MSSQL Connectivity [message #23517] |
Tue, 28 November 2006 10:36  |
I'm trying to use the MSSQL support in DTP 1.0 RC 0.
Does anyone know if MSSQL DSE tree-viewer support is fully implemented?
Nothing appears below "schemas" in the tree-viewer.
Has anyone had more luck?
Really appreciate your help,
Karim
Re: MSSQL Connectivity [message #29201 is a reply to message #28206] |
Tue, 10 April 2007 18:12  |
Originally posted by: unineurone.gmail.com
What drivers are you using ?
I have the same issue (nothing under any schema, even when logged as "sa")
using jtds1.2 + 3.3M6/Europa
Note that I do see the schemas when using the quantumdb plugin.
Re: MSSQL Connectivity [message #583337 is a reply to message #23517] |
Mon, 04 December 2006 12:20  |
Karim Fateem wrote:
> Karim
Hi Karim,
I was able to get a DSE tree for MySQL 5.0 using the latest (12/1) DTP
build. The following link from our Wiki might help too:
http://wiki.eclipse.org/index.php/Connecting_to_MySQL_4.x_an d_5.x
I suspect that MySQL is not fully supported (in the sense that the tree
shows all the expected db objects and properties), but perhaps it is
enough for basic SQL query building and testing using our editor. In
general, DTP provides this base support for a number of data sources, and
looks to the community to flesh out the offering through our Enablement
project.
John Graham
Eclipse Data Tools Platform PMC Chair
Re: MSSQL Connectivity [message #584937 is a reply to message #23978] |
Mon, 26 March 2007 17:15  |
I would also like to know the answer to this question.
I've installed DTP 1.5M5 on top of Eclipse 3.3M5eh (Europa).
I defined a connection profile to view the standard Northwind database. When
I connect to the database in the Data Source Explorer window, I don't see
any schema information.
Chuck
"Karim Fateem" <karim.fateem@hotmail.com> wrote in message
news:962b464fce76b71a7361c311fcd53487$1@www.eclipse.org...
> Hi John - Would there happen to be DSE support for MS SQL Server 2000 &
> 2005?
> Thank you for your help,
> Karim
Re: MSSQL Connectivity [message #585086 is a reply to message #28206] |
Fri, 06 April 2007 15:42  |
> Chuck
>> 2005?
>> Karim
Chuck, Karim:
We do have a database definition for SQL Server, but apparently it is not
working with the later versions. We'll take a look at this for anything
obvious, but it is likely to require DTP specialization by some one (or
group) that knows this server well.
-- John Graham
Re: MSSQL Connectivity [message #585152 is a reply to message #28972] |
Tue, 10 April 2007 11:29  |
But - I am using SQL 2000, not SQL 2005.
What versions of MS SQL Server do you support?
Chuck
"John Graham" <john.graham@sybase.com> wrote in message
news:8ba2915488891f75f591c14c8e61f34e$1@www.eclipse.org...
>> When I connect to the database in the Data Source Explorer window, I
>> don't see any schema information.
>> Thanks,
>> Chuck
>>> 2005?
>>> Karim
> Chuck, Karim:
> -- John Graham
Re: MSSQL Connectivity [message #585164 is a reply to message #28206] |
FUDForum. Page generated in 0.04801 seconds
