVH9nT/n 7vv++4v/AI3R
9nT/AJ+77/vuL/43QBJRUf2dP+fu+/77i/8AjdH2dP8An7vv++4v/jdAElFR /Z0/5+77/vuL
/wCN0fZ0/wCfu+/77i/+N0ASUVH9nT/n7vv++4v/AI3R9nT/AJ+77/vuL/43 QBJRUf2dP+fu
+/77i/8AjdH2dP8An7vv++4v/jdAElFR/Z0/5+77/vuL/wCN0fZ0/wCfu+/7 7i/+N0ASUVH9
nT/n7vv++4v/AI3R9nT/AJ+77/vuL/43QBJRUf2dP+fu+/77i/8AjdH2dP8A n7vv++4v/jdA
ElFR/Z0/5+77/vuL/wCN0fZ0/wCfu+/77i/+N0ASUVH9nT/n7vv++4v/AI3R 9nT/AJ+77/vu
L/43QBJRUf2dP+fu+/77i/8AjdH2dP8An7vv++4v/jdAElFR/Z0/5+77/vuL /wCN0fZ0/wCf
u+/77i/+N0ASUVH9nT/n7vv++4v/AI3R9nT/AJ+77/vuL/43QBJRUf2dP+fu +/77i/8AjdH2
dP8An7vv++4v/jdAElFR/Z0/5+77/vuL/wCN0fZ0/wCfu+/77i/+N0ASUVH9 nT/n7vv++4v/
AI3R9nT/AJ+77/vuL/43QBJRUf2dP+fu+/77i/8AjdH2dP8An7vv++4v/jdA ElFR/Z0/5+77
/vuL/wCN0fZ0/wCfu+/77i/+N0ASUVH9nT/n7vv++4v/AI3R9nT/AJ+77/vu L/43QBJRUf2d
P+fu+/77i/8AjdH2dP8An7vv++4v/jdAElFR/Z0/5+77/vuL/wCN0fZ0/wCf u+/77i/+N0AS
UVH9nT/n7vv++4v/AI3R9nT/AJ+77/vuL/43QBJRUf2dP+fu+/77i/8AjdH2 dP8An7vv++4v
/jdAElFR/Z0/5+77/vuL/wCN0fZ0/wCfu+/77i/+N0ASUVH9nT/n7vv++4v/ AI3R9nT/AJ+7
7/vuL/43QBJRUf2dP+fu+/77i/8AjdH2dP8An7vv++4v/jdAElFR/Z0/5+77 /vuL/wCN0fZ0
/wCfu+/77i/+N0ASUVH9nT/n7vv++4v/AI3R9nT/AJ+77/vuL/43QBJRUf2d P+fu+/77i/8A
jdH2dP8An7vv++4v/jdAElFR/Z0/5+77/vuL/wCN0fZ0/wCfu+/77i/+N0AS UVH9nT/n7vv+
+4v/AI3R9nT/AJ+77/vuL/43QBJRUf2dP+fu+/77i/8AjdH2dP8An7vv++4v /jdAElFR/Z0/
5+77/vuL/wCN0fZ0/wCfu+/77i/+N0ASUVH9nT/n7vv++4v/AI3R9nT/AJ+7 7/vuL/43QBJR
Uf2dP+fu+/77i/8AjdH2dP8An7vv++4v/jdAElFR/Z0/5+77/vuL/wCN0fZ0 /wCfu+/77i/+
N0ASUVH9nT/n7vv++4v/AI3R9nT/AJ+77/vuL/43QBJRUf2dP+fu+/77i/8A jdH2dP8An7vv
++4v/jdAElFR/Z0/5+77/vuL/wCN0fZ0/wCfu+/77i/+N0Acr8SP+RSb/run 9aKb8RkCeEXA
klf9+nMpUnv/AHVA/SirjsJnZP8A8jHZ+1ox/SP/AD2+o61jeIdWexa5ivrE yZH7hhLtXZuH
I+XrwAfQ8YAAFbL/APIx2ftaMf0j/wA9vqOtaUsEMxjMsSOYnDpvUHYw6Eeh GDzxjHbHyXSn
ySvYuEuV3OTs/FklhpQl1LT9RdEP+vih3IgyAAzkgFgRjjpgDqPl6CL5dclH TFont/y1l+n9
Pw6jjP7A8SC2Ph8yy/2MFCed5EPXfknBl3berZzngjaMHHZxfLrko6YtE9v+ Wsv0/p+HUXXU
N4mEJSk25IzrvUrjT9culudRghtRCjwxNGWbJYLwoAYnKN0PGV4G35dCwvft Eqj+0bOcGISC
OKMo4GFIbl+Bj2HUdMfLBq+l3d19pe0mtlM0KRNHPCGB2MT1PA4J6qcYHTHy XLKG8giiSea3
KpEqlY4SmGAAJByABlW4wMcdNvyy3Fx0/r8Bq9ylqiI4RZWjWI+R5hkYKuz5 dwJPGCMjHfpW
RrVzJq1+1rZwLcoSscbyyuRJgrI65JwEYJtOByORnodnUraK7QwTqWjaOPID EdFU9RzWFFZa
na6rEttIBbQyebFJKd4RfLKbMAgkgk/h1JPFYqlSkpSfxWdv0+dzWNapTnFx 2TT/AK8iPRi9
1qRvJfNjuPJKzLOVV5SShGEViEjQDCjk/Ox787i/8hD/ALdJP/RkVR29otuS 3mzSOQAzO55w
AB8owucADOO1SL/yEP8At0k/9GRVjQU1H95v5G+Jre2nzCXNxHawNNKcIuPz JwOvHU9+KwLK
J7IW9t9oIuwhaKIofmUkk+gGcHg4Jxzg7dm3qCs+m3SIpZmhcAAZJODWXPcy N4gtpkt5jbLG
Q7m0bcD83cru7jpWyOc1rS6S7iLKMMrbHX+63p+v19QDkVahiaeURqQCeST2 HrVLT8/ZSSrL
ulkYBlKnBdiODz0NWgSCCCQR0I7UgLkmnOJW8lo/L4273Oegznj1zVQgqzKc ZUkHHtQZJWdm
aRxk9Fc46UlDAlgt3uCwRkG3Gd5I659varP9msLd2MiGYNkBWJDLgcc4wc5/ z0o8g8Mw+hIo
DPtZS7FSc8sT26fSmAAggEdDUdr/AMeMX+/N/wCjpKkqO1/48Yv9+b/0dJSA BG012kKEBpGV
AWLYHyuTwrD+6KnvNJurW0muVuIf3KNJtCP82AeOXNVpEXz4mltxc25bE0O1 TuXY64wxAIO/
kGmyWegRQTGw8Mx2100TpHNHBChUspXqGyOv5V0RceXUwkp82hYqO2/5B9l/ 16Q/+i1qSo7b
/kH2X/XpD/6LWufobk9pNAug3bSRmRcztKm8r5m0sMHHsoH0AqC6hktUkkjt ChhVncm4ndWV
VJIy0e3twc/zqreWQa1uTAJBK8bhUWVlUsQf4c7eSf1qxqELSpePEkTPJFKE xtDEspA/5Zg9
/wC9+Jrno4d+85vVbGtSqtOX5k1FFFdBmFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
AFFFFABRRRQAUUUUAFFFFAHI/Ej/AJFJv+u6f1oo+JH/ACKTf9d0/rRVx2JZ 2lzKYbhXW3eV
vKQZS1MpUbV9FOM8fXHtUf26b/nyuf8AwWv/APEVt6Z/rZv+ucX/AKDVPWNc TS7x1utW0zTL
VI4iJb/gO7mT5QS6jpHnH19KSQXKH26b/nyuf/Ba/wD8RSfbZd277DcbsBc/ 2a+cZJx9z3P5
mtbRdV/tOWUxX9jf2vlJJFc2Q+RstIpGd7A4MfY+tVvEesGwkWEyiJGj3bvM CEnJ7k+1VGHM
7Ia1Kf26b/nyuf8AwWv/APEVWvNeg06IS3wNrGc4eeyKA4UseSnZVZj7KT2r grvxZr9je/aL
fVo2CtkJNfxlSPQgviuu+Ia/8JN4E0SHzhbf2reWoyrh8b1JwAJFD464+fpn AxvXaeGcGk3u
Q5qzfYdP4q0je7TXyKUyHzGy7du8HPHGPKkz6eW/904a/ibRot/mXqps3b9y MNu3fuzxxjyp
c+nlv/dOPEdR8G3MFxFb2lvq6yurux1SwWxjVFxlt7Slccjk4HI7kVPP4Fu3 sLJ7BTPcyxbp
gs8LQg7ps4k3gYCxZ4yOvI4B1+pRtfn/AA/4Jn7Z3tyns7+JtGi3+Zeqmzdv 3Iw27d+7PHGP
Klz6eW/904H8TaNFv8y9VNm7fuRht2792eOMeVLn08t/7px4QvgvXWlCC2t9 rBCkpvYRFJvJ
ChJN+1iSrDCkng+lVJvDup2+nG+lgjEKqrsonjMiK33WaMNvVTkYJAByPUU/ qEf5193/AAQ9
u/5T6CfxNo0W/wAy9VNm7fuRht2792eOMeVLn08t/wC6cD+JtGi3+Zeqmzdv 3Iw27d+7PHGP
Klz6eW/9048Li8N2y+H7TU7y9uoftm8QGOyMkO5SwCPJuG1yVPAU8EE8HjST wRY3etT6Vp+t
TS3FpdLBdCeyEeFMgjMiYkbcAxXg7TyPfCeBit5/h/wQ9u+34nsT+JtGi3+Z eqmzdv3Iw27d
+7PHGPKlz6eW/wDdOLsF7HdRebbxXU0e5k3R2sjDcrFWGQvUEEEdiCK+cdX0 dNGjhhnus6kc
me1VOIB2DNn7/quOO5zkD6Y+GD+Z8NtEbfvxCVzv3dHYYzvfpjGMjGMbUxtX KthlTSfNe/kX
Co5O1rEXmv8A8+l9/wCAcv8A8TR5r/8APpff+Acv/wATXZ0Vz8qLucZ5r/8A Ppff+Acv/wAT
R5r/APPpff8AgHL/APE12dFHKgucZ5r/APPpff8AgHL/APE0ea//AD6X3/gH L/8AE12dFHKg
ucZ5r/8APpff+Acv/wATR5r/APPpff8AgHL/APE12dFHKgucZ5r/APPpff8A gHL/APE0ea//
AD6X3/gHL/8AE12dFHKgucZ5r/8APpff+Acv/wATR5r/APPpff8AgHL/APE1 2dFHKgucZ5r/
APPpff8AgHL/APE0ea//AD6X3/gHL/8AE12dFHKgucZ5r/8APpff+Acv/wAT R5r/APPpff8A
gHL/APE12dFHKgucZ5r/APPpff8AgHL/APE0ea//AD6X3/gHL/8AE12dFHKg ucZ5r/8APpff
+Acv/wATR5r/APPpff8AgHL/APE12dFHKgucZ5r/APPpff8AgHL/APE0ea// AD6X3/gHL/8A
E12dFHKgucZ5r/8APpff+Acv/wATR5r/APPpff8AgHL/APE12dFHKgucZ5r/ APPpff8AgHL/
APE0ea//AD6X3/gHL/8AE12dFHKgucZ5r/8APpff+Acv/wATR5r/APPpff8A gHL/APE12dFH
KgucZ5r/APPpff8AgHL/APE0ea//AD6X3/gHL/8AE12dFHKgucZ5r/8APpff +Acv/wATR5r/
APPpff8AgHL/APE12dFHKgucZ5r/APPpff8AgHL/APE0ea//AD6X3/gHL/8A E12dFHKgucZ5
r/8APpff+Acv/wATR5r/APPpff8AgHL/APE12dFHKgucZ5r/APPpff8AgHL/ APE0ea//AD6X
3/gHL/8AE12dFHKgucVJceVG0klveIiAszNaSgADqSdtNjvY5nZIorp2UAsF tZCQDnGfl9j+
VdPrv/Ivan/16S/+gGs7w/8A8hW//wCuEH/oUtHKFzN81/8An0vv/AOX/wCJ o81/+fS+/wDA
OX/4muzoo5UFzjPNf/n0vv8AwDl/+Jo81/8An0vv/AOX/wCJrs6KOVBc4zzX /wCfS+/8A5f/
AImjzX/59L7/AMA5f/ia7OijlQXOM81/+fS+/wDAOX/4mjzX/wCfS+/8A5f/ AImuzoo5UFzj
PNf/AJ9L7/wDl/8AiaPNf/n0vv8AwDl/+Jrs6KOVBc4zzX/59L7/AMA5f/ia PNf/AJ9L7/wD
l/8Aia7OijlQXOM81/8An0vv/AOX/wCJo81/+fS+/wDAOX/4muzoo5UFzjPN f/n0vv8AwDl/
+Jo81/8An0vv/AOX/wCJrs6KOVBc4zzX/wCfS+/8A5f/AImjzX/59L7/AMA5 f/ia7OijlQXO
M81/+fS+/wDAOX/4mjzX/wCfS+/8A5f/AImuzoo5UFzjPNf/AJ9L7/wDl/8A iaPNf/n0vv8A
wDl/+Jrs6KOVBc4zzX/59L7/AMA5f/iaPNf/AJ9L7/wDl/8Aia7OijlQXOM8 1/8An0vv/AOX
/wCJo81/+fS+/wDAOX/4muzoo5UFzjPNf/n0vv8AwDl/+Jo81/8An0vv/AOX /wCJrs6KOVBc
4zzX/wCfS+/8A5f/AImjzX/59L7/AMA5f/ia7OijlQXOM81/+fS+/wDAOX/4 mjzX/wCfS+/8
A5f/AImuzoo5UFzjPNf/AJ9L7/wDl/8AiaPNf/n0vv8AwDl/+Jrs6KOVBc4z zX/59L7/AMA5
f/iaPNf/AJ9L7/wDl/8Aia7OijlQXOM81/8An0vv/AOX/wCJo81/+fS+/wDA OX/4muzoo5UF
zjPNf/n0vv8AwDl/+Jo81/8An0vv/AOX/wCJrs6KOVBc4zzX/wCfS+/8A5f/ AImjzX/59L7/
AMA5f/ia7OijlQXOM81/+fS+/wDAOX/4mjzX/wCfS+/8A5f/AImuzoo5UFzj PNf/AJ9L7/wD
l/8AiaPNf/n0vv8AwDl/+Jrs6KOVBc4zzX/59L7/AMA5f/iaPNf/AJ9L7/wD l/8Aia7OijlQ
XOM81/8An0vv/AOX/wCJo81/+fS+/wDAOX/4muzoo5UFzjPNf/n0vv8AwDl/ +Jo81/8An0vv
/AOX/wCJrs6KOVBc4zzX/wCfS+/8A5f/AImjzX/59L7/AMA5f/ia7OijlQXO M81/+fS+/wDA
OX/4mjzX/wCfS+/8A5f/AImuzoo5UFzjPNf/AJ9L7/wDl/8AiaPNf/n0vv8A wDl/+Jrs6KOV
Bc4zzX/59L7/AMA5f/iaPNf/AJ9L7/wDl/8Aia7OijlQXOM81/8An0vv/AOX /wCJo81/+fS+
/wDAOX/4muzoo5UFzjPNf/n0vv8AwDl/+Jo81/8An0vv/AOX/wCJrs6KOVBc 4zzX/wCfS+/8
A5f/AImjzX/59L7/AMA5f/ia7OijlQXOM81/+fS+/wDAOX/4mjzX/wCfS+/8 A5f/AImuzoo5
UFzjPNf/AJ9L7/wDl/8AiaPNf/n0vv8AwDl/+Jrs6KOVBc4zzX/59L7/AMA5 f/iaPNf/AJ9L
7/wDl/8Aia7OijlQXOM81/8An0vv/AOX/wCJo81/+fS+/wDAOX/4muzoo5UF zjPNf/n0vv8A
wDl/+Jo81/8An0vv/AOX/wCJrs6KOVBc4zzX/wCfS+/8A5f/AImjzX/59L7/ AMA5f/ia7Oij
lQXPIPiMxbwi5Mcsf79OJYmQ9+zAGitT4xf8i+P9+P8Am1FNAzudM/1s3/XO L/0GnT2V5/aM
l3aXUEfmRJGyywGT7pYggh1/vn8qbpn+tm/65xf+g1pULYTKNnZ3MV5PdXVx FK8saRgRQmMA
KXPdmz9/9KzvEvh+bWoP9FvHtZwu3erFeO3T6mt+quoXT2dp5scSyuZI41Vn 2gl3CjJwcfe9
KqMnF3QXPJV+FfjG41NRd+KvLsN3zNBcSmQr7AgAH8a6f4l3P9geENNmt4pJ ksb2BxCJSGkS
JWYgncM4VCSdr4wW28b16VrjULFmmmsrQRz3EauY7klgWKRggeUM9jyc++MC r2ozz2unzz20
BnmRcrGBkn1OO+BzgcnGO9ayrTm1foTyLVdz5ajurGwN5HH4b1hba4ieK8jn vAWwrM2VYQDY
VaCQnIYYjcY+U429O8SQW9q2mXWiaha6fBazRkvKWk+VLsbSRFgHLSDO3A8p iRwceuaP4tJ1
C4V/tU9kArSStHuMbEcbQmSQT2A468AGutsNStdTikktWkIjfy3EkTxsrYDY IYA9GB/GuirV
mk046fMl01CdubU+bLfxO2nRranw9qIsLRNiW0lxlWCtM7i4Voikg3LKfuqV 8psEFSaraz4j
1PU9FNlcWet27xQrC8SXri0xFuGTAUOCBDJn5sZjc/wkV9G33iL7LfS2lppO o6k8ABuGtFj2
w5GQCZHXccc7U3EDGQMjM9/rUFnCZIyk4iuYre4VJBmDzGUAsOcY3qcHHBzW f1p3vyr8Rezt
1PmPS9ROhWc3l6FqUd8beW3uH+0MsEinzQxkiKZJURyfxAAxE4+U1of8JM2n a7datZeG763n
nufPvPtE5fCpI0jImI12DdC+SdxHlN02tXvtv4vtZLrZc2N5ZWrSzQxX1yYh DI8e7cBtkLLw
jnLKowp9gdBvEWhqbUNrOnj7XIY7bN0n75w20qnPzENxgd+KbxTk7uP5h7FJ WufKmr3F7qVp
Eb3S7kahbbkku2DAvGu/AkUj7y+VKN2ekbAj5CR9JfDVZE+HmjxzBxLHG0bq 5yyFXYFTl2wR
jGMjGMbUxsXZl8RaHDqEmny6zp8d7GpZ7d7pBIqgbiSucgY5+lNbxLoKNbK+ t6arXTFLcG7j
BmYNtITn5iG4wO/FZVazqJKxUYcrbNSisxvEehJM8La1pyyo6xuhukDK7EhV IzwSQQB3INR6
rrj6dfW9lBpN9qNxPG8oS1aFdqqVBJMsiDq46ZrEs16Kw08TQfb/ALNcwfY0 S3knne4nj/cb
BGSG2swGBLySR93uCDU7eJ9ASxgvn1zTFs53McNwbuMRyMOqq2cE8HgUWA1a KyR4gsoV1J9R
mgsIrCcRSS3EwRCGVWVtxwADux9QRT7nxFotpb2s02r2EaXgzaM9yii46Y2E n5uo6Z6ilfS4
GnRXP2njHR30qC+1G+s9MEiI225u41GWRWwCT23gcgH2wRnSOtaUNRTTjqdl 9ukTzEtvPXzG
TGdwXOSMAnNU1YC9RVPTtX03WIXm0zULS+iRtjPbTLKqt1wSpODyOKuUgCii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA z9d/5F7U/wDr
0l/9ANZ3h/8A5Ct//wBcIP8A0KWtHXf+Re1P/r0l/wDQDWd4f/5Ct/8A9cIP /QpaXUZx/jnU
p4Pij4dsZL3VI9Nmt3M9vYyzgyH58HbCdxOQOnp6Vu3vifS/CmhLc2lvq91L d3It7a2vGuBJ
LMRwAbj5lX3Ax9TTPEnhXWL7x9o3iTTfsMkenwsjQXM7xFydw4Ko3HzU/wAT +GdX8V6baySr
Y2GqaddLdWey4eeJyOzkxoQCfQHpXUnBxgnt1+8zlfmbXbT7jnvitcatN4NC anp1tahb63Mb
292Z1fO/I5RCCMDtg561pTeIPsHxC8Qc6jL9g0c3XkNff6M2Ap+WLZ8rf7WT 1PHNWPF/hzxN
4v0FrCaPSbNkuIZYwl1JIDt3b8sYx6rgY9eara94YvbbWfFniN5bc2dzoclu iKzeYGCDkjGM
fKe9NSioWfn+SBJua+X/AKV/kLbfE6ZtN0LVb3Q1t9M1a4+zCVLzzHifJAJT YMrkdc568dM3
NN8fza9rOpWGjabaTCxmMRW41AQzygHDMkexvlB7lhnjp0HJeEvDGp+K/BXh KGf7Hb6PY3DX
TOszPPMQ7YXbsAUZyM7j6+1a+v8Aw3uvEer2t3JYaPpc6XXmzahY3EnmyoCx H7vYq7ySMsWJ
46npVyhRjNxfd/np1M4ym4X8l+v/AADWu/H87f25PpOjre2OiEpdTSXXlM7D O8RqEbdtA6kr
ntXUaZqsGs6Jb6pYhmiuYRLEHGDyOh9D2ribf4eHSta1S4h0fQdatL6Y3CjU xslt3JO5Q3lS
Bl79q7XTLSe10OC1aKztJ1i27LJP3Mbf7AIHA+grnqKHJ7vl+Wv4msb82v8A XY8b8P8AjKwv
jqFr4z17XdK117jCOk8sMUA4AVUQ7RjHO9cc9etdEj3Wq/GW70i51XUXsF01 JVjtr2WBC+E+
cCNh1yT6c1peI/C3iXxhoVvpGrRaHEyyq0moRSSPIFB5McZjG1jwD8+OtNh8 Ga1pHj19e0td
PuLQWCWUcNzdPE4CqoySsbD+Gujng9dnZ+m2luxnaX9eu3noc5deJ9ZsvD/j bw/PqVzLdaME
NpfhysxjLAAMwwSwGOepyc0zwnreqeP9V0jTYdXvbbT9Is45L+SO6aOa8lIG QSDuK54J+vOS
tdE3w5vX8MeIlmvLabX9dIeaUhkhjwwIReCdo55xk8cVVj+G+raRe+HNX0Ke wh1Kxt0t9QR3
dIrpQADyFJ55GSPQ9RTjOnbz0187b/f+OoSUraba/ddaf16HqFFFFcJsFFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQB5p8Yv+RfH+/H/ADaij4xf8i+P9+P+bUUkB3Omf62b/rnF/wCg 1pVm6Z/rZv8A
rnF/6DWlQtgYVT1O3mubLZbiMyrLFIokYqp2SK2CQDj7vpVyimBytt4WtrOZ H0/w3oOmOZIj
JPZgK5RZFcrxEuc7Bxn0rpIrS2gYNDbxRkDaCiAYGAMceyqP+Aj0qaigDnNR 0i2bVJHfw7Ff
QOiuCI4cLKWbecORyRsye+B6Vc0Cy+xQ3arp62EclxvjhAQYGxBnCEjqDV+4 bbPaDdjdKRjd
jPyMcfeGfybp04yLFVzO3KTyq/Mc5LY67purahcaPDptzb37rM4u53haGQIq EjajeYpCqcHa
QQeTkYsz6RPeWuuW08dlEt6SIZbdCHb92qh5PVww4I7BaoajqIhtpr2e5uEk +0PDEsJb5SrM
owu4KeFLHdnPI6YFX7HVpLiW1YXVrdQXDmMNDGUKnYX5yx7DoQDz+FcyrXSu tHombcuuj1Rz
mm+DDe+ELh72B11i+huG2XNzLJFbvMWJARiVQ4bBKqO/UHm/4g8NajfXF2tg th9n1CxjsZ3m
dkktlVmO6MBSH4c4UlcFRzzx1F3dQWNnNd3MgjghQySOQTtUDJPFJZ3cF/ZQ 3lrJ5kE6CSN8
EZUjI4PI/Gui+tzPb+v68jza70rVNQu5/DEFij2yT3s5vpYp4w3nJIAG3QiN vmlAyjsSBnHX
G74s8M6vrTtBZyx/YmtfKjQ6hNbLA/OWMcS4mBG0Yc4G3gHJz2dVbq/itLqz t5FcvdymKMqB
gEIz8+2FNC6B3OTm8F3MtpPGPsfmyWuoQhjn71xMJFOdvTA59/WtjVfDFjre tWVzqdhY31pb
W0sflXUKy4dmjIYBgR0VuevNb1UdT1ix0eKN7yVwZW2RRRRPLJI2M4SNAWbA BJwDgAk8Clfb
y/r9QOQ1PwHc3M939ja0t7YkNbQxyPCF2m2KpmMAoP3DDKnK5UgHpUcvg7Vh BHJY2VrZ37NM
HuW1y5umQOI1JJmiYSghADG64G0EEHkdxYX0GpWaXVsZPKfIAkiaNgQSCCrA MpBB4IFWaabW
gJ9jh/FHhu/1HX7KazQuNglcC6ltVaSMMgBli+aMlZmIIB/1eCOeJ9O0DVdG ljksNPsNs8Hk
3MU+pzSGE+Y7lkleJmk3eYSQwXkDn07GilbSwHnNh4d1/QtWtBa2On30hs5E Z5riSKJP3dsm
NwibkmNvlwMjv2pI/h9qUNq+k29xbwafJa+RNcCZ3NwRb+SpMDJiMj+9HIpK gAg9vR6q6jqV
ppVm11ezCKIEKPlLMzE4CqoBLMTwFAJJ4Apt6DTa2MXwrolzpTXUt5ZpDcTL GhkXWLm/Lhd2
P9coKAFjwM9a6SqWm6pa6tA81r54CPsZbi2kgdTgHlJFVhwQelPv7+LToI5Z ldleaOEBACdz
uEHXtkjNDu2SrdC1RRVTU9TtdIsmvLxpBCrKn7qF5WLMQqgKgLEkkDgUhlui qem6nBqtu09v
HdoitsIurSW3bOAeFkVSRz1xirlABRUFpdwX0Jmt33xh3jJwR8ysVYc+hBFT 0AFFFVLDVLDV
BObC7iuVt5TDK0TblVwASuRwSMjPoeOooAt0Vmf8JBp39sDSy9wLktsDG1lE Rbbu2iXb5ZbH
bdnijU/EGm6RPDDezSI8vOUgkkVBkDc7KpEa5P3mIHXng0dvMDTooooAKKKK ACiiigAooooA
KKKKACiiigAooooAKKKKACiiigDP13/kXtT/AOvSX/0A1neH/wDkK3//AFwg /wDQpa0dd/5F
7U/+vSX/ANANZ3h//kK3/wD1wg/9ClpdRnQ0UUUxBRRRQAUUUUAFFFFABRRR QAUUUUAFFFFA
BRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAF FFFABRRRQAUU
UUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRR QAUUUUAFFFFA
BRRRQAUUUUAFFFFABRRRQAUUUUAeafGL/kXx/vx/zaij4xf8i+P9+P8Am1FJ Adzpn+tm/wCu
cX/oNaVZumf62b/rnF/6DWlQtgYUUUUwCiiigCreAO9tGzsokkZTtkKE/u36 EMD78Z6ZwMbg
5rOJt2Xn+bOcTuOu734+8fpgf3RguAxntCDIAJSTtJAI2N97AOR064Gcc5wD YoA4HxDps+kX
B1K6uBd2cty5PmBh9kDbiMckYJwpPHO3g54taZoupX9lYTSR/wBmyRW0Sb5N 3mkhTkYVgQp3
d2ByuCtad7qssUE1498tsiTPFHGQCpKsV+YbSzZIJIUjj6Fqv2+pzPNbrNBA I7g4ieGcyZO0
sDyo4wp5BPasK9SniYRjUTsn8n/XyLpwlTk3F6lfxPZajqWnQ2WnNDG0twhm lmTeiRqd5ygZ
SwJULgEferhn0W5tdVttK1rw8viGOOO8a3SBIVjZHeFw3lzS/KFZmQZJIwCO K9QlljgieWWR
Y40Us7ucBQOpJ7CiGaK4gjmgkSWKRQyOjBlZTyCCOorZL+vUm55gnhLXk1XS ZJ7V5b2w+yRr
qMKWuxolCiTfI+bhm5k4G1SuOpJzfsfCcVzNpsF94TSOSGctqV7L5DLfnypF LsVcvICzA4dR
97pwa9DqCe7gt5reGV9sly5jiGCdzBSxHtwpPPpVXuI8xvPBF81zbrNYalJZ wq8dpHpxsmaz
xPIylftA/d/I0eDEQRsAIG1a7fWYb+31fTtXs7GTUFt4pYJbaOREkw+wh03s qEgoAQSOGJB4
wd6s/U9e0fRfL/tXVrGw83Pl/arhIt+OuNxGcZH50rhu7nHeINI1TXLlruTw 5I1xParFYyST
ws2lTCRv3p+fCkgxtmIsfkx2Ga9z4FlkiuphpUTXkkN8/mb13NOZ99u2c/eA LFT/AAZPTNek
KyugdGDKwyCDkEVDPdwW81vDK+2S5cxxDBO5gpYj24Unn0prS3lcNzz248Cy yxXMw0qM3ckN
8+/eu5pzPvt2zn7wBYqf4cnpmotR8KapczXyw6MY76Q3hn1QTR5vYpFcRw7t 3mDBaPhgFXyu
D0r06q19qFlpdo13qF5b2lshAaa4lWNFycDLEgdaSdv67gcHrvg1Y5rhNO0F pLF2t5vs1qlu
Y5ZlEwZpYpWVZBzHu5Vj8pDZXI3Z9N1KHQdAlhsoZLvS2jkksYJNiuPKaNlj LNjI35UM2Plw
SPvDobS8tdQtI7qyuYbm2kGUmhcOjD1BHBqenqgOH161vdeNrdX/AIPnvLSJ Zov7NuJrdnDs
E2TFTJ5fGHXO4sN2QOTjNHhXU1urYX2jrqWpxzWTprTPE3kpGIxIoLt5incs jYVcHdnOSRXo
V9f2emWj3d/dwWlsmN808gjRcnAyx4HNR6bq2m6zbtcaXqFpfQq2xpLWZZVD YBwSpIzgjj3p
LyB7Hm+k+DdRsrO8Elhqj3rwqt2JHslg1ACRWcb4wsrs6hgGm7OwYjJrqbnR Y77wnBp9joUm
jxG8hdrOJ44GjVZlZmBgchTgE5Vs/jXV0yKaKdN8MiSJuK7kYEZBwRx3BBH4 U7g9dTgvFXgx
pxYRW0Orahp0ZlM1v9phu5PMbZtfF8XTACsOCCN3H3mqpN4Z1WTxFpt2NPvD JZvarFeOtluM
C7fME0vMxk5kBCEIR65OfS6KE7A9VY880vRL3w/qLzWfhU4LXkTtaNbp5vmy q8chy6kqFG05
+YHgKRzUEHgu+Xwlfo1iI9VlFsmUeJpHhSOASRKzBkAYxsNrDaxA3cHNegXW p2FjbT3N3fW1
vBbkLNLLKqLETjAYk4H3l6+o9amguIbq3juLeWOaCVQ8ckbBldSMggjgg+tJ aL+vUd9bmB4L
0kaNo0lsttqFqjTs6wXq2qlMgfcW2/dqpIJwOckk9ai0ybV7e91l/wDhH7pR PqEbxGaeAK8R
EcbONrsflCs2CBkYHU4HSpLHI0ipIrNG21wpyVOAcH0OCD+IqomtaVJqr6Um p2baig3NaCdT
MoxnJTORwQenenfW/wDXT/IVtDGvYtRvfFFnLHpN1EtnKSbuW5ja3kj2MPkj 3kiQlgN2xSBu
G7Bw1DWLLWr2O6kXR5PO1nSorKVEuIiLGQGTJdiw3KPOPKBj8h45FdtRSWg7 v+vvEUbVAznA
xS0UUCCiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAz9d/wCRe1P/ AK9Jf/QDWd4f
/wCQrf8A/XCD/wBClrR13/kXtT/69Jf/AEA1neH/APkK3/8A1wg/9ClpdRm1 drdPaSLZTQw3
JHySTRGRFPuoZSf++hXFwa94kh/s65vJLa+jnv57X7Jp1iYpJPLEw+9JMyjJ jB6rj1Nd3WXD
oNrB9k2yTH7LdS3SZI5eTfuB46fvGx9BTF0MR/H1nGVLWt2XmeKCK0KRRyec zSqULtKI85iY
YyBkcFtwFamp+IodL0+yv7pJreCVXkljkh3SIqwvIQQG+Ujb/tdMd8irN4Lt njuVg1K/tvtJ
PnFBC4dS0rFCskbKVJmbgg9B75uP4btDpmn2EE9zbR6ehS3eFwGT920YPIIy AxI4xkDtxR0Y
9Lj9M1s6ro0moxaddQgJvijlaJjMNoZWRkdkYHIwd35Vy+meOr51a81DRtQF uNPtrqVIlhKw
BvM3y58zJU7QQoLNgfdrqNF0C30S3uo45pbiS7mae4mlSNGkcgAkiNVXOAOQ Mnqcmqdp4PtL
XTbuwN9fTxXNqtnulZN0cS7gqqQg6ByMtk8DOael38v6/r8BdCGy8faJf+J2 0GCXNz5kkSv5
0J3Omdy+WHMoxtblkAOOCcjKa34nmgvBZ2FneMIr22gub0LH5MW90JQ7mDEl GHKqQNw5BzjR
sdBOnag89tqt+to8jymwbymhDOSWIJTzB8xLY34BPTHFQ3fhWC71J7o399HD LPFcy2kbJ5Uk
se3axyhboiggMAcdM80uwPqYsPxW8Nzw3cqSMUt4xKu2e3YyqXVAcCQ+X8zp /rfLxnnGDjZH
id3kihj0LVHuCu+eH9wGtk3FQzkyBSDtYjYWJAz6Zbb+F5rOzaztvEWsRWyq q28Y8g/ZgrAg
KxiLMMDb85bg8881DZeCrbS44E0zUr6x2KUm8hYALgFy+GUxlV5Z/uBPvH2w PbT+v66j0Iv+
E4hMVndf2dqCQXcQeCJoU8ybc8Sqw/efKMygYYA8E8ADc2fxnOZ7OG20S+84 3rWl5bSeT5kB
EJkBz5uw5BVshm4yOvFTar4QFzp2nW9jez281ikUEU2VJWNZInLcoQXxEMZG MnkVP/wiMHko
TqV+b0XX2p77MXmyPs8v5hs2Y2fLgKOBnrzTdrO39dv+D+Aiva+NrWVLUvaX jwOIUmvliRIY
5ZVVkQguWydyD5QwBYAt1xc0XxRDrU8Ma6df2i3Ft9qt5LlUAmj+XJAVyQRu XhgvXjNVovBF
jC8CJfX/ANkjMLvZl0MU0kShUkbKbgw2ocKyqSoJHXOnZaHbWL2DRPMTY2ht I9xHKHZyeOvy
DpjvxT0v/Xb/AD/AT8ih/wAJdA15Jbx6dfshaaK3uCI1juZogS0aZcNn5XwW CqdpwemcvTNd
1qD4dXXiG8hvJr825ukt7gW4VcqDiPyyP3fPG9t+BzzWxD4UtYdU+1/bLySF JJZobN2QxQyy
Ah3X5d+TufgsQN5wBxi4dEtW8Of2EzSm0+y/Zd27D7Nu3OR3x3qen3f8ErS/ kYOn+L7gX95H
qGl6jFB9ujtxIyw7bUvHHtRyrktlm6rvAzyR2s+HfHmi+J9SlsdPkzIsZmQ+ dC/mICAW2o7M
nVeJAp56cHFyHwzAlnJbz3l3dNLdRXck0vlh3ePZjO1QuD5a5wPWpNH0JtF/ dRatf3FmieXD
aXHlFIVHQKwQOcDgbmbj1601br/Wn+ZPQgbxTGLllXTL9rMXC2wvh5XlNIZB HgAvv4YkE7cf
KcE8ZWXxTbprLaXFY31xcI7K5iVNqhRGWYlmHAEq+5wcA8Zjn8JJMbhE1fUo bWWXz0tozDsh
m3iTzEJjLZ3jdhmK8njHFSad4Xt9PvpL1r69urqUSCSW4ZMtvEYJwqqB/qlx gAcnj0lbf1/W
9ynuZd58R9KsNMsr66tLqBb5TJbR3EtvA0sYVSXBklVQPnA2khjzhSBmrdv4 3sbyWJrWxv5r
J5YoTfKiCFWlVGj6uGIPmKMhTgnnFWZfDERtdNjs9Sv7GbT4Ps8VzbmMu0eF BVg6MhztU/dy
COMc5mXw9b+RLHJc3MrS3UV3JIxUM0kezHRQMHyxkAdzjHatL/13/wAvxE9i toviKS80W91H
U7KWwitZp1Z32EMkbsMgI7HgLg5xk5wMYqOTxbLEkYfw3rIuZQ7paj7OZDGo G6TIl2gAsowW
DEnhTzV630C2gsb+xee4ns715GMEpXEYkJLqpADYJYnkkjPBA4qjJ4SlljiL +JNZN1EHjS6/
0cSCNgN0eBFtIJVTkqWBHBHNTr/X9f1qPS4kPjaxup0+zWN/NZtNFCb5UQQq 0qo0fVg5B8xR
kKcE84rC0fxhqC3t5davBqiRSNMLayMNsykpOIUWJo3L7yWUN5ny5OQVUV09 v4W060sjZ2/m
x2/2iG4VFYfIYhGFUcdMRrnPPXmqep+EIJrBvsjStdx+a9uXnEYWR5lm3bvL bBV1GPlYY4IO
arRO/wDW353Fq1YtaZ4oh1C9lspNPvbK6iEheK48oldgjJ5R2HIlXGD69Kgt fGVre2V3eQad
fG2tIBNJNIYYk5jSQLueQDO1wcn5Rg5I4zR0rwdfiJrvU9ZvItVllkaSa1ki fMbBFMZJhVTx
Ep3CNCOgPUnRj8H2EOhyaVFcXSxvJDKspKM8bxLGEYZUqceUp5BGc0dNe349 f67gjNj8epqN
vplzpGnzXcVxeSWs6xywSGIrGz8Msuw9j8rNxkdeKtWvja1lS1L2l48DiFJr 5YkSGOWVVZEI
Llsncg+UMAWALdcTjwjEIhnVdSa6+1/bDdlovML+X5ZGNmzaV4xt4zxjjEcX gixheBEvr/7J
GYXezLoYppIlCpI2U3BhtQ4VlUlQSOuV/wAD/g/8D/IP6/yLOi+KIdanhjXT r+0W4tvtVvJc
qgE0fy5ICuSCNy8MF68ZrdrFPhm2+x29vFd3kJt7B7COaKQLIqMF+YHHDjYM EflWyBgAZJx6
03bp/X9IBaKKKQBRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQB 5p8Yv+RfH+/H
/NqKPjF/yL4/34/5tRSQHc6Z/rZv+ucX/oNaVZumf62b/rnF/wCg1pULYGFF FFMAooooAq3k
Zke2CllPmNh1UEp+7cZGVYDr3x6ZOdpc1vK27F7Ouc4wE4zu/wBntuH/AHwP fLboA3Nj8yjE
54Kqc/u36ZOR/wAByfwyRaoA8/1y0vrG9VtSKyWM93IbbyXAEZIdvnGBkkZx 1xzyM8y6NaX1
5YadcaXA9sFgjcySHy0ZyhDEKVOWIZfn2kEAjdW5qV2bm0uWmhs3sUco0V2g KyFWx8zMwC5Y
YHDdj1OBow6lvuEhltJ7cyEqhkKEMwBOPlY9gTzxxWFeVLEQjDaz6afcXTjK nJy3M/xal9c6
Qljp9otzNdzJE6yOUjEedz73CttBVSucHlhXFRyXNlcWuja9HrNtFbpdqkWj tdyK43xPEVeF
VZgquU3EAZBBr1OmGGIzrOY0MyqUWQqNwU4JAPocD8hW1u5NzzBG8UjVdJa5 N/HqFv8AZIp0
WK7liuFIXzZGdXFsv3mBGxm+XORxi3aad/alzpMVx/wka34uS2pvK93Git5M oPlOcRqpY4Bh
I4K89K9Hoqr33EeVXlv4iW5t4ZdT1eztoVdLSUWN5eMWWeQAv5Mik/IIsGYO rDnn5s9hrN6m
m+J9Pu7m2vpbc2U8TPa2M1xhi8RAIjViMgHr6V0tFL/g/iB5Rc6dr1rLaQG6 v9JshG0lnHba
fc3IgZppGCMtrKFG1DEMSBk4wP4s6V5p8iW1heao+vyhtVuDObc3LyRxDz1j 2LFlkXDKNygE
gjJIxXoUU0U6b4ZEkTcV3IwIyDgjjuCCPwp9O+lht3dzz3ZrsGm6TAbq8Emp GawAmnYTRRGQ
vHKcnIkWBXBP3txXPQkb2vZsdd0jVJrO5urG1SaNvs8DTvBIwULJsUFzwHXK gkb+eCSN1Pst
0yXEfkzNGWRJVwxU5wwB7cjB+lOubmCztpLm6mjggiUvJLK4VUUdSSeAKVxI 4HXbm7vJ3uLC
3163MluG0lIIJ4YzdeY+5p0UDAP7s/vgF2k991N1Ox1tPD4nS71VJJ9SlF42 Lmdktw8vl7Io
pEkC5MfMZDEYzlQa9Atrq3vbaO5tZ4p7eVQ0csThlcHoQRwRUtHSw79f6/r9 TjJLG/uvAlhb
C/vZ7n7XARdCzkhmRRcKc+XPvYbVHV92cZOc1S8VafrdsLCD+3dXnsmMrTXI s5ZpFk+Ty1K2
JhfbgSc8rk/N/Dj0CihiWh5pM+ut4i011m1JpIHtY3YWd6Eu4jt8yVhvEEX3 mBRkZxtzkcYl
0ZpfD186m118wmS9jlXy7q4QytMGiKj5hgpk71+UEncQTXo1FD1/H8f6v6/c H/A/A81gs/EJ
8JX94Z9XXUsW0YWVpnKQ+XAZisQZSzcScqd+dwUgmun8Fx3EWjSLPf3V4PPb y2ubO5tnRcD5
cXLNIwzk7ix64HAro6Kd9w6JHnduYbXUbqW10u/hsrTXPtkscelzoHRrcxl0 XZ+8/enJ25PG
73rovC8sttY21pLY3cX2lrq7jLw7VhjMxZEfPKuVkGFIz8rZwRiuiooT0t/W 1gev9ev+Zx+g
Xtrp11rkdrpGoRxPqaMkcemyQqwkEaGQblVSAwZmIJ4BbuMvmv4b7xjBYyaf fW8Njceakv8A
ZsxS4nMZG4ShNioFYjJbJbjgD5utopLS3kHcKKKKACiiigAooooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKAM/Xf+Re1P8A69Jf/QDWd4f/AOQrf/8AXCD/ANClrR13 /kXtT/69Jf8A
0A1neH/+Qrf/APXCD/0KWl1GdDRRRTEFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFA BRRRQAUUUUAF
FFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUU UUAFFFFABRRR
QAUUUUAFFFFABRRRQB5p8Yv+RfH+/H/NqKPjF/yL4/34/wCbUUkB3Omf62b/ AK5xf+g1pVm6
Z/rZv+ucX/oNaVC2BhRRRTAKKKKAKt4X32yxyKjtIwUtyM+W+Mjcu71xz06D 7wcyXh3bZ4B1
xmEnH3sfxe6fkemRtLjf59ps+75p3/e6bG9OOuPvcfjirFAHnusreJefZtSt 2t7JryVrVkUM
JSd7ZY5O04JIHGcng44l0me6ntNNk0nzbryYY3ZSN8aMY2VhuLDBGVGzcMA5 21v6q0OqW8kM
unfarWOQ8iR0kLqSD5e0cHquSy55HQ5OhaXtkfLtbdHhVV2xo1u8S4A+6uQB wB0HYe1YV3Sr
wjTi+Wz6fp/TLpxnTk5NXuYPjf8AsXzNC/4SD+z/AOzftzeZ/aGzyc+RLjO/ 5euMe9czeaw+
laebXRNRXTdPmu5H0yeS6iggaFUjyiNLDLuBkZyiouCo+UhQAfUqK2JueXy6 9Jb3M+r3OsTW
t1e6LZSR26tBFHuYuGkDSRsQqFgzH5toY5B4FdD4QuX8S+Hr611p7PVokuTD v3JcRTptRxlh
HGj/AHuoQDgdep6+iqbTb8/8ybbf10sebWlrp3hzQYbiwFloEdzqdxb3mpwW sSNDEssu0FmU
qo3KiAuCBnHUiq83izVRYxyy639mnS28zTY/KiH9sv5zqo+ZTneqxHbFtI83 PQrj1GihMf8A
X9f1fzPL7XXbux1eysxqywwyXkgFjbtCZ5Ga7lDFo5Fy8e0YzEwZcE7WHTR8 QaBLrvjK/jg0
7S5JRY24TUbliJ7Il5cPCAhywxn76cgc139FCYPqeS6j4lvtHtRDYaklpNby 3VwYri5ijW7H
2mX5URoXeQjachWjwCOeci5qlo11e65Z/wDCQXkMza1ZS/ZUEGVQmDa4DRkk Z4BOQSgHPzZ9
OooTs0/63T/QPQ8vvPE2r2ZvI4Nfa41KIXcc1hJDCDaRxo/l3BUIG+YrHyTs bzflAGMaupXG
vWmptbReILjZD9jB3W0J3meZ0cn5Owxtx0KjO7nPd0UdgZwmqXMV14BjbX54 Li3j1KOG5mu1
RUeNLsJukGAnIXngDrwKoG/sdMllPh7UoNK8LTzQpJqFoqG3gk2ymQxFgYlB IhUtgruZh94m
vSqKX9fl/kM88svEdzdGxTU/En9lo0RazlAgQ6r+9dVOZEIOUWNtsYU/vcjg jETeMLrUINGt
tP1qP7XLbxLfmJI3eGZpoEYMpBCOA7jaQMZ5HFekUU1vf+uojzK51/xHp2ny SDVftTPHOhee
KONYFiukhMu5Izg7GZmJVlBGdoAKmfR9R13WGhtB4qtXjMNzJ9r0uaC7Zthi 2hnMKpkF2yBG
OCO/NejUUulvUdzy6TXZbW4n1W61ma3u7zRbJ0gVoIoyzFw0gaSNiFQsGY/M FDHIPAqOLV7v
ULLS7nUvEKxpaavJCL+3lgljkVrYsmZDCqHJbYCEXO7HJwa9Vooet/P/ADF/ X4WPL7DxLqCD
To11ZIrvFnHBoyQxItxA8SGSYDbuIXdIcoQq+XgjrXQeGbzVnutKN/qst6uo 6X9reN4Y0WKQ
eX9zYoODvOQxboMYrsKKq+t/62/pgzlLu/0u1+JVnFJqUSXkunTL9me75+/G V2xlsAkBjwMn
b3xxg+Kr3SdRkkvp5LeQ3GlRS+HnmXDtcsznMAPzCTmDOPm6V6TRSWlvL/g/ 5jvv5/8AAOS8
T32mXcVtDfyW76ZaaisOrC5UCFR5LOok3fKV3tCfTJFX/Bu3/hGIPKx9l82b 7Jjp9n81vK2/
7OzbjtjGOK3qKL6CfTyCiiikAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAZ+u/8AIvan
/wBekv8A6AazvD//ACFb/wD64Qf+hS1o67/yL2p/9ekv/oBrO8P/APIVv/8A rhB/6FLS6jOh
rh9H+JNrqvizU9GawlhtrVZWtr0MXF15RAlCoFzlSe2c12V5FNPZTxW84gne NljlK7vLYjAb
GRnB5xkVwem/Cm10ceHp7DVrpL/SZjJLPK8kiXKsD5qiNpNse/Ocr+OaFe/l /X5Ce39f1qdH
B410C6WxNtevcG/tnu7ZYLaWRpIk+821VJHpg4JPABNU7zx/o8NhdXEE4WS0 mhjuIb6G4tnj
ErAKSpiL854+XB9R1rKsfhdFp0evJbazcRfb4JLexMcQU6dE7tIyoQeQXbPb gAe9UE+EAWw1
K2Gp2Vv9tFmCLPTPJjXyH3Z2+Yclu5z159qpWbV/L8/0X47CldJ23NfQvH6T aXqN5rUMsa22
o3VqrWVhcTKscTY3OUV9px1JwPTpUd38SLOw8XC1uJUOgvpCagl5BbSzEFnI yxQEKm3nJA57
1nT/AAkaYuDrME0L3V5cNb3mn+dCDOQQyp5gxInIDnPXoO7rj4VXT20Vvb+I IoozoiaLcF7A
uzxg5LqfMAUnpyGx70lsm/60f62H3/rqv0uatj49h/tzxDbak8S2djdW9vZG 2hkllnMkW/AV
dxc9T8o6DPbNdDba0msaK9/oHk3j72jVLh3twHVtrK+ULIRg8Fc/zri734Q2 lzc3U6ahH813
b3NtDc2azxIIohFskQt+8Vlz3Ug12vh/SBomli0EWmxHeXI06y+yxc/7G5uf U55p6fl+S/W5
Kv18/wA3/wAAwvDXjS91nTLvU77R0tbK2nktj9kmlvJmkR9hxGkIO3vkZPqB V8eOvDpshdC9
lINybQQi0m8/zgMlPJ2eZnHONvTmshvh5J/whl74fj1lkNzfveGb7P8AKQ0m 8xOm750I+Ujc
M/pWc3wmhfQb/S5ZdHljvL77aUbS3SKA7FXbEsc6snK9d3Q4IPWpTdvkvv0v +pX/AAf1t+hp
XXxBgsPFstrfMltoyaUl95s1tKk+9pfLClCN3PGF27s1vW/ivSbvVDptvJdy 3S7RIqWM5WEs
u4LI+zbG2OzEEd64y7+EIupLO4PiK8+22WnxW1rdOhaSOZJC4lzu5HJXae3e tIfDt5fGtp4n
nv7OG8hKmaTT7SS3kucLgrIfOZCpPJ+TOABniq029fz0E77ry/JX/E7uiiik MKKKKACiiigA
ooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACi iigAooooAKKK
KACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAoooo AKKKKACiiigA
ooooAKKKKACiiigDzT4xf8i+P9+P+bUUfGL/AJF8f78f82opIDudM/1s3/XO L/0GtKs3TP8A
Wzf9c4v/AEGtKhbAwooopgFFFFAFW8D77Zo41d1kYqG4GfLfGTtbb6Z469T9 0uZ7wbtsEB64
zMRn72P4fZPzPXA3NuiBc2Pyqcznksox+7fpkZP/AAHB/DINqgDzvVrmae4l 0qeN7OE3crKZ
gw+1DczfLwAVGQe/8PPrbtNTukTSnDtfyCGO48shjJ80bKSSiklRnrtJywya 2dfNhqdsbe4F
yI4Jd/2m3ZB5TgEHAY/NgEggK3UgfMOL2kjR7aBbLSXtAiLny4HUnAAGTg5J 6cnmsK6p1YRp
0pcrT/r1LpqcJOc1e5R8S2/2y70Szee7ihnvGEn2W6kgZgIZGALRsrYyAcZ7 Vz0uu6tpsN3p
ujTSahLbXUqwNPCLlmgREL7pGmiHySOUyzM3HIJBNdrqWk6brFutvqmn2l9C rb1juoVlUN0y
AwIzyain0DRrq2tba40iwmt7TH2aKS2Rlhx02AjC/hWxN0ciniPVHu7rU47y FIJtLspYLL7K
07CaYuEA/eqvLcE/KDxllCk1s+Hr288SaNf2utQyW1zBctbTfZ3Nu3Cq4IMU rlDhgOJD07Zw
NW40DRrtUW50mwmCQ+QgktkbbF/cGRwvA46cVYsdOsdMt/s+n2dvaQ5z5dvE sa9AOgAHQAfh
VOzb0/q/9f0iddP66HFaZ9o0vT7X7BeTNfajqU9ks+qXtxdRxKjykYjaTk7Y 9owVJzkk4wWH
xprEljc3MQ05P7MtjPdo8Ts13tmkjPk/OPLB8kkE7+XAxxk9tcaVp15YvY3N haz2cjFnt5YV
aNiW3ElSME7ufrzUUmg6PN9i83SbF/sGPsm62Q/Z8Yx5fHyYwOmOgoT7jOM0 7XNUsJoIY1gh
0s3solnkt2nLPJdyLsOxwYeBkOyMhJwSuOZ/EMWpXviu8t9Oi1Z7lLKBrWaD UDDbW0haX55Y
/MG8cDI2PkLjFdW2gaM99DfNpNgbyAkxXBtk8yPJLHa2MjJZjx3J9avCGJZn mWNBK6hWcKNz
AZwCe4GT+ZoTB9Tzd/E+qaLpkn9mQrcpaTXNxfI1sCFQ3MgB8xpowudr/dWQ 8dOgL9bTW9Rg
121Gq2RtH1m1txDNZvJiNvJyjfvQChDDK4GQW/vcdtceHdEvJY5bnRtPnki3 eW8tqjFNxJbB
I4ySSfXJqdtK057t7trC1Ny4QPMYV3tsOVy2MnB5HpSW6v8A1qv8g9DhG8Ta romk+ZBDo5s0
N1aW1nbWzR+S9ujnc2HICExH5AoK71+Y450r/W/Etnfm2WTSX8v7KJCbeQbj PK8Yx+842AKe
+7B+7njpToekNe3F62lWJu7mPyp5zbpvlTj5WbGWHA4PoKsPZWsshkktoXc7 Ms0YJOw5Xn2J
JHoae9rh6HJarf6lqXgZHJUX7X8dq/2e4ktVkK3IjOHXLxhgO2SM45plsPEG mTQ6XaLZWc00
M9y73d9daoBsMYADSNGwzuORnAxnnJrrLjStOvLF7G5sLWezkYs9vLCrRsS2 4kqRgndz9eai
0/QdH0kEabpNhZA5yLa2SPOcZ+6B12rn6D0pd/66f5gcdJ411WeSwngtUfTp hbw3f+jgCKWZ
VO0StMCcB1PyxMO2Rzihb6lqlvo/h3Tb02k1vPBZXUP2eJkeEJNAu1yWIfO8 YIC/dPFd6fDu
hm7juzo2nfaY0VEm+ypvVVxtAbGQBgYHbFLZeHdE01HSw0fT7VJHWR1gtUQM ynKscDkg8g9q
aet/P+v8/wABdDjbDxd4svbCK/bSreG0vTB9lnlRNkfmSou07Lh2k+Vyc7Y+ V5AzgOm8Z6/Y
2bSXEFhcSyiSKFbeMptkS5S3LHfIAQ28MF3LjG3ec7h18Ph3Q7e8lvING06K 6mbfLMlqiu7b
g2WYDJO4A5PcZqw+l6fJG8cljavG6OjK0KkMrnLgjHIY8kd+9GhXU5O21nxj cSxWM9rY6ddt
FPMZbq33h1Qx7SI47hgud7DmQ/dz3xVnw7qWqar4ie5kuoEs5dLtLg2YjYsj SeZyrb8DkHPy
8gDpjnfsND0nSkCadpdlZqNwC29ukY+bG77oHXaufXA9KkTS9PjuILhLG1We 3i8mGQQqGij/
ALqnGQvsOKP6/P8A4BP9fkcGE1O28ZajeJNo7Xl5qQ0+2ubmxZntoxAsu0N5 oLLhSNg25Zi2
f4a2vDfiDV9c1JopBZRW9rGPtBWJy0ziSaMlPmwqkxBhndwce9dFdaVp19bT 213YWtxBcMHm
ilhV1kYYwWBGCflHX0HpUltY2lmqra2sEAWNYgIowuEXO1eOwycDtmhbW/rY b1/r+uhy11BF
qup682o6ve2Q03aIfs949usEZiD+cwUhXy27lwy/JjH3s4VrNd3Ph3U/Elzq GoQatb+U8MYv
ZFhMht4mEXklvLO92K425y3GDgjvr7RNJ1O5gub/AEuyu57c5hlnt0kaI5z8 pIyOQDx6U06B
ox1b+1jpNgdSzn7Z9mTzumPv43dOOvSlHT+vx+Y7/wBfock3iWQeP428y/8A sfnjTHT7PN9m
BK7vM8zb5e7zcR4zmtDVLKG+8Raq93qmoWUVnYQSpLBfyQpCSZSzlQwRvujO 9SOOeK6c2No1
v5DWsBh3+Z5ZjG3fu37sdM7vmz681Vu9A0bUL+K/vdJsLm8hx5VxNbI8iYOR tYjIweeKVtLC
RyGk+LPFWpX1ukejK9vCLdL7KxgqzxI7sWM6sm3f93ymzt4PPy1n8a6xaRif VYLcXMKtcGzj
ili2L5EzgearvHMp2D51yBzlFYADurnQ9IvdRh1C60qxnvoceVcy26NJHg5G 1iMjBJPFR23h
3RrCF49P0uxstzF91tbRoQ5Uru+7jOCRkjocdKpvR6D0ObOteKItah0d7rRp Z5zEVuEs5VSN
WjmY/L5pL4MQ/iXIJ6VT/wCEv8U3N0lnp2kw3lzbRl7rykTbMRNJH8vmXCGI Hyic4lxuxjj5
uh8OeC9J8M+a1rEkk0jhzK1tBEVIUqMLFGijhm5xk7iCSMAaF54d0PUREL3R tPuRCzPGJ7VH
2MxyxGRwSeTjqaNL3JW39f1/kQeHr7UtShubq9NqsX2iWKGKGNgyhJHTLMWI JIA4AGOeTniC
3uXs/E+tte6lIbKO1t5wLhkWO3BMu7GAMD5cktk++AMbsMMVvHshiSNMltqK AMk5J47kkn8a
oN4d0N7y4vG0bT2urlDHPObVC8qkYKs2MsCAODSGc94hjuIPE0GqSO8+moLW AwwavPbvFK0r
Dd5KYSUNvThiOFPB6G1rkkOrapY2I1CaPT2gu5ZJrK7eEiWJo1ALxsDxukyu eq8jituXRtLn
1KHUptNs5L+EbYrp4FMsY54VyMgcnoe5pt1oWkX1mLO80qxuLUSmYQzW6Onm EkltpGNxLMc9
eT60dLf1/XUpPW43w9dXF94a0u7ujm4ntIpJTxyxQE9PetKgDAwOlFOTu2yF ogooopDCiiig
AooooAz9d/5F7U/+vSX/ANANZ3h//kK3/wD1wg/9ClrR13/kXtT/AOvSX/0A 1neH/wDkK3//
AFwg/wDQpaXUZ0JIAyTgCqWnaxpmrpI+majaXqRttdradZAp9DtJwaNYhhud Ev4LiKaaGW3k
SSOAZkZSpBC++Olcabm/nhZX/tWfR45IY5buPT57S+dMSZUqiq7BXMZ3RqvD MMHDE7QpqSf9
f1+Amd/RXm15JqTa9ZyaYNYhghkt0jjlhv5DPCSu93Z3EakBmBDqz/LnI4xt +GrG/srrSpJ5
tTlNzpha8+1zSSKJh5eOGOEbl+ABnnOcVTopK9/63/rz0E2dCmrWcurSaZG0 r3MShpNsDlEy
AQGkA2BsEHaTnBBxg1drz680d7LUtTvdutra3Gqg3f2O4uWd4TAuCiI27HmB QTGNwAx90EVf
8KWmpzX/ANo1KXUxDDbobRJ5ZFBUyTBTICfmk8vy9wbJBwSN3NEqUeTmT7fk DdmdY15bJHPI
1xCqW/EzFwBHwD8x7cEHnsamritWeWGPxLpX2K+kudTcm0MVpI8ThoUQZkUF EwynO4jGM9CD
WMsuq3PmvolxrUmrR3F8sxm877N5Q84IqeYPJLB/KA288c8BqFRvG9/6t/SH 1sekJdwPeS2i
vmeJFkdMHhWLBTnp/C35U8zRCdYTIglZSyoWG4qMAkD0GR+YrzOSOSP7c2mw a+tpcpaxvd3i
ag80ZXzixCKyzMM7V2qVUb89Orvsmsmz0y7ddWbVI7G+t7aZROo80SDyfMQs eCozmUkHA3MT
iqdBd/6tf8xJ3PTaK8tji1FNIkP9ra3LEbiNntxpepxMcI+UMhkeZQx2/NGS qlRlSGIPomjG
Y6JY/aIpYpvITfHNKZHU4GQzEAsfcgE+lRUpcnW4Jl6iiisRhRRRQAUUUUAF FFFABRRRQAUU
UUAeafGL/kXx/vx/zaij4xf8i+P9+P8Am1FJAdzpn+tm/wCucX/oNaVZumf6 2b/rnF/6DWlQ
tgYUUUUwCiiigCreSGN7YqGY+Y2EVgC/7tzgZZQenfPrgY3BzXEq7sWU7Yzj BTnG7/a77R/3
2PfBcFhPaACQgykHaCQBsb72CMDp1yM44zgixQBwF5q8lw91plhO8MkV5L58 gcIcF3IC4Oev
U8dPc1bj1uWGLSrq/aORcJMXjKoSXicAEMQPU5yPTbWl4ltLLVEjja5NvdWj 71uRbtIsWVww
cjhQVIJBYfwk8ddHStEsdHgjjto2Z44xF50rb5CoA43HoOM4GBntWNenGdOM aLs09epVOUoz
cqmtyn4ia8e40izs9RuLD7VdMkk1ukbPtEUjYHmIy9VHasS48WaholvcWTrH q19a3TQAsJUk
njEaSb9kEMhyPMVWIVVz/dyBXU6ro1nrMcKXguB5MnmRvb3MkDq2CuQ0bK3Q kde9VJPCejSW
9vD5E8awbtrQ3csbvuIL73Vg0m4gE7ycnk5rUWhiDxbqH2u7vVhs/wCyv7Nt rqAXFwyP5ku/
au1YmJLEBcAk5AwCWxWpomrz+KdEuiVuNJu4pjA5iU7oyArAqJ4lPIYfejHf 2NTS+EdFmWJT
bSoIrdLZPJupY8Rocp91hkqeVY8jJwRmrumaRZaPDLFZJIolfzJGlmeVnbAX JZySThR1Paqd
rv8Arr/kTrp/XT/M5fTNQ1iysIpWv7rWr28vZrO3gvGggiTy3k+YvHCGHyRn PDZOMAdQ5vHV
w1nLdQ6QjRWMJm1Mvd7fJ2yPG4i+Q+aQYpDzsBAXnJwOgufD2mXVgLKSBxCs zXCGOZ43jkZi
xZXUhlJLN0I4JHQ4qtJ4O0KRbZTZuFt0EahLiVfMUNu2y4b96NxJw+7JZj3O Ref9f1/T6D0/
r+v67GFp/iy7tbm2sZLZJIp7uVftl7dNErbrmRFjiYoVdwBnyyynGNoPOHeI tV1WLxLc2mnX
uqCeK0hltLO2sVlgmlZpBiaQxnYp2qM704yQa3z4V0g3aXPkzhkffsW7lETN vaTLRhtjncxI
3A47dBWklpBHey3ipieVEjd8nlVLFRjpxub86ED6nDN41uNEsV32/wDaBWe5 e5xJO8sMYuHU
HCROoGAQC7IPlxng4Na1XxNPb61bW0VoIRqtvaQyi+eGQRv5W5crFlch/vAk jecfdGejufB2
h3ZbzbacK4cSJHdzRpKGZmIdVcB/mdiNwOM8Yq03h/TXvJ7owP5k8kcsgEzh GeMgo2zdt3Da
vOMkAA5FJbq/9aoPQ5geMbrRtMEk2j/6Egngt3OovPNLNCrllYumdp8uTDli TgZUZ4u3fivV
7O8Fs+hW7MvkeYVv/umaR44wMx88qpbpgE43Y50n8I6JLdXNw9o5a5EgkT7R J5YLjDsse7aj
NzllAJyeeTV2fSLG4uHnlg3SOYizb2GfKYunfsxJ9++afb8Q9DA1XXdQuPBi 31pHPaXz3cds
8do0UjhhOInEbSgIc4OCwHUZAqG11fXrIx2S6ff3l5NHLcD+2rq2gKIhjGM2 qMuDv44JyDnA
xXQ3Gg6dc6W+nSRSLbNKZiIp5I2D7/M3B1YMDu54NNsfD2n6fL5sX2uSQI6B 7q9muGCtt3AG
R2IHyL+XuaXf+un+YHOy+Pt11Yxw2AktLtIfMljaZntnlAKq+2IxKfmXgyg4 OQOmc+38Taou
j6HZ38Bt5LmKzuIbmO7aR5kEsKyCQbRtJ8wcAsCCefXqB4N0MSxOLacCLyys Qu5hFmMKEYx7
9pYBVG4jPHWnWXhDRLBFSG3ncJ5ezz7uaYxhGDKql3JVQVB2jAOBkU01e/mL oc/Z/EO8vYvN
i8O3Ijm8r7K8gniVhJIiAO8kKqD84OEMgIDYPAJlfx9dW1q815ohRirrCkE7 TF5UmWBlIWPd
t3sCCoZiuflBwp3LbwnpFmf3MVyIt6usBvZmhjKuHXZGX2IAQMBQB26cVLP4 Z0e5hMMtmGQi
Qf6xwR5kgkYg5yDvAYEcggYxRoVpcwrTxlq9/wCXBb+HNl4Umdlu5praPEZj 5UyQB2B8zr5Y
5UjpzVzRNc1LVvED4t4V0qTT7a6TdN+9jaTefuhMHOMH5uNoI6nGpZaBYWDq 8X2qSRUdA9ze
TTsFcqWG6RmOPlX6Y46mltdB06yu4Lm2heKWC3W1TbM4UxLnarLnDYycFgSM nB5NGn9fP/gE
/wBfl/wTkk1LXIvFupSmyjupHvfsFhH/AGtLHEiiFZDvj8vYOAzb8M2SFHA3 Vs6H4outc1D7
NFpkcSQx5u5Guc+W4eWNkQbPnw8R5O3IOevFaV54e0y+jmSeB8yzi5Z45njd ZQoUMrqQyHaM
fKRxn1NS6do1hpI/0KDyv3SRE72YlVLEZJJycuxJPJJJJNC2s/60/wAxvyMe b+1tY1PVUtNb
k0xNPkWGKOKGKQSOY1k3S71J2/OAApU4B55GMO01nWr/AETUfE66tcQrZok4 00wRGF1+zxyM
hOzzMkswB38HHBAwes1LwzpWrXJuLuGYuyBJRFcyxLMo6LIqMBIvJGHBGCR0 JqM+EtGa/a8N
vMWZ1kaD7VL9nLKAFJh3eWSAq4+XgqD1FKOm49DEbxlEPiHHpX9qWnkM32I2 PmJ5omMfm+Zj
723Hyemag8U65f2XiG5trXVdQt5UtYDZ20NmslvPO7yKqzSGI7AzBF++nU4O a65tF09rQ2pt
/wB0bgXRAdgfN8zzN2c5zu56+3TinXGk2F2bs3FskovIRBcK+SskY3YUjp/E 350LSwkZ9x4j
NvFeObTcbW+hsyPMxu3+X83TjHmdPbrzWFdeMNZk8P3Fyml29nNPpT39k/2z zCAoXIceXhSN
4IxuBxzit0+DtFM6TNBcsymNsNezsrumNrspfDuNqjewLEAAmrbeH9Le1jtn tFaCO0ayVGZi
PJYKCvXn7q8nnjrR/X4f56gjmJvGeqWEl7HLpEc81ssk1wi3w2xpGkJYRnyl LE+bwGA5BywB
GHX3jy9s3+yf2E0mpLLIjxRPPNGFVY2zuigdskSpwUAyG+bpu3YvCmjRRTRi 2lfzonikaW5l
kZ1YIGBZmJORGnOc8fWnXnhfSb6UzSwzRzmQy+db3UsEgYqqnDowYAhFyoOD tBxkUdgXmWRd
XF7oS3dqptLia3EiLdwMTExGcOmVOR0IyKZoF1PfeG9Nu7h99xNaRySMABuY qCTgdOasy2MM
2nGxdp/JMflkrcSCTGMf6wHfn3zn3qlYeG9L01bZbeGU/ZoHt4TNcySlY3Kl ly7E4+RcemMD
AofX+u//AAAXS5k+DbrVW8201641U6okEUksN4lr5YzuBaIwDlSysMOd3A4G eWWWqalJrNpd
vfSPa3mo3Vh9hMcflxCLzQrqwUPkmHnLEfOcAcVqW3hLRrWFo1t55A0kUhae 7lmfMTboxudi
wVW5C5xyeOTViLw/psOsNqqQyfam3HmeQxqWADMsZbYrEDlgATk5PJp3V7jb un/X9f0jTooo
pCCiiigAooooAKKKKAM/Xf8AkXtT/wCvSX/0A1neH/8AkK3/AP1wg/8AQpa0 dd/5F7U/+vSX
/wBANZ3h/wD5Ct//ANcIP/QpaXUZuzwQ3VvJb3ESSwyoUkjkUMrqRggg8EEd qxf+EI8Jf9Cv
on/gvi/+Jreoq4zlHZiMH/hCPCX/AEK+if8Agvi/+Jo/4Qjwl/0K+if+C+L/ AOJrGn1y+0TU
ry81y71KKJGuGt7NLaJ7a5iRWZRG6gusm1QSJHGTuwpAyFi8d3jaZczTaKbe 7SSNIIpVu0W4
3Z4TdaiRnAUkqsbADBz1xXtalr8zDlNj/hCPCX/Qr6J/4L4v/iaP+EI8Jf8A Qr6J/wCC+L/4
msyw8cy31vLdHSTFa2tp9pvHeZldCDKpREZAWO6L+LZwecEYps+q+KE120B0 mxErWU8gtl1R
/KIDRfM7eTwwyQAFYcnkUOrNOzkwSTNX/hCPCX/Qr6J/4L4v/iaP+EI8Jf8A Qr6J/wCC+L/4
mqHiPU9QvvBVld6RGI5NQktVIkuWgZI5XXIDorEEg7cjkZJByADSHjG60bTB JNo/+hIJ4Ldz
qLzzSzQq5ZWLpnafLkw5Yk4GVGeH7Sprq9BJJ2aNz/hCPCX/AEK+if8Agvi/ +Jo/4Qjwl/0K
+if+C+L/AOJqzPql1ZaXb3N5ZxpPLcRQmGOcuFEkgQHcVGSAwJGOvGT1rMuf E+ovrdxpWmaR
b3M8Jk+a4vTChCLE3URscnzsYx/D15qfaz/mf/DBZFr/AIQjwl/0K+if+C+L /wCJrXsrG002
0S0sbWC1to87IYIwiLk5OFHA5JP41xMni6+12xs7vTbIW+mm7slnuJbspKDI 0blFRVIZcOFJ
Lr1PBHVtz47vrmx1qOys4Y54LKW5srpHmMUyoQNwaSBVb7ykbN6n16EkpTlp J/1a47Hf0Vxq
+Nb9ddTTJNBlkMckcF1LbC4mVJGVWyrCARlAHXJZ0I+b5eBnQ8MeJZ9fa6We yhs5IQjfZzcM
08YbdgTRMitG2Bn+JSDkMRzU20uB0VFedaJq3iGKe5lfTYbzUbyW6kAfWZhA kMMpTaFMRVCM
oo2r82CzEHg9L4d8SS+I5JZ7exWPTlVCk8k37xy8ccgHlheBh8Eluo4BzwJX B6M6CiuA8Q+N
ZlfVNNht9sXkTpBf2zznEqRliCxiWMEbWHyyMQRjHXGgdT1G2+H2q39tL5l9 A14YnmfptlcD
khugHAxjgCl0uHWx19FcRY+INas72/e/0+BrUajFbzOt+zmAvHEAIlMY3KGb Jzs6nANXfC/j
CfxHeMjaNdWts8PnwTvFOAy5GA5eJEDEMCAjODg84AJaV9v60uB1VFcV/wAJ lqEcd+0GlLcw
2Aea4lmvAjeWJpUwirHhmAiyAcDkAtnkx6l4y1JrfXoLWyt7S5s7aeS3Fxcl J2CEL5nlNHzG
ckq6l1OMHByAh2O5orjLzxnd2Op2+n3On27bzHFcy2k0832eV+ApbyBGOqn5 nVsNnb0zh6T4
zv8ATdMihFrdareT7HXf9okCItvblsmKKVgS0mfugctkg4y0r3Een0VxN74l 1PUlt2stOa0s
kvbKO4luLhoZ1Z2jcoIghyMOFbcy9WGDjk8Y39/a69ZP5bPpNpZT31wkF/Lb yuY2ToI1+fAJ
whYKxY5xtGS39fK4LU7aiuJi8d3jaZczTaKbe7SSNIIpVu0W43Z4TdaiRnAU kqsbADBz1xDJ
411RxZalbadD9i/s+6uLq3mneJ1eKRVOMxbjg5AztyGOQCMUWd7f1tcDvKK5 zU/Et1a63HpN
lpqXNxL5expLnykG5ZW+Y7WIA8nsCfm6cVnL48uZNSvIYfD1/cWsHnokkEE7 M7xBsjmERYYo
QpEjEkqNoJICHY7Sisbw1rcmu2Es80VpFJFL5bR21yZtp2g7X3IjI4zgoygj FbNNqwgooopA
RQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFAHmnxi/5F8f78f8A NqKPjF/yL4/3
4/5tRSQHc6Z/rZv+ucX/AKDWlWbpn+tm/wCucX/oNaVC2BhRRRTAKKKKAORu NWjimzeXmtmQ
TzGMWekvcpGFkeMYZIHwcAjBOefQ1tadfMLJhcvPNJHLMhkEBJYLJIB9xcZw nbvjuRlradJb
SKkGq3MKTTu3l5i4LbnIXMZJ5zxnpk54q9ZWi2VsIVkkk+d3LyY3MWYsScAD qT0FAHHX+psY
57GwCyXK3c3nMYdwiBdz/EMEngdCOvTip7C+hgfTbl7CO0MqrJI9rGSHVo2I XCjd1GcYIG3O
a0Ne8MpeqlzpcVtb3ySmRmwUWbIIIcqOTzkEgnIxxkmpNK8NafBp9ss7jUts KIskwDIVAGCq
j5fUg8nk8msMRh17OHsLXTvqXTqS5pe02ZLr95qUEum2ulzWkM15cGJpbq3a ZVURu/Cq6HPy
gdaybnxr/YWmzvrcET3Fpd/ZJnt54YI2byxIrL58iYyrD5QzEHI5AzWzr2mx X0NtM+qXGmNa
S+alzCYgVJUpg+YjLghj29Kz08K2Vytvd2er3q3A8zzL6F4ne53ld+4sjKM7 FHyBcbQBgDFb
X6f1/wAMK3Vka+MGN/esmnTS6XDp0N9HdLJDGCrhzyZJFxkKMZAAw2SBirmj +IY/FWhTXmiT
RQTLIYt04S4RHGDz5Um1hgj7r9/UEVXm8EWUkMMUd/fwpFbQW4CGNt3ktuic 70b5lOT6HPIP
GNXSNIXSY7kfbLm7luZfOlmuSm5m2qvRVUAYUcAVTtd9v+D/AF+BGun9dP8A MwdO8Qaxb2Au
tVMGoST3Ulpa2emWRikd0dwTukmK42xluSoHqTjM7+OrAQLMljqEsSRebeMi JixUOyN5uXGS
GR8hN5+QnpjN6fw1byWEVtDeXdtJBdPdQ3MLJ5kbuzFsblKkYdhhlPB9RmqL +BbAwLCl9qEU
TxeVeKjpi+Uuzt5uUOCWd8lNh+cjpjAvMf8AX9fIg0vxiJL2PS5Le6vb55Zn doBEBFD9oeJG
KllZlG0AlFbGMnGRmHxJ4su9J16ezg1DSYzDbRTxWE8TNc3zMzgxxESDBO0A fI2C3NaEvguz
mntjJfXrWtvc/altGETRmXzGkDgmMupBcjKMvAAOec7cdhFFqdxfqz+bPFHE wJG0BCxGPf5z
+lCsD6nKP48ttEsLaTWdzfaLq5jEvnW8e1UmZANjyKz4GPuKx/E8x6z4r1pL fV7ez0i8EkGo
w2UNzCbc/K/l5YB5MF/nONy7fmTI4bGhceBrOY3Ai1LULZLqN47lITF++Vnd 8EtGWGDI2NpH
vmr7+Grd7y5nN3diO4uIbloAU2CWMphh8u4ZCKCM444AJzSVrq/9ar9LhtsZ UXja2sLLN7aa
uYoklUXlxHDm4liUmRAI2Hzja/RQp2HaTxmzceNIrW4WCbRdWWQiMsAkR2eY 7JHnEn8TL2zj
cN23nBceCLG6lnE19ftayGZ47QunlwSSgh3Q7N2TufhmKjccAcY0rrQbW7u5 LmSSYO5tyQpG
P3Ll17dyTn29Kejt/XqG2xWm8R7/AA2up2lpJ58kq28dvcEKVmMvlbXIJGA3 UgngcZ4qhP4h
1Pw9epa64LfUPtEYa2fTbZomLeYkZQo8jDrKh3bh34GMnYOgWT6PNpcnmPby yvKSWwyu0hky
pGMEMcg9sCsi/wDB9xc2+7+3L+41DzIdl5cmINDGkquwRUjEeTtzkoSSACcA YS3/AK2DoQX3
xK0jTI9t9bXNrerK0T2VzNbQuhVVYne8ojIxIhG1yTu6cNi5beN7G8lia1sb +ayeWKE3yogh
VpVRo+rhyD5ijIU4J5xTh4OjR1uYdZ1OHUy7tLqKGEyzBgoKspjMeMRxgYQY 2j1Obq+HrfyJ
Y5Lm5laW6iu5JGKhmkj2Y6KBg+WMgDucY7NW6/13B+RTv7zxBLr13aaTNpiR WttFMYrq3kZp
mcyDb5iyAIPkHOxsZzg9KrJ8QNL+26RayxPE2qQxSwM1xB/y0HyjyzJ5p54y EI98A40dQ8Of
btTlvU1jUrMTQpBPDbGILKiliAWKF1PzsMoyn0IPNVz4MslvPMt7y8t7UzQz myh8sRM8WwIS
ShfpGoxuxx0pLfX+u/8AwAeztuZ3/CffYdCfU9X0qe3QXktspa5tYgwV3AIM k4BOFwRnJIOB
jmt6/wBaVPDY1Sw2ytPGhtA4OHeTAjBHXBLDNZ7eDIRdfaLfV9St2EkzJ5fk nYkrB5IwWjJC
lhnOdw6AgcVdn8L6Zd6Pp+k3cZurGy2YhnCus2xSq+YCMN69uQKOn3f8H+u4 PfTz/wCAU7Tx
U8ml2THTri91SXzEltLLYpR4m2SnMjqoUNgctnkYzzRd+NLSxtru8uNPvY9O tiUa9doViaTc
E8sZkBB3nbuICcE7sc0J4JsbNi2j3d1o581njFikIWIMqh0VGjZQpKKx4zuy QRmnyeEo5FuI
f7X1JbWZ/OW3UxBYptwfzEPl7gd43YLFckjbjij+v6/rfyGjPtviTpN7FbfY bW6vLm4kljW1
t5rd3BjVWbDCXY5CupwjM2D04ONfSPE1vrWo3draWd15VrJJC903l+X5iEBk wHLq3PRlXI5G
Rg1W1DwidW04WOo69qd3AxImWWO1InUlSFZfJxwVyCoDDJ56Ys2PhmCz119X e8urq58poYvP
Ef7mNm3FAyoHZc4wHZsdqegun9f1/X3ZcGu63Ei6peS6dJpbX7WZhjt3jmiB nMKPvMjB+duR
tXgk54wa0PxW8Nzw3cqSMUt4xKu2e3YyqXVAcCQ+X8zp/rfLxnnGDjYtvCcU Nzum1PULq0Fw
9zHYzGIQpIzl8/Iiu2CxIDMw6HGQCEt/C81nZtZ23iLWIrZVVbeMeQfswVgQ FYxFmGBt+ctw
eeeaS8x6f1/X9diE+L9k5ik0vUftTiNYtPEUfnF2Mufn83y8bYmbOQMDqSQB EPHtsYpZBo2r
EW6eZdYWH/Rl3uhLHzMNgxtwm44xgGqs/gNNN06P+wHddQhZGilaeO3CEGQs w2wOgz5zgr5e
3ngAjNXdI8Hi30O6tdRu5prq/tzFdyIy93kc7SEUZzKwztAOAdo6U9BMqzfE 7w/DqV5Y73d7
YTZMcsLM7RAl1EYk80EbW5ZADjg8jPVWtzLdWQnNpLbyMDthuCobqcZ2lgAe D6gHkA8Vjv4S
RkvLddX1KPT7sS77EGExqZM7irGMuOSWxuwCemOK32UmMqrFSRgMMZHvzxS6 B1M3w/qF1qmk
Lc3sMMNx500bxwuXRdkjJwxAJ+71wM+g6VlaFrmo3viC8stQnhg2STiGzbTJ 4XeNJNquszvs
lG3aTsXjeOne7pfhs6XFBH/bOp3Kw3L3I81ol3lw25WEaKGXLlsHoQOwxTG8 LiWe6mm1rVZX
lhlhgYyxqbRZCC3llUBzwuCxYjAx3y+o+lite6/qMOrztD9kGm2d7b2NxE8T GWRpRHh1cNhQ
POTgqc4PIyMdRWLceGre41Zb03l2kZljnmtEKeVPKgAR2yu/I2r0YA7BkHvt Uun9f1vcT3Ci
iigAooooAKKKKACiiigDP13/AJF7U/8Ar0l/9ANZ3h//AJCt/wD9cIP/AEKW tHXf+Re1P/r0
l/8AQDWd4f8A+Qrf/wDXCD/0KWl1GdDRUF5ciysp7po5JFhjaQpGAWYAZwAe 9VBrlq+oxWaB
mMiI4l3KEwyuwxkgk4QnAB4IPTJFKLeqEQDwro/2qad7eWXzfM3Qz3MssI35 37YmYoucsDhR
wx9TUa+ENJW1+zbtSKBw6M2q3ReMgEDY5k3JwSCFIBB5q9Z65pGooHsdVsbp DIYg0FwjjeBu
K8HrjnHpzViC8trpFa2uIpw0ayr5bhtyNnawx2ODg9Dihxa0aApWXh3StOhm htrQCOePy5Vd
2cOu52IO4nPMj/nTdP8ADmm6ZIJLdbp3CNGrXF7NOVRtuVHmO2B8q8D0qvae LtMk09rzUWGj
xiV4gNRnhjLbG2sRtdhjdx16/UZvTa9pEF19ll1SyW68ozCA3CCQxgE7guc4 wCc9OKbhJN3Q
eRJ/ZVkNPtrDyf8ARrYxmJNzfL5ZBTnOTgqOvXHNUH8I6JLdXNw9o5a5EgkT 7RJ5YLjDsse7
ajNzllAJyeeTSWXjHw7fWdjcprNhGL4DyI5LqMOzHHyAbuWBIBAzzUNp4vsp HvW1BrfT7e1O
DPcXCqhPmyxjk4A/1Wev8WO3NOnNNtoV1Y2L/TrXU7J7O7jLwtg4V2RlIIIK spBUggEEEEEc
VgyeA9Ja9imSS/iiVJBIsd/cLJK7+WNzSCQM3EYGCSD1q3eeL9Esp7aF7+2Z rq2e5tyLiILK
q4+6zMASc8duDzxV463pK3k9m2qWQurePzZoDcJviTj5mXOQORyeORS5JLW3 9bDuU38JaI92
lz9jZChjIijnkSHMeNjGJWCEgKoBIzgAdOKbb+D9Dt1lVbWWRZYHtmWe6llU RNjKKHYhV4HC
4AxxitGz1bTtRjmksL62u1gYpKbeZZNjDqpweD7GqcviSzi0uwvzHL5V8m+I EopUeW0nzFmC
jhT3xn25pcsn0/ph/X3DIvCmlQXcdzEL5JUChiuo3AEu0YBlG/EpxgZfccAD oBVnStBsNF8w
2az7nAUtcXUs7BR0UGRmIUZPAwOahv8AxVomnQ37S6laNLYRGW4t0nQyoox1 XPGcgDOOoqaH
xDotxPbW8Or2Ek91H5sES3KFpU5+ZQDlhweR6H0p8krXsLQgvPC2j31vHDLb yqsbyOjwXMsL
gyEs43owbaxOSucHA44FX7LTrTTllW0gWFZWDMq9MhVQYHYbVUYHHFNtdX02 9cJaajaXDEkA
RTK5yACRwewZT9CPWrEE8N1BHPbypNDIoZJI2DKwPQgjgips0PcxpfB2hzzy zS207mRpGKNd
zGNS4YOVTftTIZs7QOuetaH9k2P9mT6abdWs5/M82JiSG8wkv1OeSx/OrtFL pYOtzLt/D2m2
1obZIZWjaZLhjLcSSM0ibdrFmYscbF6ntRpnh7T9HmeSxFzGrAqITeTPCgzn CRMxRB6bQMdB
xWpRQHkZa+HdKWG8iW1wl6hjuB5jfOpZ2I68cyOeMdfYVEvhXRw92zW8souk kjkSe5llQK5y
4RGYqgPfaBWzRQFzBHg3RRMkrRXblGR8SX87qzpja7KXIZhtHzEE8YzSt4O0 MwxxpbTQeUcp
Jb3c0Mi/IqYDo4bBVEBGcHaCeea3aKAMV/CmjyXsd28Nw0yGNubuYq7x42O6 7truNoG5gWwA
Cav3OmWV7KZLm3SZjA9uQ/KmN8blK9CDtHWrdFAGEvhDSVtfs27UigcOjNqt 0XjIBA2OZNyc
EghSAQeac/hHQ3toLdrJvKgEqqvnyfMspzIrfN86seSrZGQOOBW3RQBjWPhb SNPukuoYZ3uE
IYTXF3LM+QrqMs7EnAkcc+vsKRvCuktc3MwS7T7Tv86KK+nSJi4wzeWrhAxy TuAznnOea2qK
AMq18N6XaGBo4ZnkgnNwks9zLNJ5hQpku7Fm+ViMEkAdOgrVoooAKKKKACii igAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigDzT4xf8i+P9+P+bUUfGL/kXx/vx/za ikgO50z/AFs3
/XOL/wBBrSrN0z/Wzf8AXOL/ANBrSoWwMKKKKYBRRRQBXuG2z2g3Y3SkY3Yz 8jHH3hn8m6dO
MixVe4bbPaDdjdKRjdjPyMcfeGfybp04yLFABVGyvbb7HbK11EXMaAgygkkh f9ps/fXufvDk
5BN6igDC1LUrJL6zma7hMKxysCJQfnxGQVAOS21jjHOG96w9M1VbuS5lu7a6 gyUkL29xL0b5
VDANkt8oGQPTgAV1GqaJZax5RulfzIcmGRHKmMnHIHQngdQRxXOaJ4d1rfN/ aVz9nXbFETGQ
7ymMsd6nkKpJH3gSeeFrOrQi6M5R1m7f0vluONSSqRT2Ol0y+W70eG486OeQ RL5pRgfn2gkH
HANY+k+J9QuBp8uqaTBaW+pRb7WW2u2uCW2GTY6mNCGKgkbdw+UjI4zuWunW 9jZta2wdIznA
aRnxxjjcTxx0rnIPCGoyaXb2Go63HJHZ25hs2srRrdo2MZjEjEyOWYKTjaVH J68YdPmUPf3/
AOH/AOAVLlb02LN54206305ryKC/k2XMMEkL2FxHKvmMAG8sx7yOuMDBIwDm tKHX7CbUxpw+
1x3DDKefZTRI/GSFd0Cscc4BJ4Poa5yx8AvYWt6Le50y0uJ2tpE+w6Z5EKvD IXBaPzCWzkA/
MDxwR2msPBD23iWLWZ7qwlmjnkm85bDbcyb1YbHmMjEqNw2gAABQOcZrRWv/ AF2/zuZ62L1z
rGvxeIo9Mi0fTHhlR5knfUpFby1ZQSU8ggN8443Ee9SReMtBlhuZlvXEcCBy 7W8iiVS20GIl
f3oLYAKbskqB1GdCbTRNrMGoGXAitpbcx7fvb2Q5znts/WubXwPdtFCs+so7 WMCwabItptMI
WRHBl+ciU5ijBwE4DYwTkJdL/wBb/wDAK/r+v6+8uN4z08XcMglZbEwStJ5l tKs6yrJGip5Z
AfcfM4Xbk5XHXm3e+IQugpqWmW32lpZ44I4rrfa/M0gj+fchZcE91zxWPL4H nuPtNxc31hcX
t3va48/TvMtpCWhx+5MmdoWBRjdnJ3ZHStA+FFuPC8Oiajd/bkWdJpmuEaVZ AJRIUxIzHbxt
G5mwPWnpZf11EQWXi2eXVJbO9s0ha0jn+1Jab7r508kjyyqhnG2XkbM5GO3M 83jLT0bTTDDe
ypeXTWzAWU4khZULfNHs3L0H3gODu6Co9W8G215bxW+ntb6fbw27wJbx237k hpI3IZFZcodh
DLxuDHmq+neCpdKt4RZ3ljbzRah9tC2+n+XbjMXlMgiD5AIyQd3BPOecit/X r/kJ+X9af5kG
l+PYJmu7nUXmhtjPLFa2qaRdeftjYqzk4O8cAnagCbgGOa2pPGGhRNMPtjuI Sgd4reSRAX2b
BuVSCW8xMAHJzx0NVJfC99CkMmmarFb3cbXQLz2nmo0c8nmEbQ6ncCFwd2OD kHPDrLwfDp+l
f2db3TCFbq2nQsmSFhEQCnnknyuvHXpxQrdf6/rcb308y9pXibSdauDBY3Lv J5Zk2vBJHkA7
WxuUZKtww6qeCAaz7nxRfRR3eoQaRHLotnI6T3DXWyYhCVkdItmGVSD1dSdp wDxm5p3h/wDs
++huftXmeUt0Nvl4z50wk657Yx79eOlU7nwveypd6fDq0cWi3kjvPbm13zAO SZESUvtVWJPB
RiAxwRxgXT+uv+QFpPGOgvctAb1o8GUebLbyRwkx7t6iVlCErtYkA5wpPQU3 /hMtEEYZ5buN
zII1hksJ0mdirMNsZQOwIVsEAg7SByKxY/Bd9qtjJZa1dwpp63F3JBbQW+JV MhlVWaQuysNk
jHGwckZ6EG3ongoaTc20+NFhaCYSn+zNJFoZf3bph8SNk/PkHjHPHPADNO98 QqNAi1TSokvD
PNHDEkztANzSCPDZQshBJyCuRgjFRweJJIVu4tY0+W2vLXYzxWKyXodHJCum xN5GVYHKDBU9
sElx4dnOgHT7W+jjnF59sjmlty6hvP8AOAKB1JHb7w9aoaj4NutVhaW+1Cyu b+SSMyiawLWj
xoHCxmDzMsoLl/mc/Nz0AAXf+u3/AARl4eLrF9U0+0hiupY723knSZLWZtux gpVgE+U5Jzuw
QRgjJFaGl61ZawJvspuFeEgSR3NrLbuueh2SKrYODg4xwfQ1z0Xgie0021tL LVUtfKgurd2h
tdg2TPv/AHYVx5ZUgYOSMZ46EXPC/hMeHJ72ZTpyNdJGpj0/TxaxApu+bbvY kndySe1PT+vX
/InUntPE8Nxreo2E0S28FoheO5eQbZQnEp6fKEYgHk/hS/8ACX6R9mSfGo4k cpHH/Zdz5smB
kssfl7mUAj5gCoyOeayR8O7MRwEahem4KTR3UjzyOsyzKfM2xs5SPLlX+Ufw gc1eOi+IWkt7
w63pv9oQK8Sy/wBmP5bRNtJDJ5+d25AdwYDqMUug+pbPizRVnlikupIxErs0 0tvKkPyAl1Ep
UIWXByoJI2tkcHELeNdESFZGkvVJLDyjp1wJVChSzGPy9yoAy/MQF5HNZMXw /S3v724jXQWN
z57edNoqvcq0obdmXzBuTLEbSuSvyk96jfwDetZxQjVrSN0kdleOzlU2qsFG 21bz99uMKRgM
V5xtxxTVuo9De1fWNRtdRtrLTLCzunlgkuHa6vGt1VUKDgiN8k7/AG6VJZ+J tOutJGoM7wxr
ZR30qOhLRxuCQTjOT8rcDPSoNb8I6Z4iu7eTVYIruKG2lgVJYwzBnKfvFbqr Db1HPPUVn3fh
PWLqG4jbxBATd2gtLqR9PyzopfYy4kAVsOd3BBxwE6UK1tf63/4Av6/I008X aNNcPbwzzySr
5oGLWXY7R53or7drONrfKCTx0rPsfH+lXNjBdXKz23nQxOsP2W4aUs6uxUJ5 YLDEbEMuc4PT
jN+Dw4Io7FDdbha3c9z/AKvG/wA3zPl68Y8zrznHTms7TPBlxZ3NlNcapHOb SOOGPZamPciR
you75z82JckjA+XoM8LowNGPxloU1s88N3JKqlAqxW0rvLuBZTGgXdICFY5Q EYVueDjUtL+C
/sFvLQtLE4JUbSjZHBUq2CrAggg4IPBxXJ3vw+ivLS1je5tJ3tYbaONbyxE8 LGJZFJeMsNwI
kPAIIIByeldJpGmnSdGisY0sIWjDYFlaeRACSTkR7jjrz83Jz603bWwdg0TV G1jTFvGtZLVj
JJGYZGVmQo7JyVJGfl7Ej3PWsvQPFEmuaxqFmqaWkdnNLEyRaj5lypSQoC8P ljYG2kj5j2qX
RdF1jTbeGG41i2lVLuW4kEFiYhKj72KHdI5GHcMCD0UDuTTJNB1ie+mvJtbg E8dvNBYSRWAV
oPMKnc+XYSEbF6BQcHIPGDqPpYdd+JJ7fV3hSxjk0+C5htLm5NwVkjllC7ds e3DL+8jydwPz
HAOOehrnbrw1PPqzTJfxpYT3MN3dW5ty0kksQUKVk3YVf3ceRtP3TgjPHRUu n9f13E99Aooo
oAKKKKACiiigDP13/kXtT/69Jf8A0A1neH/+Qrf/APXCD/0KWtHXf+Re1P8A 69Jf/QDWd4f/
AOQrf/8AXCD/ANClpdRm5cSJDayyyq7RohZlSMyMQByAqglj7AEmvLpLa2m0 Qac51UMZJkMo
0O/O2DyHgiH+qySFKFuRzuwa9WoranU5L/1+gjyiLy2sJ92napa6gzRBLhod VvsqA6sf30GU
ISSTAGck8muh0XV9P0qe9Y2+rlHfbbhdFvfliBZgp/c8YZ3HGeMV21FXKspX unr5/wDAJtse
a6LqHlXkVzqWn3iNEt4qiDSr+X/XyrIOWtlxjDA/QeuBV0aVtNv7QLbahBap HGLlotMv5PtD
LAIh+6e2whBH30dSQAGB7eqUEgAknAHen7eOum/n6+XmOzPH7xtRvdHg02WL UTFFZC0Ty7bV
IURlBHmFEth5m4bco5wuON2Tmy8lxCbl7ZdVYTS7nhSw1G2MqebO+0ypbl0/ 1qH5eu0joefU
ba7tryMyWtxDOgxlonDAZAYdPYg/Qipqp4hbW/H/AIArHkzebFo0NnBBfO5t r22lEumaidiz
SB1YOYGZyMAHdjOc545L9WvYJtP+zXa2iyXdxDONHv8AzJXnVxskT7PgKPNO WDHOxeBnj1mi
l9YXbv17/IdjjINb0+HWL27W11ZYp7SGBFXQ70EFDJnP7np84x+NcvPpOhpo VhBp+jS2upRW
7xXFzH4du0MhaB4z8wt9xBZgTn0z1r1uipjWUXdX+/8A4AWPK/Ndzq9usGoW lndQ3KxIulX8
4aWVs+Zte3DRf7Sq5Uk5AB5L5b24u7qQTWNzDDd3cF7PLHpeoNLE8QQeWubY BwfLHzErgMw2
nHPqNFP28e34/wDA9P8Ahg1PNby8gTwfpOm2VvrMV/ZLFGssGh3m1Mr5crDM QyNjuR7gHB6V
32ly20ul27WcU0VsqbI45oHhZVX5cFHAYdO46c9KuUVnUqKS263/AK0/rULB RTBNE0zwrIhl
RQzIGG5Qc4JHYHB/I0+shhRRRQAUUVBBeWty7pb3MMrp99Y3DFeSOcdOVYfU H0oAnooooAKK
KRmCqWYgADJJ7UALRVaw1Gx1W0W7068t7y2YkLNbyrIhI4OGUkVNFNFOm+GR JE3FdyMCMg4I
47ggj8KAH0UUUAFFFMM0QnWAyIJmUusZYbiowCQPQZH5igB9FFFABRRRQAUU UUAFFFFABRRR
FFFABRRRQAUUUUAFFFFABRRRQB5p8Yv+RfH+/H/NqKPjF/yL4/34/wCbUUkB 3Omf62b/AK5x
f+g1pVm6Z/rZv+ucX/oNaVC2BhRRRTAKKKKAK9wu6e0O3O2UnO3OPkYZ+6cf mvXrzg2Kq3kK
TvbJJEsiGRgysm4YMbg5+U+uOq9cZ5wXNYWb7t1pA27Ocxg5zuz+e9/++j6m gDltWu4Le3kn
uYWmvJbmWOLlVcBWYAqxBKgKByvcg9TmtDTdVNxc2Xl3s84uPvRXEaIyrsLB gAoPUAZ5Xk1l
a54fl0yZ9T09Z7rz7gvdQ+UJGUEMQUCjOAxAIwTg54AObNh4Zu7vTrNNWeOA xQRp5MIWQ7lU
jLMwK/xMCMHkAhq569B04RlR95311t/X4l06nNJqeiNrWNY/skWqpp93fTXU pijhtTGGJCsx
JMjqoGFPeo38R2Npa28mrPHpFxcllhtb+5hSR2BxgbXZWPI6E9RVTxbocutw 6eI9N0zUktrk
yyWuouVikHluvXy35BYH7vaqdno2r6bcJNY6PoltHLbrbS2kV26R2yq7sDER B82d5JUqvIHJ
rd3s7El608Y6O+lQX2o31npgkRG23N3GoyyK2ASe28DkA+2CM6R1rShqKacd Tsvt0ieYlt56
+YyYzuC5yRgE5rh7Dw7r+hataC1sdPvpDZyIzzXEkUSfu7ZMbhE3JMbfLgZH ftSR/D7UobV9
Jt7i3g0+S18ia4Ezubgi38lSYGTEZH96ORSVABB7W7boSXc7mw1nTNVtpLjT dQtb6
Re: BIRT 2.2RCO cannot use this version after download [message #240670 is a reply to message #240582] |
Thu, 31 May 2007 14:32 |
--------------080107020307050905090203
Attached is a copy of a directory listing of my plugins directory for
RC0 Allinone Download.
Jason
> installation.
> Reier
>> Jason
>>> Pierre-Yves wrote:
>>>> Hi,
>>>> -Pierre-Yves
>>> Reier
name="dirlist.txt"
filename="dirlist.txt"
Volume in drive C has no label.
Volume Serial Number is 8015-5D24
Directory of C:\birt\birt-report-designer-all-in-one-2.2RC0\eclipse\plugi ns
05/31/2007 10:30 AM <DIR> .
05/31/2007 10:30 AM <DIR> ..
05/04/2007 04:02 AM 4,049,995 com.ibm.icu_3.6.1.v20070417.jar
05/04/2007 04:02 AM 131,465 com.jcraft.jsch_0.1.28.jar
05/23/2007 01:30 PM <DIR> com.lowagie.itext_1.5.2.v20070518
05/31/2007 10:30 AM 0 dirlist.txt
05/17/2007 11:09 AM 57,898 javax.activation_1.1.0.v200704300455.jar
05/17/2007 11:08 AM 383,668 javax.mail_1.4.0.v200704300638.jar
05/04/2007 04:02 AM 58,433 javax.servlet.jsp_2.0.0.v200703221034.jar
05/17/2007 11:43 AM 52,521 javax.servlet.jsp_2.0.0.v200705151656.jar
05/04/2007 04:02 AM 107,634 javax.servlet_2.4.0.v200704241052.jar
05/17/2007 11:43 AM 100,973 javax.servlet_2.4.0.v20070514.jar
05/17/2007 11:08 AM 115,217 javax.wsdl_1.4.0.v200705152208.jar
05/17/2007 11:09 AM 119,950 javax.wsdl_1.5.1.v200705160542.jar
05/23/2007 01:31 PM <DIR> javax.xml.rpc_1.1.0.v200705152206
05/23/2007 01:31 PM <DIR> javax.xml.soap_1.2.0.v200704250405
05/23/2007 01:31 PM <DIR> org.apache.ant_1.7.0.v200704241635
05/23/2007 01:31 PM <DIR> org.apache.axis_1.4.0.v2007051205130330
05/16/2007 01:21 PM 483,217 org.apache.batik.bridge_1.6.0.v200703211712.jar
05/16/2007 01:21 PM 241,833 org.apache.batik.css_1.6.0.v200703211712.jar
05/16/2007 01:21 PM 430,585 org.apache.batik.dom.svg_1.6.0.v200703211712.jar
05/16/2007 01:21 PM 93,035 org.apache.batik.dom_1.6.0.v200703211712.jar
05/16/2007 01:21 PM 370,173 org.apache.batik.ext.awt_1.6.0.v200703211712.jar
05/16/2007 01:21 PM 52,938 org.apache.batik.extension_1.6.0.v200703211712.jar
05/16/2007 01:21 PM 44,226 org.apache.batik.parser_1.6.0.v200703211712.jar
05/23/2007 01:30 PM <DIR> org.apache.batik.pdf_1.6.0.v20060613-1220
05/16/2007 01:21 PM 169,391 org.apache.batik.svggen_1.6.0.v200703211712.jar
05/16/2007 01:21 PM 144,340 org.apache.batik.swing_1.6.0.v200703211712.jar
05/16/2007 01:21 PM 68,486 org.apache.batik.transcoder_1.6.0.v200703211712.jar
05/16/2007 01:21 PM 143,870 org.apache.batik.util.gui_1.6.0.v200703211712.jar
05/16/2007 01:21 PM 87,809 org.apache.batik.util_1.6.0.v200703211712.jar
05/16/2007 01:21 PM 26,921 org.apache.batik.xml_1.6.0.v200703211712.jar
05/23/2007 01:31 PM <DIR> org.apache.cactus_1.7.2.v200606181221
05/23/2007 01:30 PM <DIR> org.apache.commons.codec_1.3.0.v20070227
05/23/2007 01:31 PM <DIR> org.apache.commons.discovery_0.2.0.v200704250405
05/04/2007 04:02 AM 122,916 org.apache.commons.el_1.0.0.v200704241052.jar
05/04/2007 04:02 AM 43,217 org.apache.commons.logging_1.0.4.v200701082340.jar
05/17/2007 11:09 AM 39,070 org.apache.commons.logging_1.0.4.v200705151524.jar
05/23/2007 01:30 PM <DIR> org.apache.derby.core_10.1.2.1
05/04/2007 04:02 AM 1,720,719 org.apache.jasper_5.5.17.v200704241052.jar
05/17/2007 11:09 AM 369,479 org.apache.log4j_1.2.13.v200704251900.jar
05/04/2007 04:02 AM 422,350 org.apache.lucene.analysis_1.9.1.v200703221049.jar
05/04/2007 04:02 AM 444,097 org.apache.lucene_1.9.1.v200703221049.jar
05/17/2007 11:09 AM 69,508 org.apache.wsil4j_1.0.0.v200705021939.jar
05/10/2007 11:00 AM 1,214,958 org.apache.xerces_2.8.0.v200702082200.jar
05/17/2007 11:09 AM 1,215,875 org.apache.xerces_2.8.0.v200704181622.jar
05/10/2007 11:00 AM 72,624 org.apache.xml.resolver_1.1.0.v200702082200.jar
05/04/2007 04:02 AM 94,982 org.eclipse.ant.core_3.1.200.v20070426.jar
05/04/2007 04:02 AM 1,086,242 org.eclipse.ant.ui_3.2.100.v20070426.jar
05/23/2007 01:30 PM <DIR> org.eclipse.birt.chart.cshelp_2.2.0.v20070510
05/19/2007 10:32 PM 83,400 org.eclipse.birt.chart.device.extension_2.2.0.v20070517.jar
05/19/2007 10:32 PM 7,891 org.eclipse.birt.chart.device.pdf_2.2.0.v20070402.jar
05/19/2007 10:32 PM 67,497 org.eclipse.birt.chart.device.svg_2.2.0.v20070510.jar
05/19/2007 10:32 PM 50,145 org.eclipse.birt.chart.device.swt_2.2.0.v20070517.jar
05/23/2007 01:30 PM <DIR> org.eclipse.birt.chart.doc.isv_2.2.0.v20070510
05/19/2007 10:32 PM 195,087 org.eclipse.birt.chart.engine.extension_2.2.0.v20070516.jar
05/19/2007 10:32 PM 1,137,973 org.eclipse.birt.chart.engine_2.2.0.v20070517.jar
05/19/2007 10:32 PM 753,132 org.eclipse.birt.chart.examples_2.2.0.v20070510.jar
05/23/2007 01:30 PM <DIR> org.eclipse.birt.chart.integration.wtp.ui_2.2.0.v20070517
05/19/2007 10:32 PM 105,821 org.eclipse.birt.chart.reportitem.ui_2.2.0.v20070516.jar
05/19/2007 10:32 PM 115,772 org.eclipse.birt.chart.reportitem_2.2.0.v20070516.jar
05/23/2007 01:30 PM <DIR> org.eclipse.birt.chart.runtime_2.2.0.v20070227
05/19/2007 10:32 PM 702,440 org.eclipse.birt.chart.ui.extension_2.2.0.v20070510.jar
05/19/2007 10:32 PM 317,384 org.eclipse.birt.chart.ui_2.2.0.v20070514.jar
05/23/2007 01:30 PM <DIR> org.eclipse.birt.chart_2.2.0.v20070227
05/19/2007 10:32 PM 58,691 org.eclipse.birt.core.ui_2.2.0.v20070329.jar
05/19/2007 10:32 PM 306,099 org.eclipse.birt.core_2.2.0.v20070516.jar
05/23/2007 01:30 PM <DIR> org.eclipse.birt.cshelp_2.2.0.v20070510
05/19/2007 10:32 PM 1,243,577 org.eclipse.birt.data_2.2.0.v200705181.jar
05/23/2007 01:30 PM <DIR> org.eclipse.birt.doc.isv_2.2.0.v20070510
05/23/2007 01:30 PM <DIR> org.eclipse.birt.doc_2.2.0.v20070510
05/23/2007 01:30 PM <DIR> org.eclipse.birt.example_2.2.0.v20070227
05/23/2007 01:30 PM <DIR> org.eclipse.birt.integration.wtp.ui_2.2.0.v20070413
05/19/2007 10:32 PM 108,423 org.eclipse.birt.report.data.adapter_2.2.0.v20070518.jar
05/19/2007 10:32 PM 165,916 org.eclipse.birt.report.data.oda.jdbc.ui_2.2.0.v20070518.jar
05/23/2007 01:30 PM <DIR> org.eclipse.birt.report.data.oda.jdbc_2.2.0.v20070518
05/19/2007 10:32 PM 12,726 org.eclipse.birt.report.data.oda.sampledb.ui_2.2.0.v20070518 .jar
05/23/2007 01:30 PM <DIR> org.eclipse.birt.report.data.oda.sampledb_2.2.0.v20070518
05/19/2007 10:32 PM 3,464 org.eclipse.birt.report.data.oda.xml.ui_2.2.0.v20070518.jar
05/19/2007 10:32 PM 17,326 org.eclipse.birt.report.data.oda.xml_2.2.0.v20070518.jar
05/19/2007 10:32 PM 40,270 org.eclipse.birt.report.debug.ui_2.2.0.v20070511.jar
05/19/2007 10:32 PM 187,636 org.eclipse.birt.report.designer.core_2.2.0.v20070518.jar
05/23/2007 01:30 PM <DIR> org.eclipse.birt.report.designer.samplereports_2.2.0.v200703 30
05/19/2007 10:32 PM 177,929 org.eclipse.birt.report.designer.ui.cubebuilder_2.2.0.v20070 516.jar
05/19/2007 10:33 PM 15,242 org.eclipse.birt.report.designer.ui.editor.xml.wtp_2.2.0.v20 070511.jar
05/19/2007 10:32 PM 113,395 org.eclipse.birt.report.designer.ui.editors.schematic_2.2.0. v20070511.jar
05/19/2007 10:32 PM 121,814 org.eclipse.birt.report.designer.ui.editors_2.2.0.v20070514. jar
05/19/2007 10:32 PM 117,954 org.eclipse.birt.report.designer.ui.ide_2.2.0.v20070511.jar
05/19/2007 10:32 PM 114,337 org.eclipse.birt.report.designer.ui.lib.explorer_2.2.0.v2007 0511.jar
05/19/2007 10:32 PM 43,955 org.eclipse.birt.report.designer.ui.lib_2.2.0.v20070511.jar
05/19/2007 10:32 PM 56,434 org.eclipse.birt.report.designer.ui.preview.static_html_2.2. 0.v20070419.jar
05/19/2007 10:32 PM 51,008 org.eclipse.birt.report.designer.ui.preview.web_2.2.0.v20070 511.jar
05/19/2007 10:32 PM 36,226 org.eclipse.birt.report.designer.ui.preview_2.2.0.v20070511. jar
05/19/2007 10:32 PM 13,903 org.eclipse.birt.report.designer.ui.samples.ide_2.2.0.v20070 419.jar
05/19/2007 10:32 PM 33,006 org.eclipse.birt.report.designer.ui.samplesview_2.2.0.v20070 419.jar
05/19/2007 10:32 PM 818,397 org.eclipse.birt.report.designer.ui.views_2.2.0.v20070514.ja r
05/23/2007 01:30 PM <DIR> org.eclipse.birt.report.designer.ui_2.2.0.v20070516
05/19/2007 10:32 PM 7,036 org.eclipse.birt.report.designer_2.2.0.v20070227.jar
05/19/2007 10:32 PM 62,437 org.eclipse.birt.report.engine.emitter.html_2.2.0.v20070516. jar
05/19/2007 10:32 PM 22,088 org.eclipse.birt.report.engine.emitter.pdf_2.2.0.v20070511.j ar
05/19/2007 10:32 PM 49,758 org.eclipse.birt.report.engine.emitter.postscript_2.2.0.v200 70419.jar
05/19/2007 10:32 PM 21,716 org.eclipse.birt.report.engine.emitter.ppt_2.2.0.v20070419.j ar
05/19/2007 10:32 PM 71,883 org.eclipse.birt.report.engine.emitter.prototype.excel_2.2.0 .v20070419.jar
05/19/2007 10:32 PM 34,623 org.eclipse.birt.report.engine.emitter.wpml_2.2.0.v20070419. jar
05/23/2007 01:30 PM <DIR> org.eclipse.birt.report.engine.fonts_2.2.0.v20070518
05/19/2007 10:32 PM 1,651,145 org.eclipse.birt.report.engine_2.2.0.v20070518.jar
05/19/2007 10:32 PM 154,149 org.eclipse.birt.report.item.crosstab.core_2.2.0.v20070511.j ar
05/19/2007 10:32 PM 317,950 org.eclipse.birt.report.item.crosstab.ui_2.2.0.v20070512.jar
05/19/2007 10:32 PM 86,002 org.eclipse.birt.report.model.adapter.oda_2.2.0.v20070517.ja r
05/19/2007 10:32 PM 2,248,344 org.eclipse.birt.report.model_2.2.0.v20070517.jar
05/19/2007 10:32 PM 7,036 org.eclipse.birt.report.runtime_2.2.0.v20070227.jar
05/23/2007 01:30 PM <DIR> org.eclipse.birt.report.viewer_2.2.0.v20070518
05/23/2007 01:30 PM <DIR> org.eclipse.birt.resources_2.2.0.v20070510
05/23/2007 01:30 PM <DIR> org.eclipse.birt.sdk_2.2.0.v20070227
05/23/2007 01:30 PM <DIR> org.eclipse.birt_2.2.0.v20070227
05/04/2007 04:02 AM 666,690 org.eclipse.compare_3.3.0.I20070430.jar
05/04/2007 04:02 AM 5,055 org.eclipse.core.boot_3.1.100.v20060603.jar
05/04/2007 04:02 AM 103,342 org.eclipse.core.commands_3.3.0.I20070502-1300a.jar
05/04/2007 04:02 AM 82,722 org.eclipse.core.contenttype_3.2.100.v20070319.jar
05/04/2007 04:02 AM 38,056 org.eclipse.core.databinding.beans_1.0.0.I20070430-0010.jar
05/04/2007 04:02 AM 249,688 org.eclipse.core.databinding_1.0.0.I20070501-0010.jar
05/04/2007 04:02 AM 81,786 org.eclipse.core.expressions_3.3.0.v20070503-0800.jar
05/04/2007 04:02 AM 110,083 org.eclipse.core.filebuffers_3.3.0.v20070503-0800.jar
05/04/2007 04:02 AM 16,948 org.eclipse.core.filesystem.win32.x86_1.0.0.v20060603.jar
05/04/2007 04:02 AM 43,015 org.eclipse.core.filesystem_1.1.0.v20070430.jar
05/04/2007 04:02 AM 81,724 org.eclipse.core.jobs_3.3.0.v20070423.jar
05/04/2007 04:02 AM 30,827 org.eclipse.core.net_1.0.0.I20070416.jar
05/04/2007 04:02 AM 120,997 org.eclipse.core.resources.compatibility_3.2.100.v20070502.j ar
05/04/2007 04:02 AM 32,200 org.eclipse.core.resources.win32_3.3.0.v20070226.jar
05/04/2007 04:02 AM 678,480 org.eclipse.core.resources_3.3.0.v20070430.jar
05/04/2007 04:02 AM 21,263 org.eclipse.core.runtime.compatibility.auth_3.2.100.v2007050 2.jar
05/23/2007 01:31 PM <DIR> org.eclipse.core.runtime.compatibility.registry_3.2.100.v200 70316
05/04/2007 04:02 AM 91,251 org.eclipse.core.runtime.compatibility_3.1.200.v20070502.jar
05/04/2007 04:02 AM 73,278 org.eclipse.core.runtime_3.3.100.v20070409.jar
05/04/2007 04:02 AM 30,804 org.eclipse.core.variables_3.2.0.v20070426.jar
05/23/2007 01:31 PM <DIR> org.eclipse.cvs.source_1.0.0.v20070202-7C79_79EI99g_ODS
05/04/2007 04:02 AM 12,922 org.eclipse.cvs_1.0.0.v20070212.jar
05/10/2007 10:58 AM 96,445 org.eclipse.datatools.connectivity.oda.consumer_3.1.0.200703 161.jar
05/10/2007 10:58 AM 122,611 org.eclipse.datatools.connectivity.oda.design.ui_3.0.4.20070 4271.jar
05/10/2007 10:58 AM 186,499 org.eclipse.datatools.connectivity.oda.design_3.0.4.20070509 1.jar
05/10/2007 10:58 AM 46,209 org.eclipse.datatools.connectivity.oda.flatfile.ui_3.0.4.200 704171.jar
05/10/2007 10:58 AM 46,363 org.eclipse.datatools.connectivity.oda.flatfile_3.0.4.200704 041.jar
05/10/2007 10:58 AM 15,184 org.eclipse.datatools.connectivity.oda.profile_3.0.4.2007032 31.jar
05/10/2007 10:58 AM 41,241 org.eclipse.datatools.connectivity.oda.template.ui_3.0.4.200 705041.jar
05/10/2007 10:58 AM 90,524 org.eclipse.datatools.connectivity.oda_3.1.0.200704111.jar
05/10/2007 10:58 AM 69,325 org.eclipse.datatools.connectivity.ui.dse_1.0.0.200705071.ja r
05/10/2007 10:57 AM 311,324 org.eclipse.datatools.connectivity.ui_1.0.0.200705071.jar
05/10/2007 10:57 AM 170,091 org.eclipse.datatools.connectivity_1.0.0.200705021.jar
04/24/2007 10:41 AM 168,605 org.eclipse.datatools.doc.user_1.0.0.200704241.jar
05/10/2007 10:49 AM 52,994 org.eclipse.datatools.enablement.oda.ws.ui_1.0.0.200705101.j ar
05/10/2007 10:49 AM 33,132 org.eclipse.datatools.enablement.oda.ws_1.0.0.200705101.jar
05/10/2007 11:00 AM 109,496 org.eclipse.datatools.enablement.oda.xml.ui_1.0.1.200705101. jar
05/10/2007 11:00 AM 84,770 org.eclipse.datatools.enablement.oda.xml_1.0.1.200704281.jar
05/16/2007 05:46 PM 8,826 org.eclipse.datatools.help_1.5.0.200704241.jar
05/10/2007 10:49 AM 7,047 org.eclipse.datatools.oda.cshelp_1.0.0.200612181.jar
05/04/2007 04:02 AM 298,959 org.eclipse.debug.core_3.3.0.v20070502.jar
05/04/2007 04:02 AM 2,123,001 org.eclipse.debug.ui_3.3.0.v20070502a.jar
05/11/2007 12:33 AM 496,437 org.eclipse.draw2d_3.2.100.v20070419.jar
05/11/2007 07:00 AM 18,098 org.eclipse.emf.ant_2.3.0.v200705110650.jar
05/23/2007 01:31 PM <DIR> org.eclipse.emf.cheatsheets_2.3.0.v200705110650
05/11/2007 07:00 AM 112,129 org.eclipse.emf.codegen.ecore.ui_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 870,831 org.eclipse.emf.codegen.ecore_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 27,515 org.eclipse.emf.codegen.ui_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 263,124 org.eclipse.emf.codegen_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 106,803 org.eclipse.emf.common.ui_2.3.0.v200705110650.jar
05/11/2007 07:01 AM 6,907 org.eclipse.emf.commonj.sdo_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 173,745 org.eclipse.emf.common_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 77,895 org.eclipse.emf.converter_2.3.0.v200705110650.jar
05/23/2007 01:31 PM <DIR> org.eclipse.emf.doc_2.3.0.v200705110650
05/11/2007 07:00 AM 23,320 org.eclipse.emf.ecore.change.edit_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 74,982 org.eclipse.emf.ecore.change_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 80,427 org.eclipse.emf.ecore.editor_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 104,060 org.eclipse.emf.ecore.edit_2.3.0.v200705110650.jar
05/23/2007 01:31 PM <DIR> org.eclipse.emf.ecore.sdo.doc_2.3.0.v200705110650
05/11/2007 07:01 AM 88,501 org.eclipse.emf.ecore.sdo.editor_2.3.0.v200705110650.jar
05/11/2007 07:01 AM 23,709 org.eclipse.emf.ecore.sdo.edit_2.3.0.v200705110650.jar
05/23/2007 01:31 PM <DIR> org.eclipse.emf.ecore.sdo.source_2.3.0.v200705110650
05/11/2007 07:01 AM 166,664 org.eclipse.emf.ecore.sdo_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 184,761 org.eclipse.emf.ecore.xmi_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 879,990 org.eclipse.emf.ecore_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 129,800 org.eclipse.emf.edit.ui_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 228,151 org.eclipse.emf.edit_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 52,823 org.eclipse.emf.exporter_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 16,545 org.eclipse.emf.importer.ecore_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 46,316 org.eclipse.emf.importer.java_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 98,724 org.eclipse.emf.importer.rose_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 69,099 org.eclipse.emf.importer_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 6,181 org.eclipse.emf.mapping.ecore.editor_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 37,655 org.eclipse.emf.mapping.ecore2ecore.editor_2.3.0.v2007051106 50.jar
05/11/2007 07:00 AM 34,968 org.eclipse.emf.mapping.ecore2ecore_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 85,446 org.eclipse.emf.mapping.ecore2xml.ui_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 49,500 org.eclipse.emf.mapping.ecore2xml_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 6,167 org.eclipse.emf.mapping.ecore_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 131,848 org.eclipse.emf.mapping.ui_2.3.0.v200705110650.jar
05/11/2007 07:04 AM 26,208 org.eclipse.emf.mapping.xsd2ecore.editor_2.3.0.v200705110650 .jar
05/11/2007 07:04 AM 23,714 org.eclipse.emf.mapping.xsd2ecore_2.3.0.v200705110650.jar
05/11/2007 07:00 AM 177,219 org.eclipse.emf.mapping_2.3.0.v200705110650.jar
05/23/2007 01:31 PM <DIR> org.eclipse.emf.source_2.3.0.v200705110650
05/11/2007 07:00 AM 6,127 org.eclipse.emf_2.3.0.v200705110650.jar
05/04/2007 04:02 AM 73,523 org.eclipse.equinox.app_1.0.0.v20070423.jar
05/04/2007 04:02 AM 92,739 org.eclipse.equinox.common_3.3.0.v20070426.jar
05/04/2007 04:02 AM 17,749 org.eclipse.equinox.http.jetty_1.0.0.v20070427.jar
05/04/2007 04:02 AM 35,592 org.eclipse.equinox.http.registry_1.0.0.v20070326.jar
05/04/2007 04:02 AM 33,711 org.eclipse.equinox.http.servlet_1.0.0.v20070402.jar
05/04/2007 04:02 AM 9,450 org.eclipse.equinox.jsp.jasper.registry_1.0.0.v20070326.jar
05/04/2007 04:02 AM 21,733 org.eclipse.equinox.jsp.jasper_1.0.0.v20070416.jar
05/23/2007 01:31 PM <DIR> org.eclipse.equinox.launcher.win32.win32.x86_1.0.0.v20070426
05/04/2007 04:02 AM 42,671 org.eclipse.equinox.launcher_1.0.0.v20070502.jar
05/04/2007 04:02 AM 103,305 org.eclipse.equinox.preferences_3.2.100.v20070409.jar
05/04/2007 04:02 AM 159,754 org.eclipse.equinox.registry_3.3.0.v20070416.jar
05/11/2007 12:33 AM 751,812 org.eclipse.gef_3.2.100.v20070508.jar
05/04/2007 04:02 AM 16,749 org.eclipse.help.appserver_3.1.200.v20070316.jar
05/04/2007 04:02 AM 319,530 org.eclipse.help.base_3.3.0.v20070426.jar
05/04/2007 04:02 AM 428,965 org.eclipse.help.ui_3.3.0.v20070501B.jar
05/04/2007 04:02 AM 457,455 org.eclipse.help.webapp_3.3.0.v20070426.jar
05/04/2007 04:02 AM 140,734 org.eclipse.help_3.3.0.v20070426.jar
05/04/2007 04:02 AM 356,051 org.eclipse.jdt.apt.core_3.3.0.v20070502-1600.jar
05/04/2007 04:02 AM 20,795 org.eclipse.jdt.apt.pluggable.core_1.0.0.v20070503-1340.jar
05/04/2007 04:02 AM 65,908 org.eclipse.jdt.apt.ui_3.3.0.v20070430-1135.jar
05/04/2007 04:02 AM 142,075 org.eclipse.jdt.compiler.apt_1.0.0.v20070502-1700.jar
05/04/2007 04:02 AM 48,685 org.eclipse.jdt.compiler.tool_1.0.0.v_755.jar
05/04/2007 04:02 AM 49,805 org.eclipse.jdt.core.manipulation_1.1.0.v20070503-0800.jar
05/04/2007 04:02 AM 4,121,211 org.eclipse.jdt.core_3.3.0.v_755.jar
05/04/2007 04:02 AM 1,272,062 org.eclipse.jdt.debug.ui_3.2.100.v20070427.jar
05/23/2007 01:31 PM <DIR> org.eclipse.jdt.debug_3.3.0.v20070501
05/04/2007 04:02 AM 5,861,118 org.eclipse.jdt.doc.isv_3.3.0.v20070503-0800.jar
05/04/2007 04:02 AM 6,337,008 org.eclipse.jdt.doc.user_3.3.0.v20070503-0800.jar
05/04/2007 04:02 AM 51,039 org.eclipse.jdt.junit.runtime_3.2.100.v20070503-0800.jar
05/04/2007 04:02 AM 14,687 org.eclipse.jdt.junit4.runtime_1.0.100.v20070503-0800.jar
05/04/2007 04:02 AM 492,072 org.eclipse.jdt.junit_3.3.0.v20070503-0800.jar
05/04/2007 04:02 AM 264,255 org.eclipse.jdt.launching_3.3.0.v20070502.jar
05/23/2007 01:31 PM <DIR> org.eclipse.jdt.source_3.3.0.v20070503-0800-7o7hE8PEFpPomYYg hICSUVP
05/04/2007 04:02 AM 9,154,295 org.eclipse.jdt.ui_3.3.0.v20070503-0800.jar
05/04/2007 04:02 AM 41,446 org.eclipse.jdt_3.2.100.v20070503-0800.jar
05/17/2007 11:44 AM 267,448 org.eclipse.jem.beaninfo_2.0.0.v200705171249.jar
05/17/2007 11:44 AM 606,997 org.eclipse.jem.proxy_2.0.0.v200704161429.jar
05/17/2007 11:44 AM 131,492 org.eclipse.jem.ui_2.0.0.v200704171010.jar
05/17/2007 11:10 AM 91,815 org.eclipse.jem.util_2.0.0.v200704171010.jar
05/17/2007 11:44 AM 68,426 org.eclipse.jem.workbench_2.0.0.v200704171010.jar
05/17/2007 11:44 AM 251,205 org.eclipse.jem_2.0.0.v200705010900.jar
05/04/2007 04:02 AM 114,433 org.eclipse.jface.databinding_1.1.0.I20070501-0010.jar
05/04/2007 04:02 AM 845,872 org.eclipse.jface.text_3.3.0.v20070503-0800.jar
05/04/2007 04:02 AM 969,942 org.eclipse.jface_3.3.0.I20070503-0010.jar
05/17/2007 12:33 PM 1,153,592 org.eclipse.jpt.core_1.0.0.v200705160000.jar
05/17/2007 12:33 PM 4,897 org.eclipse.jpt.db.ui_1.0.0.v200704250000.jar
05/17/2007 12:33 PM 58,236 org.eclipse.jpt.db_1.0.0.v200705150000.jar
05/17/2007 12:33 PM 571,331 org.eclipse.jpt.doc.user_1.0.0.v200705150000.jar
05/17/2007 12:33 PM 35,301 org.eclipse.jpt.gen_1.0.0.v200704300000.jar
05/17/2007 12:33 PM 656,867 org.eclipse.jpt.ui_1.0.0.v200705150000.jar
05/17/2007 12:33 PM 129,834 org.eclipse.jpt.utility_1.0.0.v200705070000.jar
05/17/2007 12:33 PM 10,309 org.eclipse.jpt_1.0.0.v200705090000.jar
05/04/2007 04:02 AM 24,662 org.eclipse.jsch.core_1.0.0.I20070426.jar
05/04/2007 04:02 AM 66,409 org.eclipse.jsch.ui_1.0.0.I20070501.jar
05/17/2007 12:13 PM 9,704 org.eclipse.jsf_1.0.0.v20070516.jar
05/17/2007 11:44 AM 38,488 org.eclipse.jst.common.annotations.controller_1.1.1.v2007042 51000.jar
05/17/2007 11:44 AM 17,718 org.eclipse.jst.common.annotations.core_1.1.1.v200704251000. jar
05/17/2007 11:44 AM 28,223 org.eclipse.jst.common.annotations.ui_1.1.1.v200704251000.ja r
05/17/2007 11:45 AM 54,892 org.eclipse.jst.common.frameworks_1.1.101.v200704251000.jar
05/17/2007 11:45 AM 11,870 org.eclipse.jst.common.project.facet.core_1.1.0.v20070212172 4.jar
05/17/2007 11:45 AM 51,810 org.eclipse.jst.ejb.doc.user_1.0.300.v200705092245.jar
05/17/2007 11:45 AM 229,582 org.eclipse.jst.ejb.ui_1.1.101.v200705140613.jar
05/17/2007 11:45 AM 2,268,722 org.eclipse.jst.j2ee.core_1.1.102.v200705171249.jar
05/17/2007 11:45 AM 151,081 org.eclipse.jst.j2ee.doc.user_1.0.300.v200705092245.jar
05/17/2007 11:45 AM 50,934 org.eclipse.jst.j2ee.ejb.annotation.model_1.1.1.v20070514061 3.jar
05/17/2007 11:45 AM 23,893 org.eclipse.jst.j2ee.ejb.annotations.emitter_1.1.1.v20070514 0613.jar
05/17/2007 11:45 AM 90,389 org.eclipse.jst.j2ee.ejb.annotations.ui_1.1.1.v200705100555. jar
05/17/2007 11:45 AM 130,833 org.eclipse.jst.j2ee.ejb.annotations.xdoclet_1.1.1.v20070514 0613.jar
05/17/2007 11:45 AM 226,526 org.eclipse.jst.j2ee.ejb_1.1.103.v200705151930.jar
05/17/2007 11:45 AM 10,840 org.eclipse.jst.j2ee.infopop_1.0.202.v200611161440.jar
05/17/2007 11:45 AM 23,592 org.eclipse.jst.j2ee.jca.ui_1.1.1.v200705140613.jar
05/17/2007 11:45 AM 101,524 org.eclipse.jst.j2ee.jca_1.1.103.v200705151930.jar
05/17/2007 11:45 AM 138,346 org.eclipse.jst.j2ee.navigator.ui_1.1.101.v200705140613.jar
05/17/2007 11:45 AM 749,085 org.eclipse.jst.j2ee.ui_1.1.101.v200705140613.jar
05/17/2007 11:46 AM 39,262 org.eclipse.jst.j2ee.webservice.ui_1.1.101.v200705140613.jar
05/17/2007 11:46 AM 249,210 org.eclipse.jst.j2ee.webservice_1.1.100.v200705151930.jar
05/17/2007 11:46 AM 305,594 org.eclipse.jst.j2ee.web_1.1.103.v200705171249.jar
05/17/2007 11:46 AM 36,689 org.eclipse.jst.j2ee.xdoclet.runtime_1.1.1.v200701300433.jar
05/17/2007 11:46 AM 1,469,296 org.eclipse.jst.j2ee_1.1.103.v200705171249.jar
05/17/2007 11:46 AM 12,693 org.eclipse.jst.jee.ejb_1.0.0.v200705171249.jar
05/17/2007 11:46 AM 23,986 org.eclipse.jst.jee.ui_1.0.0.v200705140613.jar
05/17/2007 11:46 AM 11,892 org.eclipse.jst.jee.web_1.0.0.v200705171249.jar
05/17/2007 11:46 AM 40,427 org.eclipse.jst.jee_1.0.0.v200705171249.jar
05/17/2007 12:13 PM 266,636 org.eclipse.jst.jsf.common.ui_1.0.0.v20070516.jar
05/17/2007 12:13 PM 379,084 org.eclipse.jst.jsf.common_1.0.0.v20070516.jar
05/17/2007 12:13 PM 500,407 org.eclipse.jst.jsf.core_1.0.0.v20070516.jar
05/23/2007 01:32 PM <DIR> org.eclipse.jst.jsf.doc.dev_1.0.0.v20070502
05/23/2007 01:32 PM <DIR> org.eclipse.jst.jsf.doc.user_1.0.0.v20070502
05/17/2007 12:14 PM 835,522 org.eclipse.jst.jsf.facesconfig.ui_1.0.0.v20070516.jar
05/17/2007 12:14 PM 858,391 org.eclipse.jst.jsf.facesconfig_1.0.0.v20070516.jar
05/17/2007 12:14 PM 7,920 org.eclipse.jst.jsf.standard.tagsupport_1.0.0.jar
05/17/2007 12:14 PM 125,647 org.eclipse.jst.jsf.ui_1.0.0.v20070516.jar
05/17/2007 11:46 AM 541,567 org.eclipse.jst.jsp.core_1.2.0.v200705071905.jar
05/17/2007 11:46 AM 6,065 org.eclipse.jst.jsp.ui.infopop_1.0.2.v200605040115.jar
05/17/2007 11:46 AM 360,787 org.eclipse.jst.jsp.ui_1.1.200.v200705092313.jar
05/17/2007 12:14 PM 372,140 org.eclipse.jst.pagedesigner.jsf.ui_1.0.0.v20070516.jar
05/17/2007 12:14 PM 291,141 org.eclipse.jst.pagedesigner.jsp.core_1.0.0.v20070516.jar
05/17/2007 12:14 PM 1,426,007 org.eclipse.jst.pagedesigner_1.0.0.v20070516.jar
05/17/2007 11:46 AM 73,075 org.eclipse.jst.server.core_1.0.204.v20070510.jar
05/17/2007 11:46 AM 158,473 org.eclipse.jst.server.generic.core_1.0.101.v200705132117.ja r
05/23/2007 01:32 PM <DIR> org.eclipse.jst.server.generic.jboss_1.5.2.v200705101546
05/23/2007 01:32 PM <DIR> org.eclipse.jst.server.generic.jonas_1.5.0.v20070211
05/23/2007 01:32 PM <DIR> org.eclipse.jst.server.generic.oc4j_1.5.0.v20070211
05/17/2007 11:46 AM 55,410 org.eclipse.jst.server.generic.ui_1.0.102.v200705100555.jar
05/17/2007 11:46 AM 2,330 org.eclipse.jst.server.installable_1.5.2.v20070117.jar
05/17/2007 11:46 AM 39,196 org.eclipse.jst.server.preview.adapter_1.0.0.v20070510.jar
05/17/2007 11:47 AM 238,294 org.eclipse.jst.server.tomcat.core_1.1.0.v20070510b.jar
05/17/2007 11:47 AM 112,024 org.eclipse.jst.server.tomcat.ui_1.1.0.v20070503.jar
05/17/2007 11:47 AM 66,376 org.eclipse.jst.server.ui.doc.user_1.0.300.v200705092245.jar
05/17/2007 11:47 AM 4,949 org.eclipse.jst.server.ui.infopop_1.0.2.v200605040115.jar
05/17/2007 11:47 AM 57,804 org.eclipse.jst.server.ui_1.0.203.v20070509c.jar
05/23/2007 01:32 PM <DIR> org.eclipse.jst.server.websphere.core_1.0.101.v20070211
05/17/2007 11:47 AM 5,131 org.eclipse.jst.servlet.ui.infopop_1.0.201.v200606130315.jar
05/17/2007 11:47 AM 103,281 org.eclipse.jst.servlet.ui_1.1.101.v200705171249.jar
05/17/2007 11:47 AM 178,304 org.eclipse.jst.standard.schemas_1.0.0.jar
05/17/2007 11:47 AM 44,797 org.eclipse.jst.ws.axis.consumption.core_1.0.203.v2007050203 30.jar
05/17/2007 11:47 AM 79,816 org.eclipse.jst.ws.axis.consumption.ui_1.0.202.v200705141919 .jar
05/17/2007 11:47 AM 92,863 org.eclipse.jst.ws.axis.creation.ui_1.0.204.v200705141919.ja r
05/17/2007 11:47 AM 4,766 org.eclipse.jst.ws.axis.infopop_1.0.201.v200705020330.jar
05/17/2007 11:47 AM 26,115 org.eclipse.jst.ws.axis.ui.doc.user_1.0.300.v200705092245.ja r
05/17/2007 11:47 AM 26,852 org.eclipse.jst.ws.axis2.consumption.core_1.0.0.v20070517134 2.jar
05/17/2007 11:47 AM 29,231 org.eclipse.jst.ws.axis2.consumption.ui_1.0.0.v200705161953. jar
05/17/2007 11:47 AM 41,546 org.eclipse.jst.ws.axis2.core_1.0.0.v200705171342.jar
05/17/2007 11:47 AM 31,736 org.eclipse.jst.ws.axis2.creation.core_1.0.0.v200705171342.j ar
05/17/2007 11:47 AM 34,855 org.eclipse.jst.ws.axis2.creation.ui_1.0.0.v200705161953.jar
05/17/2007 11:47 AM 22,032 org.eclipse.jst.ws.axis2.ui_1.0.0.v200705161953.jar
05/17/2007 11:47 AM 8,272 org.eclipse.jst.ws.consumption.infopop_1.0.202.v20070131.jar
05/17/2007 11:47 AM 537,342 org.eclipse.jst.ws.consumption.ui.doc.user_1.0.300.v20070509 2245.jar
05/17/2007 11:47 AM 712,354 org.eclipse.jst.ws.consumption.ui_1.0.204.v200705170329.jar
05/23/2007 01:32 PM <DIR> org.eclipse.jst.ws.consumption_1.0.203.v200705140613
05/17/2007 11:48 AM 2,835 org.eclipse.jst.ws.creation.ejb.ui_1.0.0.v200606130315.jar
05/17/2007 11:48 AM 209,662 org.eclipse.jst.ws.creation.ui_1.0.204.v200705141540.jar
05/17/2007 11:48 AM 123,632 org.eclipse.jst.ws.doc.user_1.0.300.v200705092245.jar
05/17/2007 11:48 AM 3,712 org.eclipse.jst.ws.infopop_1.0.201.v200705020330.jar
05/17/2007 11:48 AM 29,453 org.eclipse.jst.ws.uddiregistry_1.0.200.v200705161754.jar
05/17/2007 11:48 AM 41,195 org.eclipse.jst.ws.ui_1.0.201.v200705022145.jar
05/17/2007 11:48 AM 102,108 org.eclipse.jst.ws_1.0.203.v200705022145.jar
05/17/2007 11:48 AM 10,399 org.eclipse.jst_1.0.1.v200702280324.jar
05/04/2007 04:02 AM 259,780 org.eclipse.ltk.core.refactoring_3.3.0.v20070503-0800.jar
05/04/2007 04:02 AM 442,773 org.eclipse.ltk.ui.refactoring_3.3.0.v20070503-0800.jar
05/04/2007 04:02 AM 63,706 org.eclipse.osgi.services_3.1.100.v20060918.jar
05/04/2007 04:02 AM 22,767 org.eclipse.osgi.util_3.1.100.v20060918.jar
05/04/2007 04:02 AM 927,348 org.eclipse.osgi_3.3.0.v20070430.jar
05/23/2007 01:31 PM <DIR> org.eclipse.pde.build_3.3.0.v20070430-1700
05/04/2007 04:02 AM 981,715 org.eclipse.pde.core_3.3.0.v20070501-0010.jar
05/04/2007 04:02 AM 3,154,121 org.eclipse.pde.doc.user_3.3.0.v20070410-0800.jar
05/04/2007 04:02 AM 14,716 org.eclipse.pde.junit.runtime_3.3.0.v20070205-0010.jar
05/04/2007 04:02 AM 150,512 org.eclipse.pde.runtime_3.3.0.v20070410-0800.jar
05/23/2007 01:31 PM <DIR> org.eclipse.pde.source_3.3.0.v20061114-0800-7N7M-DUUEF6EkLW7 Gz-GE
05/04/2007 04:02 AM 570,561 org.eclipse.pde.ui.templates_3.3.0.v20070427-0800.jar
05/04/2007 04:02 AM 3,769,519 org.eclipse.pde.ui_3.3.0.v20070502-1800.jar
05/04/2007 04:02 AM 67,576 org.eclipse.pde_3.3.0.v20070403-0800.jar
05/04/2007 04:02 AM 28,428,212 org.eclipse.platform.doc.isv_3.3.0.v20070503-0800.jar
05/04/2007 04:02 AM 5,562,628 org.eclipse.platform.doc.user_3.3.0.v20070503-0800.jar
05/23/2007 01:31 PM <DIR> org.eclipse.platform.source.win32.win32.x86_3.3.0.v20070426- _19QEikF-XqdF5NwSTqN
05/23/2007 01:31 PM <DIR> org.eclipse.platform.source_3.3.0.v20070426-_19QEikF-XqdF5Nw STqN
05/23/2007 01:31 PM <DIR> org.eclipse.platform_3.3.0.v20070419
05/23/2007 01:31 PM <DIR> org.eclipse.rcp.source.win32.win32.x86_3.3.0.v20070405a-8w8e DpEbsN3KkG_gP8JZLGb
05/23/2007 01:31 PM <DIR> org.eclipse.rcp.source_3.3.0.v20070405a-8w8eDpEbsN3KkG_gP8JZ LGb
05/04/2007 04:02 AM 12,913 org.eclipse.rcp_3.2.0.v20060605.jar
05/23/2007 01:31 PM <DIR> org.eclipse.sdk_3.3.0.v20070228-0800
05/04/2007 04:02 AM 472,249 org.eclipse.search_3.3.0.v20070503-0800.jar
05/04/2007 04:02 AM 1,984,417 org.eclipse.swt.win32.win32.x86_3.3.0.v3339.jar
05/04/2007 04:02 AM 14,596 org.eclipse.swt_3.3.0.v3339b.jar
05/04/2007 04:02 AM 382,672 org.eclipse.team.core_3.2.100.I20070502.jar
05/04/2007 04:02 AM 568,176 org.eclipse.team.cvs.core_3.3.0.I20070423.jar
05/04/2007 04:02 AM 28,128 org.eclipse.team.cvs.ssh2_3.2.100.I20070326.jar
05/04/2007 04:02 AM 54,758 org.eclipse.team.cvs.ssh_3.2.100.I20061208.jar
05/04/2007 04:02 AM 1,596,026 org.eclipse.team.cvs.ui_3.3.0.I20070501.jar
05/04/2007 04:02 AM 1,266,933 org.eclipse.team.ui_3.3.0.I20070502.jar
05/04/2007 04:02 AM 233,491 org.eclipse.text_3.3.0.v20070503-0800.jar
05/23/2007 01:31 PM <DIR> org.eclipse.tomcat_4.1.130.v20070316
05/04/2007 04:02 AM 184,685 org.eclipse.ui.browser_3.2.100.v20070316.jar
05/04/2007 04:02 AM 326,991 org.eclipse.ui.cheatsheets_3.3.0.v20070416.jar
05/04/2007 04:02 AM 153,132 org.eclipse.ui.console_3.2.0.v20070430.jar
05/04/2007 04:02 AM 539,536 org.eclipse.ui.editors_3.3.0.v20070503-0800.jar
05/04/2007 04:02 AM 143,063 org.eclipse.ui.externaltools_3.1.200.v20070416.jar
05/04/2007 04:02 AM 284,601 org.eclipse.ui.forms_3.3.0.v20070501A.jar
05/04/2007 04:02 AM 45,939 org.eclipse.ui.ide.application_1.0.0.I20070427-0010.jar
05/04/2007 04:02 AM 1,734,454 org.eclipse.ui.ide_3.3.0.I20070503-1400.jar
05/23/2007 01:31 PM <DIR> org.eclipse.ui.intro.universal_3.2.100.v20070427
05/04/2007 04:02 AM 277,127 org.eclipse.ui.intro_3.2.100.v20070426.jar
05/04/2007 04:02 AM 108,709 org.eclipse.ui.navigator.resources_3.2.100.I20070424-0010.ja r
05/04/2007 04:02 AM 310,419 org.eclipse.ui.navigator_3.3.0.I20070502-1800.jar
05/04/2007 04:02 AM 37,643 org.eclipse.ui.net_1.0.0.I20070430.jar
05/04/2007 04:02 AM 97,870 org.eclipse.ui.presentations.r21_3.2.0.I20070319-0010.jar
05/04/2007 04:02 AM 91,253 org.eclipse.ui.views.properties.tabbed_3.2.100.I20070424-001 0.jar
05/04/2007 04:02 AM 74,404 org.eclipse.ui.views_3.2.100.I20070319-0010.jar
05/04/2007 04:02 AM 21,777 org.eclipse.ui.win32_3.2.100.I20070319-0010.jar
05/23/2007 01:31 PM <DIR> org.eclipse.ui.workbench.compatibility_3.2.0.I20070319-0010
05/04/2007 04:02 AM 527,782 org.eclipse.ui.workbench.texteditor_3.3.0.v20070503-0800.jar
05/04/2007 04:02 AM 3,721,279 org.eclipse.ui.workbench_3.3.0.I20070503-1400.jar
05/04/2007 04:02 AM 140,171 org.eclipse.ui_3.3.0.I20070503-1400.jar
05/04/2007 04:02 AM 96,510 org.eclipse.update.configurator_3.2.100.v20070430.jar
05/04/2007 04:02 AM 21,938 org.eclipse.update.core.win32_3.2.100.v20061214.jar
05/04/2007 04:02 AM 600,383 org.eclipse.update.core_3.2.100.v20070426.jar
05/04/2007 04:02 AM 30,783 org.eclipse.update.scheduler_3.2.100.v20070413patches.jar
05/04/2007 04:02 AM 508,517 org.eclipse.update.ui_3.2.100.v20070416.jar
05/17/2007 11:10 AM 49,501 org.eclipse.wst.command.env.core_1.0.202.v200704231835.jar
05/17/2007 11:10 AM 28,987 org.eclipse.wst.command.env.doc.user_1.5.0.v200705092245.jar
05/17/2007 11:10 AM 2,860 org.eclipse.wst.command.env.infopop_1.0.2.v200605070230.jar
05/17/2007 11:10 AM 97,116 org.eclipse.wst.command.env.ui_1.0.202.v200705030310.jar
05/23/2007 01:32 PM <DIR> org.eclipse.wst.command.env_1.0.203.v200705100241
05/17/2007 11:10 AM 35,413 org.eclipse.wst.common.core_1.1.100.v200703240614.jar
05/17/2007 11:10 AM 128,868 org.eclipse.wst.common.emfworkbench.integration_1.1.103.v200 704251000.jar
05/17/2007 11:10 AM 196,431 org.eclipse.wst.common.emf_1.1.103.v200705141235.jar
05/17/2007 11:10 AM 37,976 org.eclipse.wst.common.environment_1.0.200.v200704231835.jar
05/17/2007 11:10 AM 127,011 org.eclipse.wst.common.frameworks.ui_1.1.100.v200704121600.j ar
05/17/2007 11:10 AM 110,413 org.eclipse.wst.common.frameworks_1.1.102.v200704251000.jar
05/17/2007 11:10 AM 3,555 org.eclipse.wst.common.infopop_1.0.1.v200605270041.jar
05/17/2007 11:10 AM 263,726 org.eclipse.wst.common.modulecore_1.1.102.v200705171249.jar
05/17/2007 11:10 AM 218,241 org.eclipse.wst.common.project.facet.core_1.2.0.v20070425234 1.jar
05/17/2007 11:11 AM 195,124 org.eclipse.wst.common.project.facet.ui_1.2.0.v200704252341. jar
05/17/2007 11:11 AM 240,722 org.eclipse.wst.common.snippets_1.1.101.v200704301934.jar
05/17/2007 11:11 AM 102,603 org.eclipse.wst.common.ui.properties_1.0.101.v200703312112.j ar
05/17/2007 11:11 AM 123,055 org.eclipse.wst.common.ui_1.1.200.v200703312112.jar
05/17/2007 11:11 AM 34,266 org.eclipse.wst.common.uriresolver_1.1.201.v200703240614.jar
05/17/2007 11:11 AM 482,526 org.eclipse.wst.css.core_1.1.101.v200704101835.jar
05/17/2007 11:11 AM 232,149 org.eclipse.wst.css.ui_1.0.201.v200704101835.jar
05/17/2007 11:11 AM 780,161 org.eclipse.wst.doc.user_1.1.0.v200705020330.jar
05/17/2007 11:11 AM 389,500 org.eclipse.wst.dtd.core_1.1.101.v200705012025.jar
05/17/2007 11:11 AM 4,586 org.eclipse.wst.dtd.ui.infopop_1.0.1.v200705020330.jar
05/17/2007 11:11 AM 203,295 org.eclipse.wst.dtd.ui_1.0.201.v200704102012.jar
05/17/2007 11:11 AM 30,486 org.eclipse.wst.dtdeditor.doc.user_1.0.300.v200705092245.jar
05/17/2007 11:11 AM 575,779 org.eclipse.wst.html.core_1.1.101.v200704260107.jar
05/17/2007 11:11 AM 5,465 org.eclipse.wst.html.ui.infopop_1.0.1.v200605040131.jar
05/17/2007 11:11 AM 218,286 org.eclipse.wst.html.ui_1.0.201.v200705012025.jar
05/17/2007 11:12 AM 37,115 org.eclipse.wst.internet.cache_1.0.201.v200704092340.jar
05/17/2007 11:12 AM 57,651 org.eclipse.wst.internet.monitor.core_1.0.103.v20070328.jar
05/17/2007 11:12 AM 97,862 org.eclipse.wst.internet.monitor.ui_1.0.103.v20070306.jar
05/17/2007 11:12 AM 52,418 org.eclipse.wst.javascript.core_1.0.1.v200704101835.jar
05/17/2007 11:12 AM 4,315 org.eclipse.wst.javascript.ui.infopop_1.0.1.v200605040131.ja r
05/17/2007 11:12 AM 557,200 org.eclipse.wst.javascript.ui_1.0.101.v200705022205.jar
05/17/2007 11:12 AM 273,156 org.eclipse.wst.server.core_1.0.204.v20070510.jar
05/17/2007 11:12 AM 24,805 org.eclipse.wst.server.http.core_1.0.0.v20070509.jar
05/17/2007 11:12 AM 33,025 org.eclipse.wst.server.http.ui_1.0.0.v20070509c.jar
05/17/2007 11:12 AM 34,514 org.eclipse.wst.server.preview.adapter_1.0.0.v20070510.jar
05/17/2007 11:12 AM 21,401 org.eclipse.wst.server.preview_1.0.0.v20070515b.jar
05/17/2007 11:12 AM 101,745 org.eclipse.wst.server.ui.doc.user_1.0.303.v200705092245.jar
05/17/2007 11:12 AM 7,801 org.eclipse.wst.server.ui.infopop_1.0.5.v200704050413.jar
05/17/2007 11:12 AM 702,285 org.eclipse.wst.server.ui_1.0.204.v20070516.jar
05/17/2007 11:12 AM 369,707 org.eclipse.wst.sse.core_1.1.201.v200704190452.jar
05/17/2007 11:12 AM 116,084 org.eclipse.wst.sse.doc.user_1.0.300.v200705092245.jar
05/17/2007 11:12 AM 4,798 org.eclipse.wst.sse.ui.infopop_1.0.101.v200705020330.jar
05/17/2007 11:13 AM 694,597 org.eclipse.wst.sse.ui_1.0.302.v200705081842.jar
05/17/2007 11:13 AM 119,648 org.eclipse.wst.standard.schemas_1.0.1.v200705150253.jar
05/17/2007 11:13 AM 3,986 org.eclipse.wst.validation.infopop_1.0.201.v200609292131.jar
05/17/2007 11:13 AM 98,247 org.eclipse.wst.validation.ui_1.1.102.v200704260330.jar
05/17/2007 11:13 AM 188,640 org.eclipse.wst.validation_1.1.101.v200704251000.jar
05/17/2007 11:13 AM 3,526 org.eclipse.wst.web.ui.infopop_1.0.201.v200605070230.jar
05/17/2007 11:13 AM 48,103 org.eclipse.wst.web.ui_1.1.101.v200705151930.jar
05/17/2007 11:13 AM 97,338 org.eclipse.wst.webtools.doc.user_1.0.300.v200705092245.jar
05/17/2007 11:13 AM 50,135 org.eclipse.wst.web_1.1.101.v200705151930.jar
05/23/2007 01:32 PM <DIR> org.eclipse.wst.ws.explorer_1.0.204.v200705141919
05/17/2007 11:13 AM 3,674 org.eclipse.wst.ws.infopop_1.0.202.v20070131.jar
05/17/2007 11:13 AM 43,482 org.eclipse.wst.ws.parser_1.0.201.v200705140822.jar
05/17/2007 11:13 AM 19,663 org.eclipse.wst.ws.ui_1.0.202.v200704241537.jar
05/17/2007 11:13 AM 80,665 org.eclipse.wst.wsdl.ui.doc.user_1.0.300.v200705092245.jar
05/17/2007 11:13 AM 767,006 org.eclipse.wst.wsdl.ui_1.2.0.v200705141600.jar
05/17/2007 11:13 AM 172,392 org.eclipse.wst.wsdl.validation_1.1.201.v200705140822.jar
05/17/2007 11:13 AM 401,323 org.eclipse.wst.wsdl_1.1.0.v200705140822.jar
05/17/2007 11:13 AM 43,488 org.eclipse.wst.wsi.ui.doc.user_1.0.202.v200705092245.jar
05/17/2007 11:13 AM 66,201 org.eclipse.wst.wsi.ui_1.0.300.v200705140822.jar
05/17/2007 11:14 AM 805,789 org.eclipse.wst.wsi_1.0.104.v200705140822.jar
05/17/2007 11:13 AM 208,573 org.eclipse.wst.ws_1.0.202.v200705141919.jar
05/17/2007 11:14 AM 611,034 org.eclipse.wst.xml.core_1.1.200.v200705141726.jar
05/17/2007 11:14 AM 6,866 org.eclipse.wst.xml.ui.infopop_1.0.1.v200705020330.jar
05/17/2007 11:14 AM 715,299 org.eclipse.wst.xml.ui_1.0.300.v200705012359.jar
05/17/2007 11:14 AM 118,673 org.eclipse.wst.xmleditor.doc.user_1.0.300.v200705092245.jar
05/17/2007 11:14 AM 61,591 org.eclipse.wst.xsd.core_1.1.200.v200705021820.jar
05/17/2007 11:14 AM 1,067,350 org.eclipse.wst.xsd.ui_1.2.0.v200705141600.jar
05/17/2007 11:14 AM 115,326 org.eclipse.wst.xsdeditor.doc.user_1.0.300.v200705092245.jar
05/17/2007 11:14 AM 10,790 org.eclipse.wst_1.0.1.v200610230930.jar
05/23/2007 01:31 PM <DIR> org.eclipse.xsd.cheatsheets_2.3.0.v200705110650
05/23/2007 01:31 PM <DIR> org.eclipse.xsd.doc_2.3.0.v200705110650
05/11/2007 07:04 AM 6,189 org.eclipse.xsd.ecore.converter_2.3.0.v200705110650.jar
05/11/2007 07:04 AM 11,601 org.eclipse.xsd.ecore.exporter_2.3.0.v200705110650.jar
05/11/2007 07:04 AM 19,248 org.eclipse.xsd.ecore.importer_2.3.0.v200705110650.jar
05/11/2007 07:04 AM 84,507 org.eclipse.xsd.editor_2.3.0.v200705110650.jar
05/11/2007 07:04 AM 202,357 org.eclipse.xsd.edit_2.3.0.v200705110650.jar
05/11/2007 07:04 AM 6,182 org.eclipse.xsd.mapping.editor_2.3.0.v200705110650.jar
05/11/2007 07:04 AM 6,168 org.eclipse.xsd.mapping_2.3.0.v200705110650.jar
05/23/2007 01:31 PM <DIR> org.eclipse.xsd.source_2.3.0.v200705110650
05/11/2007 07:04 AM 714,071 org.eclipse.xsd_2.3.0.v200705110650.jar
05/23/2007 01:31 PM <DIR> org.junit4_4.3.1
05/23/2007 01:31 PM <DIR> org.junit_3.8.2.v200701261102
05/04/2007 04:02 AM 700,174 org.mortbay.jetty_5.1.11.v200701082340.jar
05/23/2007 01:30 PM <DIR> org.mozilla.rhino_1.6.0.v20070227
05/17/2007 11:09 AM 184,739 org.uddi4j_2.0.5.v200704240246.jar
05/16/2007 01:21 PM 22,414 org.w3c.css.sac_1.3.0.v200704241454.jar
05/16/2007 01:21 PM 10,161 org.w3c.dom.smil_1.0.0.v200704241454.jar
05/16/2007 01:21 PM 72,489 org.w3c.dom.svg_1.1.0.v200704241454.jar
05/10/2007 11:00 AM 211,959 org.w3c.dom_1.3.3.v200702082200.jar
05/17/2007 11:09 AM 212,583 org.w3c.dom_1.3.3.v200704190547.jar
05/23/2007 01:30 PM <DIR> org.w3c.sac_1.3.0.v20070510
05/23/2007 01:31 PM <DIR> org.wsdl4j_1.4.1
426 File(s) 168,786,394 bytes
69 Dir(s) 63,981,015,040 bytes free
--------------080107020307050905090203--
Current Time: Fri Apr 26 09:41:22 GMT 2024
Powered by FUDForum. Page generated in 0.03591 seconds
